Removing Fender Liners
Posted 06 March 2012 - 04:19 PM
Gabe
Posted 06 March 2012 - 05:26 PM
Posted 06 March 2012 - 05:32 PM
Posted 06 March 2012 - 06:33 PM
I want to remove them in one piece. Are the rears like the fronts? Remove some rivets and they plop out?
And I'm using a dent repair hammer/dolly kit to fold up the lips. I think that will make the work pretty quick and easy.
Yeah, they'll pop out after the rivets are gone.
Ah. The metal is a tad thicker back there as well so just keep that in mind.
Posted 06 March 2012 - 06:37 PM
i learned this the hard way
Edited by s_moneh, 06 March 2012 - 06:37 PM.
Posted 06 March 2012 - 06:38 PM
1 screw on the mudflap
3 rivets where the bumper is
3 plastic bolts in the well itself
Posted 06 March 2012 - 11:54 PM
When you guys keep mentioning that it's a bit thicker, is it like impossible to roll or what? I understand it might be a bit thicker, but I don't see how a hammer with a metal block behind it won't get the job done.
yeah its the same process for the rear.
Awesome. Thanks!
Posted 07 March 2012 - 04:35 AM
Posted 07 March 2012 - 05:11 AM
that is, unless you actually plan on keeping them....
1998 Saffron V70R 190k miles. ARD green tune, Cat delete, Snabb intake pipe, MSD ignition, IPD/TME Catback exhaust, 302mm brakes, silicone intercooler & radiator hoses, IPD intake kit, IPD strut brace, TME lowering springs, Pioneer AVH p-3200BT receiver, Kenwood 1000w dual channel amp, two kicker 10'' subs, RZ design Intercooler, IPD swaybars.
Posted 07 March 2012 - 05:32 AM
Awesome. Thanks!
Its two layers or metal stitch welded. So is exactly twice as thick. Do not roll rears. Peel back liners, and trim the lip. You can cut off up to 20mm. Then trim the the liner with a razor and rivet it back in.
Volvospeed On Google+
Posted 07 March 2012 - 06:30 AM
psh, you don’t need to remove them. just get some 8 inch wide wheels (or wider) and drive like a nut job, especially on the corners... only takes a couple months and they will be completely gone, all on their own.
Not everyone drives like a nut job like you.
Posted 07 March 2012 - 06:33 AM
You’re just upset because you can’t keep up.
#14
Posted 07 March 2012 - 06:44 AM
#15
Posted 07 March 2012 - 12:59 PM
So just cut off the lip instead of folding it up? Would it be easier to just cut the front fender lips off as well do you think?
Is 20mm the width of the fender lip or is that the width of the lip on the liner? Looking at it, I think it may just be easier to cut them, and then smooth out the edge.
Try 9.5.
And yes I plan on keeping them, they're going to stay in the car, I never said I was removing them.
I'm not taking the fender liners out right now so I can trim them or delete them, I just want to remove them so I have ample room to work with folding/cutting the lips so they don't rub a groove into my tires.
#16
Posted 07 March 2012 - 01:06 PM
I just took a box cutter to the outside 6" or so. No problems after that. I will say that the rears are a pain and will take some time to roll properly.
You cut about 6" from the fender liner? I will have to trim some of it as well after the lips are folded/removed.
#17
Posted 07 March 2012 - 01:57 PM
i think possibly maybe your tires are too narrow for your wheels? maybe its the camera angle or something...
1998 S70 NA
1997 850 GLT
#18
Posted 07 March 2012 - 02:02 PM
Are you serious?
I know they are. But good luck fitting a 9.5" wheel in the back without stretching the tire somewhat.
But, please don't go off topic talking about my tire size in this thread, if you want to talk about, go here:
http://volvospeed.com/vs_forum/topic/149493-my-wheels-as-told-by-gabe/page__st__340
This thread is about the fender liners and rolling the fender lips.
#20
Posted 07 March 2012 - 02:29 PM
1998 S70 NA
1997 850 GLT
