please delete, on 08 February 2012 - 08:27 PM, said:
XC90 springs seats
Bearing plates
bump stops
the round metal piece for the bump stops
bellows
word of caution with this combo, be careful going into corners and hitting any kind of bump.
I am looking at FCP site, and what are the bearing plates that you talk about?
I can find the bump stop and washer, but I don't know which one is bearing plates.
Thank you.
please delete, on 08 February 2012 - 08:36 PM, said:
Compress the front springs! Don't just take it apart. Also you shouldn't need to compress the new springs since they are smaller and can be installed with compressing.
You can also use the weight of the vehicle to decompress the stock springs. Only on the 94-00 since the 01+ models have different control arms.
Thank you for the tip.
I will rent spring compress tool from autozone.
Last time when I replace Saab front shocks, I couldn't unbolt the top nut so I had to take them to a shop to do it.
A mechanic used an air tool to unbolt it.
Is Volvo the same thing?
What year of XC90? 2003?
Thank you.
