Rotating The Battery 90Deg - Mount Options
26 replies to this topic
#1 boxpin
boxpin
    Old Man Crew Psyllium pusher
  • 1,621 posts
Posted 26 March 2012 - 04:24 PM
Anyone have any pictures showing creative mounting options for rotating the battery 90 degrees?
20G, ARD Black, 342whp/403bhp
#2 kalvin
  • 2,365 posts
Posted 26 March 2012 - 05:00 PM
Here you are:
http://volvospeed.co...__fromsearch__1
#3 claymore
claymore
  • 236 posts
Posted 26 March 2012 - 05:01 PM
Won't all the water drain out of it...lol :)
#4 boxpin
boxpin
  • 1,621 posts
Posted 26 March 2012 - 05:36 PM
#5 Ian Carr
Ian Carr
  • 1,615 posts
Posted 26 March 2012 - 06:12 PM
home depot: 1/8th in threaded rod. couple nuts, and a piece of aluminum. make a hook out of the rod, use drill bit. done done and done.
Ian Carr - 09' C30 T5-Polestar Tuned - (Sold)99' Volvo S70 T5M
#6 the commissar!
the commissar!
  • 2,077 posts
Posted 27 March 2012 - 01:42 PM
Pull battery, relocate cruise control to the inner fender, determine how much of the battery tray you need to keep to hold battery, remove tray from car to sawzall off the excess and the lips that interfere with the battery sitting flat, drill holes in tray to mate with holes in battery bottom, replace tray and battery, then ziptie battery to tray or use an aftermarket generic battery hold down. You can keep your stock airbox doing it this way or use an aftermarket open air type box...I use IPD's SR5T and it fits perfect.
1998 V70 T-5 -Auto - ARD Blue & Turbo-Tuner,18T, HD TCVw/ Hallman Pro MBC, custom 3" DP w/ Volvo 2.75" sport catback - both wrapped and coated, RIP, IPD aluminum intercooler, intake w/ K&N cone, R ex. manifold, , gasket matched & polished intake manifold w/ thermoblock spacer, n/a TB w/ 960 plate, Optima bluetop, MSD 6aD and blaster coil, IPD plug wires, IPD poly bushing, Koni FSD w/ Eibach springs, IPD sways 25mm x 25 mm, blue silicone vac, silicone coolant lines, custom intake tubes grill to turbo, skid plate, front lower brace, cherry turbo strut brace, HD endlinks, 302mm brakes, Zeitronix wide-band/data-logger, Walbro w/variable fpr. In process: Home grown HD Endlinks, Meth/H2O injection, greens, catch can, fully built 2.3.
#7 scumcity14
scumcity14
  • 4,815 posts
Posted 27 March 2012 - 02:55 PM
I relocated my cruise control to a box in my garage, tossed the battery tray in the trash and zip tied my battery sideways. Didn't cost a penny.
TB members would be proud.
#8 lookforjoe
  • 9,785 posts
Posted 27 March 2012 - 04:12 PM
I cut down the stock tray, rotated, added the pins back on the side to prevent the tray 'tipping'
utilizes the two inner bolt holes in the frame rail
1998 V70 XR M66 PTE6262 BB Built '04 2.3l Block Wiseco Pistons 147mm H-Beams '03 Ported Head EnemY21Cams TurboTuner 710cc Inj, DW300, 3" DP back Dual Magnaflow 14834's Apr 2013 408WHP AWD (@7925rpm) 347WTq(@4400rpm)@18psi LGSpeed Header Custom Intake Manifold 30x12.5x3.5"Treadstone FMIC Spec Stage III+ SO603FS Kaplhenke CoilOvers
#9 Dan A
Dan A
    Old Man Crew Pledge Pres.
  • 1,994 posts
Posted 27 March 2012 - 04:37 PM
Is anyone using a slimmer battery also? Or full/standard size? I'm using a slim one, but only lasts through a couple of winters.
99 V70R
98 V70 GLT
#10 T5Hammy
T5Hammy
    Dick Sledge
  • 342 posts
Posted 27 March 2012 - 04:45 PM
Sounds like mine except I opted for a tie down strap out of the back of my roommates truck instead of a zip tie :ph34r:
1998 s70 t5- auto :(, Stage 0, kw var 3, Ipd short ram, N/A TB from Snabb, FMIC 29x9x3, OBX exhaust, 18" Ipd pegs flat black, black projectors, aux tranny cooler.
#11 survolvo
survolvo
  • 2,920 posts
Posted 27 March 2012 - 05:02 PM
Thats one hell of a PCV system if I don't say so myself. Is that upper can custom?
1996 854 T5
M56h w/ R Clutch, NA Intake Mani, Snabb Phenolic Intake Spacer, NA Throttle Body w/ 960 Plate, Snabb Intake Pipe, Custom CAI, NA Cams, S60R Exhaust Mani, 16t w/ Whites, iPd TCV, ARD Lightwieght Crank Pulley, +99 Oil Pan/Cooler, Kingsborne 8mm Spark Plug Wires, 302mm Front Brakes, Volvo Strut Tower Brace, Konis, IPD springs, few more things to come...
#12 s_moneh
s_moneh
  • 1,581 posts
Posted 27 March 2012 - 06:18 PM
y dont u just relocated it to the back....
1997 854 T5M - Megasquirt 2Extra with COP, Sconemans Intake Kit, Sconemans short shift kit, K&N Panel Filter, poly engine mounts/poly control arm bushings, delrin solid subframe bushings,prosport; boost, oil pres gauges, AEM wideband, OBX Turboback, 16T, D2 Racing coilovers, HKS SSQV4 BOV with BP, FMIC w/ 2.5" piping, 213 Fuse Mod, R manifold, NA 3" throttle body w/ 960 plate, NA cams, lgspeed rods, wiseco 81.5mm pistons, newer style oil cooler, green giants, 4bar fuel regulator,28mm rear ipd sway, 25mm front ipd sway, 17x7.5 BBS Propus C's, tons more mods
#13 survolvo
survolvo
  • 2,920 posts
Posted 27 March 2012 - 06:59 PM
Don't get that topic started.
1996 854 T5
#14 s_moneh
s_moneh
  • 1,581 posts
Posted 27 March 2012 - 08:38 PM
i dont see why not? its so much less of a hassle to just move it and give you some space
instead of fubaring a mount, cuttign it shaving it to fit perpendicularly to what it was just remove it and call it a day
#15 Zappo
Zappo
    THE ONE UPPER
  • 16,418 posts
Posted 27 March 2012 - 08:51 PM
Seems like a lot more work to move it to the back to me. Well, to do it the right way at least.
#16 s_moneh
s_moneh
  • 1,581 posts
Posted 27 March 2012 - 10:41 PM
i personally see it quiet easy but to each his own right its still a nice big option that not many have done
#17 Zappo
Zappo
    THE ONE UPPER
  • 16,418 posts
Posted 27 March 2012 - 10:48 PM
Do you have it in a sealed box with drain and vents to the outside of the car, or did you just mount a battery tray in the wheel well and call it good?
#18 s_moneh
s_moneh
  • 1,581 posts
Posted 27 March 2012 - 11:04 PM
nowhere does it state you NEED it in a sealed box with a drain and vents to the outside (OE wasn't even in a sealed box with a drain or vent's.....). the law states it has to be secured down so it doesnt fly all over the place, that's about it
however, no the wheel well is a quiet stupid idea.
i don't know if many people know this but trunks have vents in them anyways for w/e reason u would need a vent
here's a point to your vent/sealed box idea......bmw's have their battery's in the rear. exact spot as mine, but its embeded because bmw engineered the spot there for it, BUT the trunk carpet goes over top it and from what i saw there is absolutely no holes for any sort of draining or venting.
here's mine:
#19 Rod'sT-5
Rod'sT-5
  • 97 posts
Posted 27 March 2012 - 11:32 PM
Most manufacturers with the batteries inside the car, do use vent and drain tubes for venting and for spills. The Red Top is completely sealed, no chance of venting or leaking if rolled over. That is probably the best choice. But for a regular lead acid battery with removable caps, they should be vented, in a box, with a drain hose.
98 S-70 T5A
#20 BtownVolvo
BtownVolvo
    Level 69 Member
  • 8,709 posts
Posted 27 March 2012 - 11:39 PM
Just go Li-Ion and tuck it under the headlight:
http://rbbatteries.com/
/thread
Reid | 1998 V70 T5
