Reinstalling Timing Belt
Started by sdancer, Feb 05 2012 11:01 PM
10 replies to this topic
Posted 05 February 2012 - 11:01 PM
So I rescently had to take my timing belt off to fix a broken bolt on the camshaft pulley. All that is done and fixed now but I'm trying to put the belt back on. I can't seem to loosen the tensioner enough to get the belt back on. I've tried taking the tensioner off completely to understand it but when I get the belt taut on the crank, idler, cams, and water pump but I can't seem to get over the tensioner. Ive already loostend the tensioner bolt and roated the assembly to the right but to no avail. Is there a trick to it? Thanks
98 S70 glt. ARD Green tune 17psi, 15g swap, OBX exhaust straight piped, IPD HD TCV, silicone lines, KONI FSDs, IPD Sport Springs, slotted rotors IPD, IPD strut bar
Posted 05 February 2012 - 11:47 PM
hydraulic or mechanical tensioner?
If it is hydraulic, you need to take the tensioner all the way off, compress it SLOWLY, then pin it. There will be enough slack and you pull the pin when it is all back together. Mechanical I don't really know about, thought it was the same but something I saw posted the other day confused me.
Posted 06 February 2012 - 12:03 AM
99% sure it's mechanical cus it's a spring in a pulley. Less the hydraulic had that too.
Posted 06 February 2012 - 12:33 AM
Unbolt it enough so the set tab can move around without being locked onto the block. It won't have many threads left so be carefull. Then you can rotate it counter clockwise and give you the room.
Posted 06 February 2012 - 01:24 AM
I tried that a couple times and it still wouldn't go on, I even had it on basically like one thread (it even fell off a few times) is there something to that Allen key?
Posted 06 February 2012 - 01:35 AM
u need to use a 6mm allen wrench to set the indicator in the 'window' .. move all the way right to remove tension iirc.. check this link out:
http://www.underhood..._tensioner.aspx
Edited by phunktified, 06 February 2012 - 01:35 AM.
Former: 89 744 GLE 16V, 90 745 GLE 16V, 95 964, 94 854 Turbo, 01 S40 1.9T, 99 C70 HPT, 01 S60 T5, 07 VW GTI
Current: 98 V70 GLT, 97 854 GLT
Posted 06 February 2012 - 01:54 AM
A play by play would be nice. Thanks
Posted 06 February 2012 - 02:52 AM
Then use the water pump as the last install...
Play by play is get the belt on everything and like I said, make sure the metal tab doesn't lock in and is free floating. That will give you a ton of room to get the belt on.
Posted 06 February 2012 - 03:16 AM
You have the belt completely on every gear? Sitting in all the groves? And your not caught on the 10mm bolt that goes thru the bracket on the right of crank pulley?
95 850 T5-R - Sold : (
'00 V70R-STOCK/ ARD lightened Crank Pulley
'01 C70 Coupe - Stock
Posted 06 February 2012 - 03:49 AM
+1, that bolt can fool you.
Posted 06 February 2012 - 06:12 PM
It may have very well fooled me I forgot about that bolt. I'll chrck to see if that is the problem if it stops snowing today. Thanks!
