98 Lpt Going 15G. A Few Questions.
#1
Posted 18 February 2012 - 10:34 PM
Tomorrow I'm installing a 15g. I own a 98 lpt, it has R ecu, exhaust, intake and stage 0.
Questions are:
I would like to run about 15psi, I realize that's close to the 15gs limit, but am I going to run into fuel cut before that? (I do have an R ecu)
Secondly, about how much more power can i expect from this swap? I read around 270-300 tops. But any idea on a stock R ecu?
Thanks everyone.
#2
Posted 18 February 2012 - 10:56 PM
If your running all of the above plus an MBC to acheive the 15psi you want then id say around 285 hp.
These are just rough guesses. could be more or less depending on the condition of the car.
#3
Posted 18 February 2012 - 11:22 PM
#4
Posted 19 February 2012 - 04:03 AM
\So by running a mbc I will avoid fuel cut?
I think there is a fuel cut at 14 PSI.
Get a LPT tune from lucky, you can run 15 PSI safely without having the risk of boost coming in too early.
#5
Posted 20 February 2012 - 04:00 AM
Thanks for the tips.
#6
Posted 20 February 2012 - 04:12 AM
Same with the AWD... if you don't actually own one, or never have, or plan to do so, then shut your pie hole.
#7
Posted 20 February 2012 - 04:29 AM
#8
Posted 20 February 2012 - 04:38 AM
#9
Posted 21 February 2012 - 11:21 PM
There are 3 turbine housing designs (with two variations having been seen internally in the angle-outlet housing, but we will ignore that for now!). Conical outlet flange (94-95 850 turbo, 95 850 T5-R), straight outlet flange (96-97 850 R, T5 and GLT, 98 model S70 R, T5, And GLT), and angled outlet flange (All cars 99+ excluding the newer cars with KKK turbos)."
http://forums.turbob...hp/t-10961.html
#10
Posted 21 February 2012 - 11:26 PM
79 242 GT*84 F150*96 854R*98 S70 GLT-M*98 V70 AWD*00 V70R
72Chevy K10 Cheyenne*78 242 GT*89 740 TIC*96 855R *97 855R*98 V70 NA*98 V70 XC*98 S70 T5
98 C70 T5m*98 V70R*98 V70R*99 S70 AWD*99 V70R*99 V70R*00 V70R*00 V70 XC*04 V70R
#11
Posted 22 February 2012 - 01:37 AM
Ok, given its a 98 R ecu with the 15G and the slightly higher compression ratio your going to be around 250-260
Pulling horsepower numbers out of your ass is not the right way to give suggestions.
#12
Posted 22 February 2012 - 05:28 AM
#13
Posted 22 February 2012 - 05:42 AM
OP, you're probably looking at an increase anywhere from 2-400 horsepower which brings your total to anywhere from 150 to 746 horsepower depending on how much you had previously.
