Strut Spring Compressor
Posted 09 March 2012 - 05:23 AM
1998 S70 NA
1997 850 GLT
Posted 09 March 2012 - 05:26 AM
1996 854 T5
M56h w/ R Clutch, NA Intake Mani, Snabb Phenolic Intake Spacer, NA Throttle Body w/ 960 Plate, Snabb Intake Pipe, Custom CAI, NA Cams, S60R Exhaust Mani, 16t w/ Whites, iPd TCV, ARD Lightwieght Crank Pulley, +99 Oil Pan/Cooler, Kingsborne 8mm Spark Plug Wires, 302mm Front Brakes, Volvo Strut Tower Brace, Konis, IPD springs, few more things to come...
Posted 09 March 2012 - 05:34 AM
1998 S70 NA
1997 850 GLT
Posted 09 March 2012 - 07:06 AM
1994 Volvo 855 Turbo - 175K, 3in dp to 2.5in catback, IPD stage 1 tune.
Posted 09 March 2012 - 07:10 AM
An air tool really makes for a quick job.
1996 854 T5
Posted 09 March 2012 - 11:55 AM
1999 S70 Base w/ Manual - "5 BANGER" - IPD Springs and Sways, HD Endlinks, Bilstein TC Struts, HD Shocks, OBX Strut Brace, Lots of Poly, Custom Exhaust, Amaltheas, Pioneer Double DIN
Posted 09 March 2012 - 12:30 PM
1998 S70 NA
1997 850 GLT
Posted 09 March 2012 - 12:33 PM
Do not use the jack and control arm method. That is a good way to get hurt or damage something.
You can rent spring compressors from your local
auto parts, so do it the right safe way.
AG
Suspension - IPD 25 mm track sway bars, H&R Springs, Koni Sports struts/shocks, Maxxium Grip 18x8 Wheels, 302 brakes with Porterfield R4S pads
Posted 09 March 2012 - 02:36 PM
i think ill just buy the 30 dollar tool but thanks for the suggestion deimos.
I've got the tool too, but if you're not putting the OEM springs back on (why would you? they're so squishy...) then you don't need it.
Posted 09 March 2012 - 02:46 PM
Posted 09 March 2012 - 02:55 PM
particular reason you arent a fan of the other design?I have this one from HF. I'm not a fan of the individual sticks.
1998 S70 NA
1997 850 GLT
Posted 09 March 2012 - 03:18 PM
I think the clamshell is safer and easier to use. One bolt to turn and no slipping. The sticks just scare the shit out of me, even using this I tell anybody else that's in the garage to stay out of the way..I have a lot of respect for a compressed spring.
Posted 09 March 2012 - 03:24 PM
#14
Posted 09 March 2012 - 03:27 PM
I wore out a set of those and bought another I was using them so much. I have done a lot of suspension swaps.Is this type fine to use or or are they dangerous compared to the large standing type?
Never really had a problem with them.
#15
Posted 09 March 2012 - 03:33 PM
Just can't do it on 01+ due to the control arm setup.
#16
Posted 09 March 2012 - 03:47 PM
1998 S70 NA
1997 850 GLT
#17
Posted 09 March 2012 - 03:54 PM
#18
Posted 09 March 2012 - 04:00 PM
1998 S70 NA
1997 850 GLT
#19
Posted 09 March 2012 - 04:52 PM
20G, ARD Black, 342whp/403bhp
#20
Posted 09 March 2012 - 05:01 PM
I am out west until this spring, so if you need anything your welcome to come by whenever. I can go over whatever or do any repairs with you..oh stuff ! a fellow mainer! im not alone here on vs. maybe there are more... but i digress thanks for the info.
