Wheel Spacers
#1 WayAway
WayAway
  • 1,174 posts
  • Interests:Bewst, Beer, Women, Towers
Posted 08 February 2012 - 11:02 PM
Im looking on some info on wheel spacers. I have 18" peggs on my 98 V70R and its lowered. My inner parts of the tires are getting destroyed. For the rear i have 10mm spacers but there still rubbing on the inner fender liner nuts (which im totally removing) All four fenders are getting rolled but it seems like i need maybe 15mm in the rear and 10mm up fronts.
My question is were can i get decent spacers (15mm) and will I need longer bolts
Also, has anyone had issues with thins on a V70R?
96 854R Black IPDStage III, Winter (M56, 99T5 motor, 18T) 19psi, Whites, OBX, Eibach springs, SSQV, Exhaust Cutout, Aem UGO, 17" Peggs etc...
98 V70R Saffon AWD, RICA 18psi tune, Sconeman intake pipe, Mufflers Delete,IPD springs, CX Racing FMIC, Hillman MBC @ 18psi, VR Charcoal Swap, Cai, HKS SSQV, Projectors, 18" Peggs
#2 JVC
  • 7,604 posts
Posted 08 February 2012 - 11:40 PM
http://www.motorspor...apters_pop.html
or you can find the H&R ones then order longer bolts
http://www.ebay.com/...#ht_2507wt_1185
You will definitely need longer bolts if you go with the H&R, if you contact Motorsports Tech/Adaptec Speedware they can do bolt on ones that will come with smaller bolts to bolt the adapter to your hub then use your stock bolts to thread into the spacer. Or you can have them make slip on ones and supply you with longer wheel bolts.
OR You could convert to wheel studs and then just buy the H&R spacers.
There are many options.
-John
#3 Matt_
Matt_
  • 544 posts
Posted 08 February 2012 - 11:46 PM
I just picked up 15mm spacers and extended bolts from iPd about a month or so ago. Total price was 127.50 shipped.
Yes, you'll need the longer bolts.
Spacer P/N 112726
Extended bolt P/N 112835
2005 S60R Ti Grey/Gobi/6M/18"Black Pegs
1997 854R Black/Charcoal/5M/ARD M4.4 BLUE/Dark Bronze Volans/Daily Driver
2005 S40 T5 FWDhttp://www.cardomain.com/ride/2938966 SOLD/MISSED
#4 NEU
NEU
    Old Man Crew Photographer
  • 2,982 posts
Posted 09 February 2012 - 02:17 AM
What is your offset? I'm at running 235/40-18 on 38et and they rubbed bad at full lock and on the fender lip front and rear, but they worn through and it's not an issue any longer.
NEUBAR
