Posted 08 February 2012 - 03:17 AM
2001 S60 T5
Auto trans
Solid body no rust fla car
Engine has 150,000 on the clock.
Posted 08 February 2012 - 03:37 AM
do you have any hp goals?
if it was me, some struts/springs and sway bars will help it handle miles better than stock.
a fmic, k24 turbo, bigger injectors, turboback exhaust, and a tune would make a pretty responsive fun setup.
my .02 cents
JVC, on 13 March 2012 - 05:56 AM, said:
Posted 08 February 2012 - 03:50 AM
Posted 08 February 2012 - 05:11 AM
Posted 08 February 2012 - 06:10 AM
Jardim, on 08 February 2012 - 05:11 AM, said:
+1 very good point, trans cooler would be a worth while preventative upgrade
Posted 08 February 2012 - 08:09 AM
1. sway bars - iPD is too soft for the rear, Evolve adjustable bar is far better. I started with iPD bars, but never installed the front, only the rear. Roll distribution was much nicer, but I knew it would be too heavily aimed at understeer if I went to the front bar. Sold my rear bar to S80 owner, and got the Evolve. Bitch to install, they told me they've had 3 S60's with install problems. Apparently for some, you have to make shorter links for the sway bar links. I've got TKi, but even they need to be shortened a bit. Had to grind a lip off the lower control arms to avoid interference, but with shorter links, likely wouldn't have been needed. Massive difference. You still want more roll resistance in the rear than iPD gives you, and the Evolve set might even be better, both bars are adjustable, and that helps on the AutoX.
2. Strut bars - you need the Ultra bars from VIVA. Upper front, upper rear is not as noticeable, but still helps. I thought the upper front was the best, until I bought the lower front brace. WOW. Lucky from ARDideas drove the car, and he says it is the first P2 car (S60/V70/S80) that he has driven that has instant steering response. Before, you turn wheel, wait an instant or two, and then the car starts to follow. Now, turn wheel and car turns, just like that. I am seriously considering getting the only remaining bar left, the lower rear brace. I suspect it will help the rear end. Disadvantage: When you hit a sudden bump in road, the lower front bar prevents the subframe from moving backwards slightly to cushion the shock, so you feel it, but cornering is fabulous.
3. be sure your strut mounts and entire front suspension bushings, ball joints, etc are in top shape, any slop there ruins your work.
4. Can't comment on springs, kept stock T5 springs, they work fine for street, obviously want to get lower for AutoX. PM Lucky to see what he recommends for springs.
5. Trans cooler - probably a must item.
6. Oil cooler, I've got an article to show how to add a gauge for oil temp and that may be necessary. Likely not, AutoX is too short to really bring up temps on engine. If necessary, get dealer to sell the oil cooler for a D5 diesel, it has more cooling plates in it, and is probably about 1/2 inch thicker, thus more cooling without having to add extra plumbing, etc.
7. Oil pressure. I've not heard of anyone having problems with oil pressure on these engines, but to avoid it, start by replacing the O-rings between the pan and intermediate carrier, as well as on the oil pickup tube, because the o-rings can start to crack and let in air as they age from heat, and you don't want air bubbles in your oil as it goes through your bearings. Fast way to throw a rod. I"ve done it racing in a red block, not something I want to ever do again. Much expensive, usually new block, crank and rods, and perhaps some pistons for a start, and that's if you don't have a piston hit any valves. If you are worried, get an Accusump, which is simply an oil resevoir, used it in racing, kept several engines in one piece when I didn't have the oil drainback worked out properly, because as oil pressure drops, it shoots more oil into the engine. Just need a one way valve to keep oil going into engine, not backwards into pan.
1997 854 GLT NA Manual 192K - son; 1995 854 NA Auto 240K - daughter
Posted 08 February 2012 - 08:46 AM
Posted 08 February 2012 - 10:34 PM
Jardim, on 08 February 2012 - 08:46 AM, said:
'05 xc/90. The stereo sucks.
"Crowded elevators smell different to midgets"
Posted 09 February 2012 - 12:26 AM
I seen EGT's around 1400-1800 degrees so he could of been right...Idk
Posted 09 February 2012 - 12:58 AM
I was mostly just being sarcastic anyway
Posted 09 February 2012 - 02:16 AM
Lol your always being sarcastic. But yeah that's what i meant, Dry sump would keep the oil away from that crazyness.
There was a Mercedez back in the 50's or 60's that came factory with a Dry sump setup, people who drove it stated that it was rather unecesary because the oil wouldnt even reach operating temp
Posted 10 February 2012 - 02:05 AM
Also tagged with s60, racing, track
Announcements →
Show Room →
O2012 S60 T5Started by oprahhwinfreyy, 20 May 2012 |
Modifications →
Performance Modifications →
2008 S60 2.5T Turbo Upgrade For NoobStarted by Dbrunetti6770, 16 May 2012 |
Regional Forums →
Regions →
North West Region (NWC) →
May 27 Novice Autox SchoolStarted by herz3mc, 03 May 2012 |
Announcements →
Member Announcements →
Volvo's @ Sebring International Raceway 2012 Feb11-12Started by RobT5., 09 Jan 2012 |
Regional Forums →
Regions →
2012 Racing ScheduleStarted by herz3mc, 07 Jan 2012 |
