Heavy Smoker
20 replies to this topic
#1 850maybe
850maybe
  • 346 posts
Posted 05 February 2012 - 08:00 AM
Car is @ 300,600 miles now. It would smoke once in a while after a long idle or puff on accelleration at long stop lights. In December I had the control arms replaced and while the mechanic had it he instructed one of the helpers to top off the fluids. Well, this thing eating oil and all, the helper filler 'er up. Now it's blowing smoke after warming up and even after short stops ( stop signs ). Here is the my question. I use semi-synthetic and I wasn't asked what oil I had in there. Will a mix of conventional and semi-synthetic cause bad smoking issues? As mentioned in another thread, I have a " massive oil leak at turbo ". I'm also thinking the turbo is just soaked in oil and that may be what's burning off. Thoughts, ideas?
Thanks in advance for your help
#2 volvos70turbo99
volvos70turbo99
    Mrs. Brightside
  • 212 posts
  • Gender:Not Telling
Posted 05 February 2012 - 07:16 PM
well i get a little blue smoke after long idle which i'm almost positive is valve stem seals, if they are totally deteriorated you will see a lot more smoke and at 300k there probably gone.
1998 s70 glt t5 converted - 16t, white injectors, nxs mbc @ 14psi, k&n drop in filter, high flow cat, full 3in. exhaust, dp, hd wg, na tb, ipd turbo hoses, ard orange tune, stage 0 complete
#3 volvoskiah
volvoskiah
  • 1,301 posts
Posted 05 February 2012 - 10:35 PM
Valve stem seals
98 S70 GLT-M * 79 242 GT * 96 850R * 84 F150 * 99 S70 AWD
72 Chevrolet K10 Cheyenne*78 242 GT*98 S70 T5*00 V70R*04 V70R*96 855R *97 855R*98 V70R*98 V70R*99 V70R*99 V70R*98 V70 NA*98 V70 XC
#4 850maybe
850maybe
  • 346 posts
Posted 06 February 2012 - 01:51 AM
View Postvolvoskiah, on 05 February 2012 - 10:35 PM, said:
Valve stem seals
Lower mileage motor on order this week along with another turbo. New mounts, timing kit and will also have the shop replace the valve stem seals while the motor is out of the car. Better than car payments unless I can find an 04+ R wagon for a reasonable price. Saw one semi-local and looked into the dealer that was selling it. Scammers all the way. :tdown:
#5 volvos70turbo99
volvos70turbo99
    Mrs. Brightside
  • 212 posts
Posted 06 February 2012 - 03:11 AM
Valve stem seals
wheres my plus 2, you said the same thing lol.
haha,
#6 850maybe
850maybe
  • 346 posts
LOL. You got 1 in there so looks like you're even again.
#7 volvos70turbo99
volvos70turbo99
    Mrs. Brightside
  • 212 posts
Posted 06 February 2012 - 03:12 AM
sweet , thanks. and a -1 that equals 0
#8 volvoskiah
volvoskiah
  • 1,301 posts
Posted 06 February 2012 - 02:12 PM
I have an 04 v70R i selling will be in a few months, looking for around $5800. Has 183k miles but runs awesome
#9 Tommy.
Tommy.
  • 4,098 posts
Posted 06 February 2012 - 08:36 PM
^^buy this R, there will be nothing wrong with it when you get it, super good guy.^^
1997 855R Black on Black, Bilstein HD's, IPD Blues, TITANS, 3" Custom Exhaust, Custom intake pipe
("insert funny quote here")
#10 850maybe
850maybe
  • 346 posts
Posted 08 February 2012 - 06:46 AM
You on the wrong side of the country man!!
#11 volvoskiah
volvoskiah
  • 1,301 posts
Posted 10 February 2012 - 08:03 PM
I'll drive it out to you!!
#12 850maybe
850maybe
  • 346 posts
Posted 12 February 2012 - 04:51 AM
Do not tempt me to do evil things.
#13 Ex850R
Ex850R
  • 77 posts
Posted 13 February 2012 - 02:08 AM
Could you float it over to Australia???
#14 850maybe
850maybe
  • 346 posts
Posted 21 February 2012 - 04:39 AM
Nothing wrong with a road trip out to sunny San Diego. :tup:
So, have been on a quest to find a reasonable motor :blink: $1200 for a motor pushing 130 compression. Nutz!
called the two Volvo specialists/yards in my local area. No motors and one even told me to get in line lol.
Anywho, all the small stuff has been ordered so now it's down to finding a suitable motor. Think I may have found one with 170 comp. across the board. This be good yes?
Volvoskiah - shoot me some pics of the car. There's a chance I could talk the boss into letting me splurge.
#15 Fudge_Brownie
Fudge_Brownie
    Hippie Exterminator
  • 8,431 posts
Posted 21 February 2012 - 02:54 PM
Its pretty unlikely that this caused any actual problems. The only thing I could think of is if he put in a very light oil (10w-20, 5w-20), it may have increased the amount of oil seeping out. As a temperary solution, you can try using 10W-40 with your next oil change to see if that slows the leaks. But the oil is not what caused your problem. And a different oil won't be the fix.
As people already mentioned, your symptoms about a puff of oily smoke coming off a stop light is typically valve seals, especailly at 300k miles. Now if you have a leak by the turbo, oil droplets can easily hit your downpipe, which causes them to burn off. Valve stem seals will cause gray-blue smoke to come from the exhaust pipe, the oil leak on the turbo will cause smoke to come from under the car/hood and get in to the cabin intake, so you'll smell the burning oil.
86 Kawasaki Gpz900R Ninja
#16 volvoskiah
volvoskiah
  • 1,301 posts
Posted 21 February 2012 - 07:38 PM
PM Sent
#17 850maybe
850maybe
  • 346 posts
Posted 21 February 2012 - 09:54 PM
Thanks Fudge. Leaking at both points. Bluish out back and I do get the burnt oil smell in the cabin from time to time.
Will a '97 motor work without getting too hairy about replacing electronics?
VOLVOSKIAH - Thanks for the pics :tup:
#18 Scootdiggity
Scootdiggity
  • 594 posts
Posted 24 February 2012 - 01:33 PM
97 motor is fine
Volvo For Life!!!
#19 850maybe
850maybe
  • 346 posts
Posted 26 February 2012 - 08:46 PM
So, while I'm waiting for replacement parts to come in I decided to check the condition of my plugs last night.Found some oil pooled up in the valleys just behind and to the left of the filler neck but none around the PCV hose that wasn't even tightened down. Not enough there to cause any concern as it looks like it may have been a sloppy fill job.
Plugs are two years ( 20k miles ) old and #4 had some oily, sticky goo on the ring.
1 thru 5 left to right
Sorry for the bad pic but had to get the car put back together. #4 with goo.
I didn't see any type of oil or residue in the chamber after pulling the plug.
Getting anxious for all the parts to get in so the work can begin.
#20 the commissar!
the commissar!
  • 2,024 posts
  • Interests:interesting things...varies with temperature and altitude
  • Crew:ECC
Posted 27 February 2012 - 06:04 PM
that looks like oil that has been down the hole, from a spill hopefully, and cooked on there...
1998 V70 T-5 -Auto / Pewter - Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
Posted ImagePosted Image
