Longgest Timing Belt Run Ever!
24 replies to this topic
#1 Keaton85
Keaton85
  • 7,487 posts
Posted 22 February 2012 - 02:19 AM
Im riding in an 05 V70 N/A with 187k on the original TB!!!
Insane, anyone else have one longger?
#2 tchnprgrmr
tchnprgrmr
  • 254 posts
Posted 22 February 2012 - 02:40 AM
yup, as far as I know my belt was stock when I replaced it at 193k (bought at 189k).
the idler pulley moved and the belt tore a hole in the side cover(didn't fall off thankfully, but moved a good 1/2 way off)
had it "fixed", drove 250 miles to South Carolina, checked it and the belt had moved again, drove it all the way back to Jacksonville with the belt 1/2 way off and got it redone the correct way
luck was on my side that weekend, belt hasn't moved in the 40k miles since then
1999 C70 2.4 LPT Convertible
19T, 0.5 bar actuator, 3" turbo back exhaust, InMotion tune, SRT4 fmic with 2.5" hot-side piping 3" cold-side, ME7 NA intake manifold, big green injectors, ebay pull-type BOV, japanifold exhaust, EBC, weitec lowering springs, no cat, single dual outlet muffler, e-code headlights, dual transmission coolers, polyurethane mounts, front strut bar, XC front bumper, Innovate wideband
#3 Keaton85
Keaton85
  • 7,487 posts
Posted 22 February 2012 - 02:44 AM
Nice! I had to swap my idler at 140k ob my T5 i picked up recently. They replaced the TB and tensioner but not the idler. It was unhappy!
#4 Ihatespeedbumps
Ihatespeedbumps
    The Pied Piper
  • 3,895 posts
Posted 22 February 2012 - 04:05 AM
142k on a customer car is my record, nice save.
#5 Keaton85
Keaton85
  • 7,487 posts
Posted 22 February 2012 - 04:31 AM
Im still working in trying to have the owner save this one but he doesnt care haha. I told him i will buy it when it goes...
No bearing noise though!
#6 Matty Moo
Matty Moo
  • 1,915 posts
Posted 22 February 2012 - 05:13 AM
145k on my MIL's s70. I'm replacing all of that and the entire front end this weekend.
#7 JRL
JRL
  • 571 posts
Posted 22 February 2012 - 07:35 PM
I bought one with 150K on it, it was ready to fall off.
I don't understand how an owner can not do a T-belt at the proper interval and risk losing their engine
#8 cbpldc
cbpldc
  • 69 posts
Posted 23 February 2012 - 03:10 PM
Wow. That is frightening. He could get many more years of faithful service out of it were he to only replace the timing belt. Some people just don't get it.
96 850R (rescued from the junkyard)
94 940 Wagon
99 V70XC
#9 KevinR
KevinR
  • 2 posts
Posted 23 February 2012 - 07:07 PM
I'm not brave enough to find out how long one can go. Whenever I look at a used Volvo (and many other cars, for that matter) my first question is: have you replaced the timing belt and can you produce documentation of it? Otherwise, I just assume it needs replacement and move on accordingly.
My wife's '04 C70 LT currently has 73k on the original belt. I'm probably going to take care of that one soon.
#10 Keaton85
Keaton85
  • 7,487 posts
Posted 23 February 2012 - 07:34 PM
73k is still young though, 105K is the norm.
#11 andyb5
  • 3,186 posts
Posted 23 February 2012 - 08:47 PM
I'd replace the original belt on any of these cars, even if it has "miles left" according to the service interval. As the belt ages, it can begin to deteriorate despite low miles.
A previous owner of my 99 R had the T-belt changed in 02 @ ~80k on it, and it was starting to fray when I bought it in Dec. @ 149k, so I replaced it right away.
#12 Keaton85
Keaton85
  • 7,487 posts
Posted 23 February 2012 - 08:50 PM
There has never been a report of a belt failing ever on here. Only tensioner and idler failures...
#13 sjmcarz
sjmcarz
  • 187 posts
Posted 23 February 2012 - 10:16 PM
IMO, 80,000 miles should be the max for replacement of belt and related components.
2001 V70 XC, 44,000 miles, Black/Beige, Wifes wheels
2000 S70 ASR N/A, 184,000 miles, Silver/Graphite, Daughters wheels, Xemodex, Rear spoiler,
2000 V70R, 110,000 miles, Emerald(Olive) Green/Graphite, Sons wheels, Father and son project car. 2002 2.4LPT, 19T, Greens. Delco BCS, VDO boost gauge
My wheels: Changes almost daily but usually a Volvo of some sort
#14 andyb5
  • 3,186 posts
Tell that to the cracks and frayed cords in the timing belt I replaced. Not saying it is guaranteed to happen, but its something to keep in mind with an old, low mileage belt.
#15 Keaton85
Keaton85
  • 7,487 posts
Posted 23 February 2012 - 10:24 PM
On what grounds?
#16 Burn-E
  • 9,267 posts
Posted 23 February 2012 - 10:54 PM
The statement for service is mileage / number of years. So replacing the belt and components before you hit the milestone (70k or 105k) if the car is past the age (7 years) is an appropriate action. And it's been demonstrated elsewhere that Volvo changed the interval to 105k miles not because the parts were superior but because they realized they could and thereby reduce the overall cost of ownership during the first 100k miles which is one of the metrics reviewers look at.
I experienced a failure at 138k miles, the tensioner failed but it goes to show that some percentage of cars will experience a failure prior to the milestone. Everyone says swap out the tensioner, pulleys, and water pump every second change but my experience shows that may be running on borrowed time.
#17 scumcity14
scumcity14
  • 4,804 posts
Posted 24 February 2012 - 12:58 AM
My T5 had a sticker that said it had been done at 82k ( the car had 214k on it when I bought it) who knows if had been done a second time...my XC90 is at 115k..it will get done next month though.."fingers crossed" (also needs cam seals, crank seal, water pump etc..)
#18 Keaton85
Keaton85
  • 7,487 posts
Posted 24 February 2012 - 02:56 AM
All my failures have been around 130-135K miles on the tensioner pulley. Belts were fine and still a major PITA to cut off, also I've never seen a show idler as of yet. Although like I said earlier my current V70 had the TB done but they didn't replace the idler, which I just replaced since my wife and I are on a road trip. The idler at 140K miles was still ok but needed to be changed out. You don't even need to take the timing belt off, just swap the idler while holding the belt over, works perfect and takes about 10mins.
As for age, I don't go by age, just miles. Personal preference, I guess as my experience has shown me it's more about miles and bearing condition then anything else. Also, I don't really care if I have to do a head job as it's nice to get the top ends cleaned up and new valve stem seals installed.
#19 volvos70turbo99
volvos70turbo99
    Mrs. Brightside
  • 212 posts
Posted 24 February 2012 - 06:53 AM
I've heard the hydraulic tensioners are a lot more reliable than the mechanical ones, maybe so, mine was still going, it may have been the original at 168k, unless it was changed at 76k still thats 92k miles on the tensioner itself. Mine never made any noise either.
1998 s70 glt t5 converted - 16t, white injectors, nxs mbc @ 14psi, k&n drop in filter, high flow cat, full 3in. exhaust, dp, hd wg, na tb, ipd turbo hoses, ard orange tune, stage 0 complete
#20 98t5M
98t5M
  • 544 posts
Posted 24 February 2012 - 07:11 AM
Mine was changed by the P.O at like 73000 mi.
Then when I had my valve stem seals replaced at 110K (iirc) the idler pulley bearing was about to fall apart. I had all the timing components except water pump replaced at this time.
5-10K miles later the water pump started leaking. LOL
So in my experience ALL of the components should be replaced at every interval (which is 70K on the 98 and older cars.) Or at very least the water pump and idler should be pulled and inspected carefully. I have also heard the hydraulic tensioners are more reliable.
