Cotter Pin Snapped Off On Both Sides On The Wastegate.
10 replies to this topic
#1 bunce1260
bunce1260
  • 48 posts
Posted 05 February 2012 - 05:13 AM
So I decided to have a fiddle with the wastegate, I wish I hadn't.
The pin snapped off on both sides, It was super brittle. The hole is now completely blocked, Ive tried hammer and pin/nail. Ive tried drilling it out.
I have no idea what to try next.
Any suggestions?
1995 Volvo 850 Turbo wagon
#2 Volvo5.0
Volvo5.0
  • 798 posts
  • Interests:Cars,Fishing,Boating
Posted 05 February 2012 - 02:50 PM
You could use a push on retainer...... http://www.bakfin.com/
#3 bunce1260
bunce1260
  • 48 posts
Posted 05 February 2012 - 04:35 PM
That looks like the solution to my problem! Thanks! Any idea if any hardware/home improvement stores stock them?
Also how do the remove? with a bit of muscle?
If I can't find it locally, any other ideas?
I only have today to fix this issue as I wont have time all week and I've got a lot of miles to drive next weekend.
#4 850R Hooligan
850R Hooligan
  • 339 posts
Posted 05 February 2012 - 04:41 PM
Have you tried spraying it down with some PB Blaster or similar product to loosen the corrosion?
#5 bunce1260
bunce1260
  • 48 posts
Posted 05 February 2012 - 04:50 PM
Yeah, it's almost as if it was one solid piece of metal. If you didn't know there was a hole in there, you'd never know. Looks like a complete piece of metal, no holes, no indentations, and super hard.
#6 850R Hooligan
850R Hooligan
  • 339 posts
Posted 05 February 2012 - 04:59 PM
Strange... have you unscrewed and removed the piece that has the pin in it. I would say if you can get it off hit up your local JY that has some 850/S70 and get another one. I know my JY has a bunch of them...just call around and see if they have any turbo's in the yard.
#7 bunce1260
bunce1260
  • 48 posts
Posted 05 February 2012 - 05:23 PM
So that nipple just unscrews?
#8 TyConn
TyConn
    Delta Bravo
  • 900 posts
  • Interests:Wings 'n Things
Posted 05 February 2012 - 06:40 PM
I didn't think it did either...
1998 V70 T5 M
1994 854M Silver on Black
1998 Black on Black S70T5
1998 S70 GLT
1990 245 DL M47
...RIP at 320K
#9 bergmjs
bergmjs
  • 1,923 posts
Posted 06 February 2012 - 03:04 PM
Don't think it unscrews, I think it's welded on the underside. A lot of PB and a brad nail with hammer should get it out. I had the same problem and that worked for me
'95 854 T5M 175k - Koni Yellows, IPD Strut Brace, IPD CAI, IPD 25mm front sway, IPD Poly Upper, M56H, NA TB+Mani, Japanifold, OBX exhaust w/ angled housing, IPD springs, 2.25" Plumbed FMIC, 18T, ARD Blue
#10 bunce1260
bunce1260
  • 48 posts
Posted 06 February 2012 - 11:09 PM
So after a bit of searching various car and home improvement stores, i found something similar to the items in the link although not as heavy duty. It seemed to hold well, i guess time will tell.
Thanks for the help guys
#11 850R Hooligan
850R Hooligan
  • 339 posts
Posted 07 February 2012 - 02:31 AM
Ooh snap...my bad, now i know what part your talking about and yeah as stated it does not unscrew. Sorry for the confusion.
