Failed Smog Numbers,
Started by wannacar, Feb 05 2012 04:05 AM
11 replies to this topic
Posted 05 February 2012 - 04:05 AM
Any help or suggestions would be great. I have read about the denatured alchol trick. Do you think it is worth a shot?
Posted 05 February 2012 - 04:50 AM
What kind of car? What year? Check engine light on?
Posted 05 February 2012 - 05:17 AM
97 850 wagon, No CEL.
Posted 05 February 2012 - 04:19 PM
not denatured..use isopropyl in less than a 1/4 tank. This will allow you to pass a tailpipe test only. It will not allow you to pass a visual and it will not fix any problems.
'98 s70. has over 62 zip-ties
'05 xc/90. The stereo sucks.
"Crowded elevators smell different to midgets"
Posted 05 February 2012 - 09:21 PM
Posted 05 February 2012 - 10:36 PM
wannacar, on 05 February 2012 - 09:21 PM, said:
I will try this first. How much should i use. Where can i get isopropyl.
From any drugstore etc..90%. clear not scented or anything. its common rubbing alcohol. use a 16-20 oz bottle on @ 4 gallons of gas. I have used this trick for almost 20 years and it worked even on old CIS Volkswagens
Posted 06 February 2012 - 06:38 PM
should i drive it alittle before taking it in there? should it be hot or cold?
Posted 06 February 2012 - 06:48 PM
Never take a car in for smog cold, the CAT needs to be hot to keep the NOX levels low. Drive it around on the freeway for a good 15 - 20 minutes to get the CAT hot, then take it straight to the smog shop. Try to minimize any long stops so the CAT doesn't cool down too much. .
John
1998 V70 T5
Chrome 19" Niche Rhine Wheels
1998 V70 T5
Posted 28 February 2012 - 06:33 AM
Hello I am having the same problem here in Cali ...Just wanted to know if your car passed with the isopropyl ? Thanks
Posted 01 March 2012 - 04:26 AM
I took my car to smog check to day with denatured alcohol and came out gross polluter.......Oh well putting a new Cat tomorrow...This SUCKS
