S70 T5
rwd
17 replies to this topic
#1 Tomuch5oost
Tomuch5oost
  • 3 posts
Posted 26 March 2012 - 02:32 AM
Hi I am new to volvo and I am looking for a rear wheel drive manual transmission that works with the s70 t5 motor ( B5234T3 ). any idea if the 740 modle has a manual or 240 would work? im running a stock motor and turbo and want the feel of a clutch but hate FWD ... any seggestions?
#2 Tomuch5oost
Tomuch5oost
  • 3 posts
Posted 26 March 2012 - 03:22 AM
I have also read that the s70 can be maited to the t5 trans out of the ford mustang ... with an adapter plate what is the best route to go if I wanted to put a B5234T3 into a 240? two door ...
#3 Aequitas_Veritas
Aequitas_Veritas
    Blue Calipers&Balls
  • 8,130 posts
Posted 26 March 2012 - 06:37 AM
Ask over on turbobricks.com, they know the RWD scene quite a bit better then us. I do know what you are talking about is possible though.
#4 okoye
okoye
  • 508 posts
Posted 26 March 2012 - 11:14 AM
depends on what rwd volvo you're attempting to do it in. there are a few guys that are using t6 from the s80's in the 960's as they use the same mounts.
as far as the 250 and 740 go with the t5 motor you'd need custom mounts. as for the t5 mustang trans you'll need an adapter plate, throw out bearing and i forgot the last thing.
99 v70xc x2 sold
#5 JRL
JRL
  • 571 posts
Posted 26 March 2012 - 09:09 PM
That's not going to happen PERIOD
#6 greekone
greekone
  • 3,415 posts
Posted 26 March 2012 - 09:53 PM
It's been done......
'95 854 T-5R
'98 S70 T5
'09 BMW 335i 6MT
#7 andyb5
  • 3,196 posts
Posted 27 March 2012 - 05:36 AM
Users "Karl Buchka" and "Captain Bondo" on here have done whiteblock swaps into RWD Volvos. Karl and his brother swapped at T5 into a 242, and Captain Bondo had a T6 in his 245
"Homer" is in the process of swapping a T5 into his 244.
#8 bassguy
bassguy
  • 9 posts
Posted 30 March 2012 - 09:53 PM
M90 out of a European market 960?
1990 Volvo 240 wagon, 400,000km, NA/Auto
#9 okoye
okoye
  • 508 posts
Posted 31 March 2012 - 04:09 AM
m90 can work but are extremely expensive, counting in shipping and the actual cost of parts. not to mention when something goes wrong.
99 v70xc x2 sold
#10 bassguy
bassguy
  • 9 posts
Posted 31 March 2012 - 03:36 PM
I only mentioned it because it sits behind a RWD whiteblock motor. So for "stock" options, it's the only one, unless you want the weak crap (>250hp) M46 or M47
#11 Kevin.
    I'm 22 and I love anal
  • 7,290 posts
Posted 31 March 2012 - 03:38 PM
Not to mention Robbie is putting a Whiteblock into an E30.
There's also a member on here in the middle of a RWD swap on an 850. He's using a BMW transmission and a E39 rear end I believe
#12 bassguy
bassguy
  • 9 posts
Posted 31 March 2012 - 03:41 PM
Who's doing the RWD 850? Link?
Also, is the BMW trans a Getrag 265?
#13 Kevin.
  • 7,290 posts
Posted 31 March 2012 - 03:42 PM
http://volvospeed.co...ge__hl__850 rwd
#14 Jazzy_J
Jazzy_J
  • 309 posts
Posted 31 March 2012 - 04:58 PM
2 people on turbo bricks are about to finish t5 swaps. one is into a 700 series the other into a 240. Have to modify the pan for the 240 not sure on the 700 series.
#15 Tomuch5oost
Tomuch5oost
  • 3 posts
Posted 13 April 2012 - 01:44 AM
"Also, is the BMW trans a Getrag 265"
true or false this trans can work? if so what is different that is needed?
and Do I need to custom fab up motor mounts from my sub-frame to the motor?
B5234T3 is that a red or white block still not shure on that, and Im tryin to stuff that motor with a manule trans into an e30 BMW ....
tryin to make a monster :D :D
any other seggestions much appreciated
-J
#16 bassguy
bassguy
  • 9 posts
Posted 12 May 2012 - 04:08 AM
That's a whiteblock. B = bensin (gasoline) 5 (cylinders) 23(2.3L) 4(valves/cylinder)
#17 98t5M
98t5M
  • 546 posts
Posted 17 May 2012 - 07:13 AM
http://volvospeed.co...aaackkkk-sorta/
#18 Three Fat Tigers
Three Fat Tigers
    RWD Moderator
  • 1,752 posts
Posted 19 May 2012 - 01:09 AM
Some photos I posted here on this subject, many years ago, all 240s:
