Bah's Quick Review Of Mothers Mag And Aluminum Polish
17 replies to this topic
#1 Bah
Bah
  • 1,703 posts
Posted 02 March 2012 - 07:58 PM
So...in a nice turn of events, Walmart sells Mothers products now! I have heard of them, but never experienced any of the goodness they sell. It isn't griots of course, and while i've been using meguiars lately, i have a feeling the volvo interior would like mothers products over meguiars. That's for another time though.
Walmart sells mothers products for cheap. I paid 5$ for the 5 ounce version of this:
http://www.amazon.com/Mothers-05101-Mag-Aluminum-Polish/dp/B0009H519Y/ref=pd_sim_sbs_auto_1
Good deal to experiment. I recently swapped the head on my 93 to an s70 head(Thank you ErikV11!), so while cleaner then before, it was nasty. And now that i have something worth cleaning, i figured why not.
First off, i have 0 clue whether this is appropriate to use on your head, so USE AT YOUR OWN RISK!! I got the black excrement that the product says i should, but again, i cannot verify. It says certain coatings not to use on. If your like me and just aren't worried with it, then check out the pics and maybe you wanna try the product.
So, these are all before pictures of the same spot. Its a cell phone camera, but the pics are good enough. I took plenty so you can get an idea of what it looked like.
Here is after just a few rubs on it and wiping it
better picture after a little more polish. I was using sparingly on a microfiber cloth from the dollar tree. I am positive a better cleaning tool would provide much better results.
Eww. Now this i have seen really nice and shiny on other cars and it is round and easy to polish. Lets see...
You can see just how much i put on here.
This was right after that 1 rub. WOW! Now, i have a feeling that the 2nd oil cap holder thingy is coated differently or something, as this shine is ridic compared to the other pics on the cam cover. Maybe it's just my cam cover? No clue, but you can see the shine. There is pitting or whatever you want to call that embedded into that thing. But, lets put some more effort in.
Pretty good if you ask me.
Ah your typical looking cover...with that nasty discoloration...lets see what this can do for that.
Not bad, but, i think with a rag and this polish, you won't be able to remove that discoloration. I didn't expect it to, but, it shows some signs of improvement.
Spent some time on the entire top now, and cleaned it up. I have only done where the cam lobes sit, not in the crevaces around the spark plugs. i would want to pull the boots up and stuff paper towels down then go around it all. Overall, compared to how it looked 30 minutes ago, not bad!
You can see i got some in this crevace...oops. But, just showing a comparison of cleaned vs the dirty.
Overall: I used less than 1/4 of the container to accomplish what you see above. I used dollar tree microfiber cloths, AND the engine was still warm. Comments about warm engine; the polish literally melts like butter. As i put it on the car, the heat of the engine and the sunny florida day, made this a bit more challenging. I recommend using after the car is cool, and maybe do it when its a nice temperature outside. It works fine, but, i think a lower temperature will give you more control with this product.
It isn't perfect and you can do much better with a real polishing method like we have under cosmetic by chuck. However, this is a 5$ product, from a reputable brand, that you can buy locally. Very little work involved, and you can clean up the oil stains and oxidation pretty easily.
Mothers sells a billet polish, and if you look through the forums, you can get a VERY VERY vibrant shine with that. However, i could not find this at the walmart, so went with this product. So keep in mind that this is not the best product if your looking for that super shine, but more of a casual clean shine.
1996 850 R - My Love, Suwanee
VS for life
#2 Mattphi
  • 8,627 posts
Posted 02 March 2012 - 08:02 PM
Used that on my old wheels. Loved it.
#3 JVC
  • 9,294 posts
Posted 02 March 2012 - 08:58 PM
Let us know how it holds up! I might have to pick some of this up!
#4 Zappo
Zappo
    THE ONE UPPER
  • 16,472 posts
Posted 02 March 2012 - 09:33 PM
Some of that you might have done a bit better by hitting is with sandpaper first, especially that freeze plug. 1000 grit, 2000 grit and then hit it with the Mothers.
Overall though it did clean it up pretty well. I have a jar of that already and use it to clean up my exhaust tip on my car as well as quick cleaning under the hood.
#5 Bah
Bah
  • 1,703 posts
Posted 02 March 2012 - 10:03 PM
yea in this instance i just wanted to see what this stuff was capable of, and overall i was pleased. I didn't expect it to be miracle, and given that i spent ~25 minutes working on it, it did ok.
If i get my hands on some 1000 grit -> 2000 grit sand paper, i could get in the crevaces that the towel didnt. This stuff does require some elbow grease in the very dirty spots, and i bet the sandpaper would allow me to clean those spots well enough that a light touch of this stuff could help.
And good to know about the exhaust tip! My 93's tip is always coated with carbon, and i'll try using it on it to get the shine back.
VS for life
#6 JRL
JRL
  • 581 posts
Posted 02 March 2012 - 10:35 PM
Stuff has been around since I was a kid and that's a VERY long time
If you want a KILLER polish try WENOL
#7 Serge
Serge
    Level 6 Senior Member
  • 10,851 posts
Posted 02 March 2012 - 10:36 PM
The yellow discoloration is actual caked on oil. Get some degreaser and let it sit on those spots. Make sure the degreaser is not too strong otherwise it will slightly corrode the aluminum.
Serge - 95 850 T5
#8 Volvo5.0
Volvo5.0
  • 1,122 posts
Posted 02 March 2012 - 10:57 PM
I love Mothers. Kind of like Frank's RedHot Sauce.....I put that sh*t on everything.
The cheap ebay CXRacing intercooler piping really shined up nice, with very little effort.....
1998 S70T5M, 2000 Built B5244T2 RN Engine, K24 turbo, 550cc injectors, Turbo-Tuner, Coolingmist Progressive WMI, Precision FMIC, 311whp 363wtrq
#9 scumcity14
scumcity14
  • 4,972 posts
Posted 02 March 2012 - 11:02 PM
Absolutely. Wenol is really good stuff.
Ziptied together S70 with a bitchin shift knob. Wanna buy it?
"Having a fast Saab is like coming out of the closet..sure you might surprise some people, but you're still gay."
#10 Hanks
Hanks
  • 3,507 posts
Posted 02 March 2012 - 11:29 PM
a brass brush wont score the aluminum if you want something with hard bristles to scrub with.
-Kevin-
2004 V70R: 3 angle valve job, Phuzzy FMIC, IPD Neutral rear sway
White '96 850 T5M:Black '94 850 T5
Volvospeed Useful Threads For Repairs
VS Docs now live
#11 adamjjohn203
adamjjohn203
    Steve
  • 2,242 posts
Posted 02 March 2012 - 11:40 PM
I use the mothers on my engine....holds up great, I only give it a polish twice a year!
#12 Bah
Bah
  • 1,703 posts
Posted 02 March 2012 - 11:44 PM
Brass brush noted. I need something to get a good scrub. And WOW adam is that the billet polish? Ill take all these suggestions and do some more work. Wenol sounds like that's the next step up! Too nice for this car lol
VS for life
#13 adamjjohn203
adamjjohn203
    Steve
  • 2,242 posts
Posted 03 March 2012 - 12:01 AM
Yes the billet polish after a lot of sandpaper!
#14 RobT5.
RobT5.
    FRED SANFORD
  • 5,070 posts
Posted 03 March 2012 - 01:42 AM
Dam Thank you Barry!
1 more thing on my long list of things to do this weekend. :)
#15 volvo 4 president
volvo 4 president
  • 125 posts
Posted 04 March 2012 - 02:12 AM
damn thats clean, do you drive that car lol
METALLIC BLACK. 2006. S60. T5.
#16 Che'_Moderator
Che'_Moderator
    Monkey Master
  • Admin
  • 24,710 posts
Posted 04 March 2012 - 02:48 AM
Its not gonna polish when its pitted from the molds still. Go 200 grit to 600, then try the polish. Looks more like this:
BTW here is the stuff you want:
#17 shellshock
shellshock
  • 329 posts
Posted 05 March 2012 - 02:27 AM
A nice hard power wash will remove all of that yellow coating junk. I think that was sprayed on for corrosion resistance when being on the boat ride across the pond. Grab some steel wool and work all the parts before the polish. I followed this method and mine came out looking very good!
#18 Mossback
Mossback
    Old Man Crew Sgt at Arms
  • 1,905 posts
Posted 05 March 2012 - 08:23 PM
Like Adamjohn I use sandpaper to finish off the pitting and regular to very fine steel wool when working with Mothers and lots of elbow grease, Engine will be closer to finished up by Carlsen this year.
01 C70M
1 of 603
