Questions/opinions... New Engine Parts And Replacing Old Ones.
26 replies to this topic
#1 Jazzy_J
Jazzy_J
  • 265 posts
  • Interests:Musis.
Posted 07 February 2012 - 08:05 PM
On my 98 v70 t5 w/ 112k miles. I will be replacing the throttle body with a 960 and also do both manifolds (new intake and R exhaust). While I was in there and had most of the big parts off I figured it would be a good time to replace the breather system and replace a few seals/gaskets (leaks a little oil). I will also be replacing the plastic intake pipes with silicone.
So besides the things above is there anything else I should consider replacing while I'm in there?
I am under the impression that the previous owner didnt do any maintenance as almost everything I've replaced is factory original and the fluids looked about 20k miles old at least...
This is my daily and I want to get another 150k out of it at least. Here's what I've already replaced...
Ignition system (from coil to plugs, all new. OEM plugs, Bosch cap/rotor, Ipd wires, MSD coil)
Air filter,
Fuel filter,
Fluid changes every 2800 miles,
power stearing fluid was flushed last month,
Tranny flush happening this spring.
Thanks.
#2 volvoskiah
volvoskiah
  • 1,301 posts
Posted 07 February 2012 - 08:38 PM
Definitely do pcv, when was timing belt changed? I would clean everything up and do a complete stage zero. Sounds like you already have a good start though.
98 S70 GLT-M * 79 242 GT * 96 850R * 84 F150 * 99 S70 AWD
72 Chevrolet K10 Cheyenne*78 242 GT*98 S70 T5*00 V70R*04 V70R*96 855R *97 855R*98 V70R*98 V70R*99 V70R*99 V70R*98 V70 NA*98 V70 XC
#3 Jazzy_J
Jazzy_J
  • 265 posts
  • Interests:Musis.
Posted 07 February 2012 - 08:43 PM
Not sure, I already planned on doing the belts...forgot to put that up there.
I also have a spare set of injectors I am going to send off to be cleaned and flowed.
#4 Keaton85
Keaton85
  • 6,439 posts
Posted 07 February 2012 - 10:24 PM
Don't bother! You have better things to spend your money on then injectors.
Why does everyone think injectors are the root of all evil haha. It's almost the last part to even mess with.
#5 Jazzy_J
Jazzy_J
  • 265 posts
  • Interests:Musis.
Posted 07 February 2012 - 11:52 PM
See I agree with you that injectors are usually the last thing to go bad.......but as mentioned above I have no problems, I am just doing maintenance to ensure the vehicles longevity. I just want to be sure that the injectors are flowing evenly, I know that after 100,000 miles they aren't.
#6 Keaton85
Keaton85
  • 6,439 posts
Posted 08 February 2012 - 12:36 AM
How do you know that?
In all of my years of doing this I have never seen one fail or cause even the slightest issue. Fuel is a solvent, just look into your intake ports and where te fuel hits...
#7 erikv11
erikv11
  • 2,530 posts
Posted 08 February 2012 - 02:05 AM
Injectors go bad. The ones on my car never have, to my knowledge, but the indy mechanic in town here has seen more than one white block with burned exhaust valve due to clogged injector and running lean. And no codes.
#8 Keaton85
Keaton85
  • 6,439 posts
Posted 08 February 2012 - 02:18 AM
If you had a clogged injector that was dumping fuel the O2 would pick that up. So I call total BS..
It could happen but it's highly unlikely and even more so at those miles. That's all I have to say, do whatever ya feel all warm and fuzzy inside over haha...
#9 the commissar!
the commissar!
  • 2,024 posts
  • Interests:interesting things...varies with temperature and altitude
  • Crew:ECC
Posted 08 February 2012 - 06:41 PM
I agree that unless you use crappy fuel you should not ordinarily see a problem with fuel injectors. Yes occasionally one will fail but not often.
For a DD just dump some fuel system cleaner in there every now and again and be done with it.
1998 V70 T-5 -Auto / Pewter - Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
Posted ImagePosted Image
#10 erikv11
erikv11
  • 2,530 posts
Posted 08 February 2012 - 07:38 PM
I agree with you guys that failure is rare, I even +1'ed that it sounds like BS that there are no codes. Still, just sayin ...
The mechanic became aware of this several years back when someone brought in a DIY head swap that burned a valve in the same cylinder in the first couple thousand miles after the swap. The injector was clogged, no codes. So now he checks the injectors whenever he sees burned valves. And this guy is good and not prone to BS.
#11 Jazzy_J
Jazzy_J
  • 265 posts
  • Interests:Musis.
Posted 08 February 2012 - 08:16 PM
Is just like to remind everyone that I have no engine problems....I started this thread to make sure I wasnt missing anything that I should check or replace while I was doing my stage 0.
The only reason I am doing injectors Is because i have a spare set, and I just want everything to be cleaned/replaced so it last as long as possible.
#12 GP850T
GP850T
  • 1,468 posts
  • Crew:ECC
Posted 09 February 2012 - 08:20 PM
2 things i noticed, why are u changing fluids so often? 2800 miles? Unnessary, my volvo has 400k KM i put synthetic in there and let it run for 10k kms, 6000 miles easy. Especially if your not beating on the car and its just a daily that seems just to often for me
1994 Volvo 850 Turbo Stage 0 Complete ----swapped 15g for 16T Full 3" Exhaust, MBC, Forge BOV, Red Stylin Kit, Red Stylin Intercooler Kit, 1/4 Time 14.4 @ 98 MPH - WRECKED
1998 Volvo V70 T5-M Custom 3" Turbo Back Exhaust, IPD Springs + Koni Adjustables Yellows, IPD HD Endlinks, MSD Blaster, IPD Stage II tune, 18PSI 262WHP 330 LBS-FT, Custom Foglight Projectors (Bosch H3 Mini projectors) 35w 3000k, R bumper, VDO boost gauge, R interior Swap
#13 Jazzy_J
Jazzy_J
  • 265 posts
  • Interests:Musis.
Posted 10 February 2012 - 12:52 AM
You're right and wrong.
Yes synthetic can run for 10k+ miles. Thats what It was made for...
But, I am not running synthetic. I am running regular oil...which should be changed every 3k-4k....I choose to do mine early because i drive long distance trips monthly. (1k+ miles a trip).
#14 Keaton85
Keaton85
  • 6,439 posts
Posted 10 February 2012 - 12:58 AM
Longger trips means longger OCI..
Even with dino, you can do 4-5k OCIs, no issue.
Doesn't really matter though as your going to do what you feel good ab
Even with dino, you can do 4-5k OCIs, no issue..
Edit: VS really pisses me the f off with no edit..
#15 Deimos
Deimos
  • 605 posts
Posted 10 February 2012 - 01:09 AM
Another one of the paid only features.
Oh, and he said 10k+ kilometers, not miles, only 6k miles.
#16 Keaton85
Keaton85
  • 6,439 posts
Posted 10 February 2012 - 01:16 AM
Yeah but I'm not giving chuck my money..
#17 erikv11
erikv11
  • 2,530 posts
Posted 10 February 2012 - 01:32 AM
You've got it backwards there. Long trips = easy on the oil = change oil at normal intervals or longer. Short trips = change oil earlier.
#18 Deimos
Deimos
  • 605 posts
Posted 11 February 2012 - 07:24 AM
Neither am I. Total waste, especially considering I'm a poor student.
#19 Swag Swag
Swag Swag
    Captain Tow Hook
  • PipPipPipPip
  • 4,479 posts
  • Crew:SWC
Posted 11 February 2012 - 07:37 AM
I hope you take that back when you need help/info and VS helps you out. If nobody supported, VS wouldn't exist, defiantly not a "Total waste"
Spence—855 T5-R W/RN Swap—NWC
http://www.seshday.com/invite/?r=43707
#20 Deimos
Deimos
  • 605 posts
Posted 11 February 2012 - 08:22 AM
He's already said that the site is self supporting on ad revenue. The memberships are on top of what is needed to keep the site going. So... congrats on being wrong.
