95 850-T Auto Transmission Gone Or Almost Gone - Advise?
Posted 11 February 2012 - 05:14 PM
Long time since I've been on the boards. Started my car up on Sunday night after the superbowl and backed out of my space. Put it in drive and noticed a significant lack of power/felt something wrong/and noticed what felt like gear slipping. Turned down the radio, got to a stop sign went to go again and just started hearing all kinds of bad noises with grinding and what sounded like the transmission continuously falling to the ground. Once the car got outta first everything was fine, but in first gear it was a struggle to even get moving and get to second. Just made it home that night after having to stop 3 more times at red lights so the car is at my apartment in Wilmington, DE.
Transmissions are one thing I know nothing about other then watching chillman change one out one time.
Is it possible to fix just first gear in the tranny or does the entire transmission need replaced?
Also does anyone know of anyone or anyplaces near Wilmington, DE where I could get one and or a good place to get it repaired or replaced?
If it turns out that its too expensive to get it fixed I'll probably end up parting out the car to anyone who needs anything from it but i'll wait till that happens before I start selling anything.
Zach
Pennsylvania
1995 850 Turbo Sedan
Posted 11 February 2012 - 05:44 PM
i just had mine go out at 125,000 miles, a little early, but the trans had a bad first owner. (Bad!)
mine shifted hard for years, and then made a groaning noise for about 1 1/2 years.
Final outage was trouble shifting, and strange noises.
Found a used one with lowish mileage for $300, had someone put it in, car runs fine now.
I would first do a complete flush (through the outlet cooler hose). That could either fix it, or give it a few extra miles.
1997 Volvo 850 R sedan - 124K miles
Posted 11 February 2012 - 07:43 PM
Pennsylvania
Posted 11 February 2012 - 09:15 PM
if it doesn't help, or makes it worse, then your tranmission is probably done.
Posted 12 February 2012 - 05:09 PM
Posted 12 February 2012 - 05:44 PM
98 S70 T5 M56H,R clutch,manifold , 04 RN engine, Black on black,Koni+Ipd Black, IPD Sways, OZ racing 18X8,282K, 00'V70R silver/black STOCK for now. 99' C70 Vert., 02' S60 AWD.
Posted 15 February 2012 - 06:59 PM
Hello All, Long time since I've been on the boards. Started my car up on Sunday night after the superbowl and backed out of my space. Put it in drive and noticed a significant lack of power/felt something wrong/and noticed what felt like gear slipping. Turned down the radio, got to a stop sign went to go again and just started hearing all kinds of bad noises with grinding and what sounded like the transmission continuously falling to the ground. Once the car got outta first everything was fine, but in first gear it was a struggle to even get moving and get to second. Just made it home that night after having to stop 3 more times at red lights so the car is at my apartment in Wilmington, DE. Transmissions are one thing I know nothing about other then watching chillman change one out one time. Is it possible to fix just first gear in the tranny or does the entire transmission need replaced? Also does anyone know of anyone or anyplaces near Wilmington, DE where I could get one and or a good place to get it repaired or replaced? If it turns out that its too expensive to get it fixed I'll probably end up parting out the car to anyone who needs anything from it but i'll wait till that happens before I start selling anything. Thanks Zach
I have a buddy who is parting out a 98 XC70, you could get the tranny relatively cheap from him. Pm sent.
