Rough Idle
3 replies to this topic
#1 xtc
xtc
  • 436 posts
Posted 10 March 2012 - 04:57 PM
My 98 S70 has about 280,000km on it (174,000 miles). When the car is stopped, it idles quite roughly. The rpm's remain consistent at about 900 when idling, and they do not surge. No CEL. What could be the cause?
98 S70 NA
#2 BlackBrick
BlackBrick
  • 695 posts
Posted 13 March 2012 - 02:16 PM
Spark plugs?
1997 Volvo 850 GLT wagon - 129K miles
1997 Volvo 850 R sedan - 124K miles
#3 (_8*(l)Homer
(_8*(l)Homer
  • 374 posts
Posted 13 March 2012 - 04:42 PM
vacuum leak. There is a hose that runs from the big pipe coming off the airbox, connecting to near the right side of the fuel rail, a bit below. That one is easy to replace and I guarantee it is cracked and leaking. Perhaps someone is able to name the hose I am talking about. It is hose # 12 here: http://www.fcpgroton...her System Kit . You can just pick up a 5mm? hose and run it along around the engine for a temporary fix. It is very likely that you need to replace the PCV system. You can find instructions in the forums here.
1998 Volvo V70 R AWD
#4 brad850
brad850
  • 1,115 posts
Posted 13 March 2012 - 07:05 PM
Could also be the vacuum line going into the intake mani on the passenger side. Mine was off and I had the exact sypmtons you're describing.
96 850R red/beige
18t, R manifold, ARD, lot more
Infinity speakers / Kappa perfect 12"
