98 Lpt Going 15G. A Few Questions.
12 replies to this topic
#1 VTawdR
VTawdR
  • 67 posts
Posted 18 February 2012 - 10:34 PM
Hey all. I've searched for answers but still have a few questions.
Tomorrow I'm installing a 15g. I own a 98 lpt, it has R ecu, exhaust, intake and stage 0.
Questions are:
I would like to run about 15psi, I realize that's close to the 15gs limit, but am I going to run into fuel cut before that? (I do have an R ecu)
Secondly, about how much more power can i expect from this swap? I read around 270-300 tops. But any idea on a stock R ecu?
Thanks everyone.
#2 Jardim
Posted 18 February 2012 - 10:56 PM
Ok, given its a 98 R ecu with the 15G and the slightly higher compression ratio your going to be around 250-260
If your running all of the above plus an MBC to acheive the 15psi you want then id say around 285 hp.
These are just rough guesses. could be more or less depending on the condition of the car.
#3 VTawdR
VTawdR
  • 67 posts
Posted 18 February 2012 - 11:22 PM
So by running a mbc I will avoid fuel cut?
#4 Jardim
Posted 19 February 2012 - 04:03 AM
I think there is a fuel cut at 14 PSI.
Get a LPT tune from lucky, you can run 15 PSI safely without having the risk of boost coming in too early.
#5 VTawdR
VTawdR
  • 67 posts
Posted 20 February 2012 - 04:00 AM
Well the 15g is in. And I'm front wheel drive lol. Went fairly smooth. Tight spaces for huge parts, but its in. next is a manual boost controller as I'm topping out at 10psi. But what a difference. Whole new car.
Thanks for the tips.
#6 -Matt01
-Matt01
  • 451 posts
Posted 20 February 2012 - 04:12 AM
16T is the same housing and same straight angle flange it will bolt right in place of your LPT 13G, maybe consider it so you wont have to modify your downpipe if you decide to go with a angled flange 15G.
Same with the AWD... if you don't actually own one, or never have, or plan to do so, then shut your pie hole.
#7 VTawdR
VTawdR
  • 67 posts
Posted 20 February 2012 - 04:29 AM
I put in a straight flange 15g.
#8 Keaton85
Keaton85
  • 7,500 posts
Posted 20 February 2012 - 04:38 AM
There were never any angled flanged 15G turbos....
#9 -Matt01
-Matt01
  • 451 posts
Posted 21 February 2012 - 11:21 PM
"The difference in turbine housings:
There are 3 turbine housing designs (with two variations having been seen internally in the angle-outlet housing, but we will ignore that for now!). Conical outlet flange (94-95 850 turbo, 95 850 T5-R), straight outlet flange (96-97 850 R, T5 and GLT, 98 model S70 R, T5, And GLT), and angled outlet flange (All cars 99+ excluding the newer cars with KKK turbos)."
http://forums.turbob...hp/t-10961.html
#10 volvoskiah
volvoskiah
  • 1,732 posts
Posted 21 February 2012 - 11:26 PM
Just for shits and giggles, I got 250whp and 328tq on a 19t with an ipd stage2 @ 19psi
79 242 GT*84 F150*96 854R*98 S70 GLT-M*98 V70 AWD*00 V70R
72Chevy K10 Cheyenne*78 242 GT*89 740 TIC*96 855R *97 855R*98 V70 NA*98 V70 XC*98 S70 T5
98 C70 T5m*98 V70R*98 V70R*99 S70 AWD*99 V70R*99 V70R*00 V70R*00 V70 XC*04 V70R
#11 JVC
  • 9,219 posts
Posted 22 February 2012 - 01:37 AM
Pulling horsepower numbers out of your ass is not the right way to give suggestions.
#12 Jardim
Posted 22 February 2012 - 05:28 AM
#13 JVC
  • 9,219 posts
Posted 22 February 2012 - 05:42 AM
If that's the game we're playing...
OP, you're probably looking at an increase anywhere from 2-400 horsepower which brings your total to anywhere from 150 to 746 horsepower depending on how much you had previously.
