2000 C70
Posted 24 February 2012 - 02:42 AM
I hav a 2000 C70 and am lookin into a wheel and tire combo to finish the project. What is the largest known wheel and tire combo I can fit without rolling the fenders or doing anything else crazy. I'd live to fit a 18X10.5.
Posted 24 February 2012 - 04:29 AM
1998 C70 HPT M modified S70 T5A Emerald Green on Tan
Posted 24 February 2012 - 04:40 AM
Posted 24 February 2012 - 05:06 AM
Posted 24 February 2012 - 07:40 AM
Posted 25 February 2012 - 01:17 PM
Posted 25 February 2012 - 04:19 PM
20x9 ET30 with 225/30/20
I could have put 20x10.5" or 20x11" in the rear with the correct offsets and tires.
Mine was also a 2000.
aka "the Offset Whisperer"
I could list every achievement or car part I have installed in my signature, but I won't.
Posted 25 February 2012 - 04:59 PM
3 cars 1 driver 05 V70R GT http://tinyurl.com/c6frorm, 01 C70 T5M Vert http://tinyurl.com/75zhepq 03 4Runner http://tinyurl.com/ck254ueSoLD 03XC90T6 http://tinyurl.com/74pwukq98V70T5M http://tinyurl.com/85mh7z3 97 850R BTCC http://tinyurl.com/7rx7naw 98 S70T5A http://tinyurl.com/c32vjbf
Posted 27 February 2012 - 12:16 AM
Want to get my coupe to that status
Posted 27 February 2012 - 02:23 AM
God i love your car steve... as much as I don't like convertibles yours is amazing.
Want to get my coupe to that status- Guess I have to leave the pegs and head for some 18 or 19" wheel...
I don't like convertibles either lol. It's actually jeremy's fault I ended up in a vert...his was the one t that made me lust for one
Posted 27 February 2012 - 08:04 AM
my 01 has 19x9.5 fronts and 19x11 rears 62et corrected to 42 fronts and 33 rears
What tire size are you running out of curiosity?
Posted 27 February 2012 - 11:43 AM
235.35.19 frontsWhat tire size are you running out of curiosity?
265.30.19 rears
Posted 27 February 2012 - 05:56 PM
#14
Posted 27 February 2012 - 06:18 PM
on my c70 with bilstein HD's and qbm endlinks and eibachs i needed 30 mm front spacer/adapters. so my fronts went from 19x9.5 62et offset to 32mm offset to clear suspension.AND i had to roll the fenders and liner and such.
Now with my D2 Coilovers i can use my 20mm spacers/adapters and did not need the lip work. I probably can run 245/35/19's again.
the D2's are much much smaller diameter shocks.
#16
Posted 27 February 2012 - 06:25 PM
rubbing when you turn?
#18
Posted 27 February 2012 - 07:29 PM
Apologies. They rub when I turn, full lock I guess you'd say? I've never experienced them rub when I hit a bump.
That can be solved with some spacers very simply.
235.35.19 fronts
265.30.19 rears
Thank you.
#19
Posted 28 February 2012 - 12:55 AM
#20
Posted 28 February 2012 - 11:53 AM
pegs are 18 x 8? and tires are 235 40 18?
oem tire size on this car is 225mm wide, you are going another 10mm wider to 235mm
oem wheel is 42-44mm offset and pegs are 46mm off set. this equals to a wider wheel that is going inside the wheelwell towards the shock tube about 6mm.
only 6mm is enough to start rubbing inside wheel well and the inside fender liner.
You complain about the turning radius of this car? pssh...the c70 has a wheel base as short as a honda civic with a turning circle the size of a mac truck with two tandem trailers. LOL
thats normal its not you or your wheels, so dont feel so special!
