No Spark, Wondering What Are All The Things That Can Cause This Condition.
no spark
13 replies to this topic
#1 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,556 posts
  • Interests:Volvo's, football, and finishing school.
Posted 07 February 2012 - 02:18 AM
My most recent issue is spark. I was driving when all of a sudden there was no spark at all. Went from going 60mph to coasting to the side of the road, man it just died. I have plenty of fuel. and just replaced the cam sensor and I also have a throttle positioning sensor on the way. thinking of going back to stock coil just to double check that. So my question is : Is there any thing else besides the TPS, CPS, and the coil that can cause a no spark issue?
Thanks Again.
1996 850 turbo wagon auto, Custome intake, MSD coil, IPD spark plug wires, Eibach springs, Bilstiens HD, Mesh grill, IPD strut tower bar,ultra racing 2 point rear strut bar, Tiki end-links,IPD intake manifold spacer, FCP silicone inter-cooler hoses, stoptech steel braided brake lines front and rear, completely rebuilt auto tranny, Complete stage zero. soon to have (white injectors, s70 front end, 16t, ARD tune)
#2 Volvo5.0
Volvo5.0
  • 798 posts
  • Interests:Cars,Fishing,Boating
Posted 07 February 2012 - 04:06 AM
Engine Speed (RPM) Sensor
#3 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,556 posts
Posted 07 February 2012 - 04:32 AM
thanks, will look into that also
i9s this what u r referring to?
http://www.ebay.com/...r#ht_954wt_1163
#4 erikv11
erikv11
  • 2,530 posts
Posted 07 February 2012 - 03:12 PM
It is unlikely but for sure a bad ECU can cause no spark.
#5 cn90
cn90
  • 1,339 posts
Posted 07 February 2012 - 03:31 PM
Maybe it is bad MAF (use Bosch only BTW).
Or bad fuel relay (or bad fuel pump).
To get spark from a to z:
1. Key
2. Ignition Switch
3. Crank sensors
4. ? Temp sensor
5. Ignition Coil
6. Spark Plug wires
7. Cap +Rotor
8. Spark Plugs themselves.
There you go, work through these things systematically.
1998 V70 Non-Turbo 100K miles
#6 erikv11
erikv11
  • 2,530 posts
Posted 07 February 2012 - 03:57 PM
That's a nice, ordered list, for the record this is where the other necessary things for spark fit in:
3.5 Cam sensor
4.5 ECU takes info from the various sensors and tells coil to spark
5.5 Coil wire
#7 the commissar!
the commissar!
  • 2,024 posts
  • Interests:interesting things...varies with temperature and altitude
  • Crew:ECC
Posted 07 February 2012 - 04:47 PM
This sounds elementary, but did you double check the wiring to the MSD coil...one loose wire there and you get what you describe...
1998 V70 T-5 -Auto / Pewter - Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
Posted ImagePosted Image
#8 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,556 posts
Posted 07 February 2012 - 06:05 PM
Thanks guys for the info. thats exactly what I was looking for. Double checking my mental list. I am going to start from A to Z on this one. From the fuel side everything is good. I received a new maf yesterday. so we will see where that goes. Also replaced the cam sensor yesterday. I am going back to the stock coil and replacing wires cap rotor etc.I also have a new rpm sensor on the way. This actually got me puzzled this time. So I am going to replace everything that has to do with spark except the ecu.
thanks again for the list.
#9 cn90
cn90
  • 1,339 posts
Posted 07 February 2012 - 07:15 PM
Why do you randomly replace parts?
Have lots of money LOL?
#10 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,556 posts
Posted 07 February 2012 - 09:44 PM
No, I don't have lots of money. I wish lol. the problem arose when i was driving and I usually can tell the problem by how it dies. but this time I was confused. I checked fuel and that was fine. so I replaced the maf since the one I replaced previously was a used unit. still nothing, replaced the coil with one I had bought before new but never used and still nothing. which is why I am going back to stock. I replaced the cam sensor with a known working unit but still nothing. so I ordered a throttle positioning sensor since before when I had another issue I remember I forgot to plug that in and there was no spark. so I am replacing that just in case. I am also going to replace the spark plug wires and cap and rotor just to rule that out also. Hopefully that will fix the problem. I have no codes to go off of. So I am going through it slowly until I get to the problem. I also have checked the grounds since I have had that issue also. Its a b---h and expensive but still cheaper than buying a new used car.
#11 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,556 posts
Posted 19 February 2012 - 04:10 AM
As I laugh at my self, After changing a lot of things that turned out needed changing anyway. I finally figured it out. I actually changed plugs wires, coil wire coil, cam sensor, tps, rpm sensor, and still would not start. So I went back to fuel. last time I checked there was fuel, but when i went back there was none, so i went to the back and pulled the pump. at first glance there was nothing so I took it apart so i can test the pump. when I disassembled it the black wire literally feel out. It broke off from the soldering point. at the top of the case. So I removed the old oem solder and what was left of the wire and soldered a new one in its place. problem fixed. I am a happy man.
#12 erikv11
erikv11
  • 2,530 posts
Posted 19 February 2012 - 07:25 AM
Glad you got it fixed. :tup:
#13 mojojo
mojojo
  • 353 posts
Posted 22 February 2012 - 02:29 AM
So, thinking about this post I found some humor in a few things...
As a mechanic (and following the same diagnostic trouble shooting procedure on everything from a lawn mower, to my Volvo, to any Hayabusa), I start with three simple criteria when trouble shooting any driveability issues, and this was beaten in to my head quite a few years back at a Suzuki technician course, always check the following things:
M - Mechanical If you didn't hear this thing run before it came in, or you had a loud clunk and then no run check (compression/leak down)
I - Ignition Check ignition system, check for spark at the plug, usually a spark gap test can tell you if everything is in good shape
F - Fuel Check for fuel or the absence of fuel (fuel pressure test, at the rail - read: after the filter, closest to injector-s).
In the future, if you trouble shoot these systems, usually a quick (>5 minutes) test can rule out the category, you will find your culprit much quicker, and with less money spent and time wasted replacing parts that don't need to be replaced.
As I was reading your posts, I was anticipating the next issue to pop up because of unrelated repairs.
Good Luck
#14 fastwagonhawaii
fastwagonhawaii
    Oh James!
  • 1,556 posts
Posted 22 February 2012 - 06:04 AM
Usually I am right on these things but not this time. lol My dad popped me upside the head and said the same thing to me as you state in the above post.. ^^^ thanks for the info.
