Tire Question
13 replies to this topic
#1 dublin14
dublin14
  • 2,716 posts
  • Interests:Track events in NASA/ProAutoSports and dumping money into old Vulva. And one of the VS mods on here put that comment above. Dam kids these days lol
Posted 06 February 2012 - 09:45 PM
Who has used 245/40/18s on their S70? I have a set of them by Vredestein - called the Ultrac Sessanta's . Its a better tire than PS2 and I just cant say enough about them. So Im hoping they will fit? My Fenders are getting rolled also, so that will help of course. Rims are TDR 1.2s - 8 inch wide - 40 offset. I have to add that Im not a 100% on the offset as it says 40 on my bill, but I thought I got a 45 offset.
Edited by dublin14, 06 February 2012 - 09:49 PM.
#2 fischmama
fischmama
  • 3,132 posts
Posted 06 February 2012 - 10:02 PM
245s will be rub city. I have 235s on 7.5 and it already rubs pretty severe anywhere close to full lock.
A buddy here is running 245/35/18 on OZs with KWs and even with rolled fenders it rubs in hard corners or with people in the back.
I would not advise to run them.
1998 Volvo S70 T5M - 04 R Motor - T3 60Trim @ 19PSI - 3" Custom Exhaust - TT/MegaSquirt 3X - FMIC w/ 3" piping - TA Coilovers w/ Custom Rears
#3 dublin14
dublin14
  • 2,716 posts
Posted 07 February 2012 - 01:20 AM
Im not worried about full lock, or even a bit of rubbing over bumbs with people in the back which is dam near never. But.. rubbing in the corners blows. I have 15mm spacers for the rear and 5 for the front and the fenders being rolled I thought might work. Dam these skinny Volvo wheel wells. :tdown:
#4 andyb5
  • 1,942 posts
  • Interests:cars?
Posted 07 February 2012 - 02:09 AM
Nue is running 235/40s on his 18x8 +38 OZs. He is lowered on TMEs and only rubs a little bit.
http://volvospeed.co...ost__p__1308170
99 V70 R. Silver/Charcoal, 151k, working on stage 0. Still waiting for mods to start....
#5 NEU
NEU
    Old Man Crew Photographer
  • 2,982 posts
Posted 07 February 2012 - 02:27 AM
Yes, I'm running 235/40-18 on 38et, on Ultraleggeras, front's rubs at full lock and rubbed the fender liner away at the lip. Rears won't apply to you since I'm AWD. I thought about going to 245, I'd have to roll the fenders and couldn't lower my car any more then the TME springs give me.
NEUBAR
#6 theForgottenone
theForgottenone
  • 3,977 posts
Posted 08 February 2012 - 01:26 AM
Cassie ran 235/40/18 on her s70 and it was rubbing crazy.
#7 laird
laird
  • 1,439 posts
Posted 11 February 2012 - 07:40 PM
Not all tires will measure the same. See if you can get the tire specs, ie. section width and tread width, and compare them to some brands and sizes you know.
I had some Sumitomos, 225/35/18 that were quite a bit smaller than the Avon M500 in the same size. Tirerack.com is a good resource but they don't have the Vredesteins.
#8 Johann
  • 4,980 posts
Posted 11 February 2012 - 07:48 PM
Hm.. Ultrac Sucksanta .. 245/40 is way to big for this car.
PS2 much better.
#9 yangotang
yangotang
    yangbang!
  • 6,634 posts
  • Location:San Mateo, Commiefornia, Land of the Smog Nazis, Obamaland.
Posted 11 February 2012 - 09:19 PM
i have nitto neo gen 225/40/18 on peggies with a 10mm spacer and it rubs anywhere close to full lock. i don't feel good about 245...
Alex
#10 dublin14
dublin14
  • 2,716 posts
Posted 12 February 2012 - 02:57 PM
PS2 much better.
I couldnt diagree with you more on that. Anyone I know that has had PS2, Toyo T1Rs ect that went the Vreds likes them better and will never look back. I put a set on my fathers Saab Turbo X and couldnt believe the difference from the Pirreli P Zero`s he had on there. I tried PS2s vs Vreds on a 335i and the Vreds felt better. In the rain the Vreds are brilliant again.
#11 dublin14
dublin14
  • 2,716 posts
Posted 12 February 2012 - 03:56 PM
If the 245s wont work then I cant do much about that. I`ll have to see if someone wants to do a trade for 225s of the same tire or PS2 T1R ect.
#12 tizio
tizio
  • 315 posts
  • Interests:all engines, some cars,space, ho knows
Posted 12 February 2012 - 05:51 PM
Same here, even with fender ben., will rub(rims play also a big part). 18x8 ultrallegeraOZ, 235x40 rub a lot front and rear(eat all the plastic) 225 run great.
#13 trophtaker308
trophtaker308
  • 14 posts
Posted 14 February 2012 - 09:02 PM
i would go with 17s..offset on volvo are 35 but you can go with a 38 and be fine.if you go with a 40 you will need a spacer.
1995 850 turbo,autom gold,(gold package)...more to come!!!
187000 miles,runs strong.
18t turbo,obx exhaust,(ard blue tune),ipd MSD Ignition Coil Upgrade,ipd Short Ram Intake,cams retarded,BOV Upgrade,ipd 8mm performance wires.
#14 dublin14
dublin14
  • 2,716 posts
Posted 15 February 2012 - 01:17 AM
Ive done the Pegs 17s and Im not a fan of the look. I have 225/40/18 Dunlop Sport Max tires on there right now. I just have these 245s also, and if I could use them I would.
