5W20 Synthetic For Gas Mileage ?
Posted 17 February 2012 - 01:54 PM
If i did run a 5W20 I would run Redline Synthetic.
Posted 17 February 2012 - 02:06 PM
Driving technique will net you the biggest mileage gain.
Posted 17 February 2012 - 03:23 PM
and average @17MPG running mainly 93 octane Chevron - sometimes I will top off with a 1/2 tank of 89 octane Chevron. I average a mininum of 20K miles a year
on my car.
Posted 17 February 2012 - 04:02 PM
Pushing 10k intervals on 10W20, are you planning on conducting sample analysis? Otherwise, I'd think you're just taking an arbitrary gamble.
I agree that removing that lead foot is undoubtedly your most cost effective and safest fix. If you do a lot of highway driving, maybe run 2psi higher tire pressure and pay attention to the wear on your tires.
This all reminds me of overweight people who have a low-cal meal every fifth Sunday, so that they can feel like they are making progress. But they are turning a blind eye to the 3k calorie dinners they have every night. I crazy?
Edited by Fudge_Brownie, 17 February 2012 - 05:38 PM.
Editted my mistake of .05 difference to .10
86 Kawasaki Gpz900R Ninja
Posted 17 February 2012 - 04:14 PM
My Haynes UK manual recommends 9K oil change intervals for the S60. I definitely don't think 10K is a stretch if you are running a TRUE synthetic engine oil especially on an OEM filter which is what I use.
The oil would be changed a minimum every 6 months based on my rate of mileage accumulation.
Posted 17 February 2012 - 04:19 PM
Does Haynes tell your to drive like
10k miles or km?
With a 10k mile interval I would do 2 filter changes in there.
Volvospeed On Google+
Posted 17 February 2012 - 04:20 PM
Posted 17 February 2012 - 05:07 PM
Regardless the main focus in runnning 5W20 weight - I am curious if anyone is running it ? Otherwise you can stay out the conversation.
Posted 17 February 2012 - 05:12 PM
@Che - Volvo US owner's manual states 7500 mile oil change intervals and warns you that is WITHOUT Synthetic oil unless you pay extra for it. What proof do you have you need to change your filter every 3-4K miles - waste of time and money if you are running a true synthetic oil and this been proven time and time again by used oil analysis on BITOG.
One BTOG is about as trust worthy as wikipedia, but that aside what does chemical composition of oil have to do with the oil filter? I can pour a cup of sand in the pan and trash a brand new filter. Its a filter not a conditioner. The oil would still be fine but the oil filter would be shot and in bypass. As for 20 weight oil I have run it on several occasions. Usually to qualify or dyno. Its is way too light for sustained use in a turbo vehicle.
Posted 17 February 2012 - 05:33 PM
It really seems like you are nickle-and-diming. 89 octane is a waste. Ever do the math on what that is actually saving you? 20,000 miles @ 17mpg @ .05cent savings per gallon -> $58/year. And that's assuming you fill EVERY tank with 89 instead of 93. At 'occasional fills', its much less. Note that I kept 17mpg static, so if you are able to gain mpg on the 89, you increase your savings minorly.
5 cent difference between 93 and 89??? Not where I live. There's generally a 10 cent difference between the three grades:
87 = $3.39
89 = $3.49
93 = $3.59
So there would be a 20 cent difference between regular, medium and premium. That changes it from $58 to $116 a year in gas cost between 89 and 91 (we get 93). That's $10 a month more. Though I run 87 in the NA so for me it's a $20 a month difference.
1998 C70 HPT M modified S70 T5A Emerald Green on Tan
Posted 17 February 2012 - 05:37 PM
I read perfectly fine.@Fudgie_Brown - obviously you dont read too well, I said I occassionally (actually rarely) top off a HALF a tank with 89 octane which - 89+93 averages 91 octane which is Volvo's octane recommendation. My Haynes UK manual recommends.
You are reading a Haynes UK manual, are you based in the UK, or US? You've opted not to fill out your location in your profile, so no one is aware if you are in the UK.. At 'occasional fills', its much less.
I can say, based on my time spent here, I don't think many are runnning 10W-20. Let's hypothetically say we have someone here who can tell you they gained 2mpg by switching.... but they've only driven 10,000 miles on 10W-20. The damage being done may not be evident yet. That is why I am asking if you will be conducting oil analysis on your fills. I think with that, you will obtain the best information. Try it, sample at 3k miles, and base your decisions on the data.
You're correct, my mistake. Will edit post accordingly.5 cent difference between 93 and 89??? Not where I live. There's generally a 10 cent difference between the three grades:
Posted 17 February 2012 - 06:00 PM
#14
Posted 17 February 2012 - 07:32 PM
87 = $3.39
89 = $3.49
93 = $3.59
Even more than that here in DC
1998 S70T5M, 2000 Built B5244T2 RN Engine, K24 turbo, 550cc injectors, Turbo-Tuner, Coolingmist Progressive WMI, Precision FMIC, 311whp 363wtrq
#15
Posted 18 February 2012 - 02:42 AM
187000 miles,runs strong.
18t turbo,obx exhaust,(ard blue tune),ipd MSD Ignition Coil Upgrade,ipd Short Ram Intake,cams retarded,BOV Upgrade,ipd 8mm performance wires.
#16
Posted 18 February 2012 - 03:22 AM
so is the 5w-30 to light for a turbo vehicle.i live in ky and like to use the light weight in the cold months,then switch to 10-20or10-30 in the summer....so many decisions>>????
Good discussion - http://v70r.com/foru...ormula-no-more/
#17
Posted 18 February 2012 - 09:59 PM
Here in CT $3.89 is the lowest in my area, I saw $4.09 on the merritt for regular today... Awful high.
2001 C70 T5m (OBX, HDs, B&Gs, Bi-Xenons, iPd intake, Snabb pipe, OEM strut bar)
Projects: 2002 C70 HPT coupe, 2001 V70 T5m, 1998 S70 T5m
#18
Posted 18 February 2012 - 10:32 PM
#19
Posted 19 February 2012 - 12:40 PM
Still have my fingers crossed for 10 dollars a gallon.
Right? Same here....can't friggin wait. We can't even fill the tank on our express trucks at work because the pumps stop us at $75 and sometimes $100.
The name's Ben: '95 850, m56 w/ gripper lsd, Sachs 707 pressure plate w/ organic disc, built '02 RN 2.3L, worked '04 R head, Enem Y21 cams, Precision 5857B, ARD tune, blah blah blah
#20
Posted 19 February 2012 - 03:45 PM
I think you should take up a hobby or something if this is what you have time for. Just run 5-30 and call it a day. You're trying to squeeze orange juice out of apples dude...volvos, especially awd volvos, don't get phenominal mpg...but 17/avg seems a bit low as it is.
I filled my truck last week and my stations had no problem letting me pump 340 dollars in fuel. 75 cut off really? That would piss me off if I were filling 300 gallons.
