Fuel Trim Levels
#1 optimus prime
optimus prime
  • 1,372 posts
Posted 14 March 2012 - 02:07 PM
Is it normal for my long term fuel trim levels to be negative 10%?
1998 S70 NA
1997 850 GLT
#2 Converted
Converted
  • 53 posts
Posted 30 April 2012 - 02:53 AM
Hmm lol I have the opposite problem
In is 26% running rich as hell, I'd say it may be running lean but that's not a total bad thing I'd ring a Volvo dealer and ask them what is the acceptable long term fuel trim parameters are make out u are a mech by saying that fancy word would get u in the door as most dealers hate divulging that kind of Info out
#3 optimus prime
optimus prime
  • 1,372 posts
Posted 30 April 2012 - 12:06 PM
acceptable trims are -10% to 10% the closer to 0 the better anything else represents a problem with the fuel system or vacuum system.
1998 S70 NA
1997 850 GLT
#4 the commissar!
the commissar!
  • 2,077 posts
Posted 02 May 2012 - 03:36 PM
I don't know what is "acceptable" but IIRC, LTFT +/- 20% sets off CEL. LTFT is designed to fluctuate and it is impossible for it to lock in to a zero reading or even close to zero and stay there...that is why you have a range of 40% before it is a problem. If you watch it on a steady highway cruise it will be much more stable than when you are in stop and go traffic. It is a problem when the engine management system cannot influence the variable parameters enough to keep the trim in control.
To answer the OP question yes, that is normal
1998 V70 T-5 -Auto - ARD Blue & Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
