I figured with the engine out of the car it would be a great time to do the oil pan seals. Anyway, whoever installed the oil pan last I think used way too much sealant. Big chunks were oozing out of the block. I didn't want to break any bolts so chipped off as much sealant as I could see and then soaked the bolts in pb blaster.
Ending up snapping the majority of the shortest bolts that run the length of both sides of the engine.
Tried everything I can to get these out. Used two different bolt extractor kits. Two different bolt extractors even broke off inside the bolts.
I don't get how they can be THAT tight. I was wondering what other options I have to get these out and if you guys could help me decide.
I figure I can take that part of the block off ^^^ and send it to a shop to drill them out/ re tap. But I was wondering what taking that part off entails.
Im pretty sure the bolts that hold it on also hold on the crank bearings. If I can get it off without messing with the rods/crankshaft then I would be willing to do it this way.
Thankful for ANY input guys.
