#81
Posted 06 March 2012 - 02:52 PM
#82
Posted 06 March 2012 - 05:37 PM
H, keep in mind the turbo is baxkwarda on my setup in order for the exhaust to face the correct direction. I wouldnt be the right buyer for that header, i can make my own for less than what you could sell that thing for
An for now im happy to run the shitty stock manifold with the adapter.
#83
Posted 06 March 2012 - 06:29 PM
#85
Posted 06 March 2012 - 08:14 PM
Andrij, just search ebay, not sure if you can fit one though.
#86
Posted 06 March 2012 - 08:49 PM
Posted 06 March 2012 - 08:53 PM
#88
Posted 06 March 2012 - 09:46 PM
-Kevin-
2004 V70R: 3 angle valve job, Phuzzy FMIC, IPD Neutral rear sway
White '96 850 T5M:Black '94 850 T5
#89
Posted 06 March 2012 - 10:01 PM
PM sent.ooooo pics, specs? they would look gorgeous on my car
Posted 07 March 2012 - 02:29 AM
scott clark may want to sell his cosworth inconel header for this project.... let me know if you want his contact info.
Pm me, if the price is right i might consider it
#91
Posted 12 March 2012 - 05:02 AM
Ordering intercooler and exhaust parts right now, ordered oil filter relocation stuff and a bunch of vdo gauges. Flywheel is at the machine shop right now getting redrilled.
#92
Posted 12 March 2012 - 12:41 PM
#93
Posted 13 March 2012 - 05:39 AM
^ Good Work! Definitely better off with the ME7 turbo manifold than -98 version with that turbo
even better with a custom manifold...i dont have much of a choice now, found out the master cylinder is in the way. oh well, just another road block for the best.
btw thanks for the quick reply to my text today H, wanted to grab bolts at my lunch break but had no idea what they were, you were correct m10x1.5 =]
So today, i got a suprise at work, couldnt believe it but sure enough...my adapter plate! from sweden in 7 days, not bad!
Quality looked great and tolerences were also quite nice i found after installing it.
need to get some more bolts at lunch tommorow for the adapter plate but for now it is bolted on sturdy enough for mock up.
woooohoooo!
We heard you liked vert mounted whiteblocks so we put one in your e30
It closes!
So that is the final position of the motor, exactly, the height is perfect, the hood closes, its perfectly centered, the rear transmission crossmember is bolted up.
I need to extend the driveshaft and shift linkages about 6 inches, the driveshaft angle will be less harsh than stock, so im happy.
The intake manifold does not fit unfortantly, when i mocked up the motor originally it was not centered so i thought it would fit but....nope. The master cylinder and booster are in the way, so i will be installing an e21(smaller) booster and moving the booster over a couple inches to give me some more clearance but i still dont think that will be enough room for the stock manifold so i will most likely be building a manifold, but even then, space is very tight, we'll see.
Edited by mdlimy, 13 March 2012 - 05:41 AM.
#94
Posted 13 March 2012 - 05:56 AM
#95
Posted 13 March 2012 - 06:05 AM
thanks bud, i try
#96
Posted 13 March 2012 - 06:35 AM
QFT =]
thanks bud, i try
This is going to be so awesome... my friend is just starting his S52 swap in the next week or so on his 2 door white E30. Should be a nice match!
#97
Posted 13 March 2012 - 11:23 AM
#98
Posted 13 March 2012 - 12:50 PM
What will the new oil pan hold (oil volume) ? Same amount as before, or less ?
#99
Posted 13 March 2012 - 01:40 PM
Good work , keep it up !!!
Dyno.
Runs like a champ , finally
PM me if you need any volvo parts
#100
Posted 13 March 2012 - 04:51 PM
Not sure how much the oil pan will hold, im shooting for 6qt.
