Ptc Nipple Question
#1 850maybe
850maybe
  • 346 posts
Posted 02 February 2012 - 01:41 AM
Was cleaning the gunk around the turbo this afternoon and noticed the PTC had some build-up. I wiped off some crud and noticed a nice little notch at teh base. Is this supposed to be there? Cut looks pretty straight. If so, no worries. iIf not, is this a bad thing?
#2 Keaton85
Keaton85
  • 6,439 posts
Posted 02 February 2012 - 01:49 AM
The notch is just a locating spot for the PTC into the rubber.
Did you clean your PTC out? as you should check that every so often.
#3 850maybe
850maybe
  • 346 posts
Posted 02 February 2012 - 04:01 AM
Right on. No, I haven't cleaned it out. PCV was replaced @ 282K miles. Just turned over 300k. I do need to check the turbo as the mechs said there is a " massive " oil leak there. :ph34r:
#4 scumcity14
scumcity14
  • 2,658 posts
Posted 02 February 2012 - 12:56 PM
"Massive oil leak there" probably means the oil drain tube seal on the bottom.
'98 s70. has over 62 zip-ties
'05 xc/90. The stereo sucks.
"Crowded elevators smell different to midgets"
