Rotating The Battery 90Deg - Mount Options
Posted 26 March 2012 - 04:24 PM
20G, ARD Black, 342whp/403bhp
Posted 26 March 2012 - 05:00 PM
Posted 26 March 2012 - 05:01 PM
Anyone have any pictures showing creative mounting options for rotating the battery 90 degrees?
Won't all the water drain out of it...lol
Posted 26 March 2012 - 05:36 PM
Posted 26 March 2012 - 06:12 PM
home depot: 1/8th in threaded rod. couple nuts, and a piece of aluminum. make a hook out of the rod, use drill bit. done done and done.
Ian Carr - 09' C30 T5-Polestar Tuned - (Sold)99' Volvo S70 T5M
Posted 27 March 2012 - 01:42 PM
Posted 27 March 2012 - 02:55 PM
TB members would be proud.
Another fucking s70: with Lots of zip-ties, a power antenna, and a bitchin shift knob... the only mods that matter.
Posted 27 March 2012 - 04:12 PM
utilizes the two inner bolt holes in the frame rail
Posted 27 March 2012 - 04:37 PM
99 V70R98 V70 GLT
Posted 27 March 2012 - 04:45 PM
Sounds like mine except I opted for a tie down strap out of the back of my roommates truck instead of a zip tieI relocated my cruise control to a box in my garage, tossed the battery tray in the trash and zip tied my battery sideways. Didn't cost a penny.
1998 s70 t5- auto
Posted 27 March 2012 - 05:02 PM
Thats one hell of a PCV system if I don't say so myself. Is that upper can custom?
1996 854 T5
M56h w/ R Clutch, NA Intake Mani, Snabb Phenolic Intake Spacer, NA Throttle Body w/ 960 Plate, Snabb Intake Pipe, Custom CAI, NA Cams, S60R Exhaust Mani, ARD Billet 16t , Whites, iPd TCV, ARD Lightwieght Crank Pulley, +99 Oil Pan/Cooler, Kingsborne 8mm Spark Plug Wires, 302mm Front Brakes, Volvo OEM Strut Tower Brace, Konis, IPD/TME springs, ARD Green Tune
Posted 27 March 2012 - 06:18 PM
Posted 27 March 2012 - 06:59 PM
y dont u just relocated it to the back....
Don't get that topic started.
1996 854 T5
#14
Posted 27 March 2012 - 08:38 PM
instead of fubaring a mount, cuttign it shaving it to fit perpendicularly to what it was just remove it and call it a day
#15
Posted 27 March 2012 - 08:51 PM
#16
Posted 27 March 2012 - 10:41 PM
#17
Posted 27 March 2012 - 10:48 PM
Do you have it in a sealed box with drain and vents to the outside of the car, or did you just mount a battery tray in the wheel well and call it good?i personally see it quiet easy but to each his own right its still a nice big option that not many have done
#18
Posted 27 March 2012 - 11:04 PM
however, no the wheel well is a quiet stupid idea.
i don't know if many people know this but trunks have vents in them anyways for w/e reason u would need a vent
here's a point to your vent/sealed box idea......bmw's have their battery's in the rear. exact spot as mine, but its embeded because bmw engineered the spot there for it, BUT the trunk carpet goes over top it and from what i saw there is absolutely no holes for any sort of draining or venting.
here's mine:
#19
Posted 27 March 2012 - 11:32 PM
#20
Posted 27 March 2012 - 11:39 PM
