High 12's Possible With An 18T?
49 replies to this topic
#1 project_850
project_850
  • 701 posts
Posted 28 March 2012 - 03:23 AM
In October of 2010 I managed to run 13.33 @ 109.64 on the following setup:
Fresh 18T, angled flange, ported wastegate, fresh 300/70 actuator
R manifold
Custom intake
iPD 3" turboback
iPD drop in intercooler, RIP kit
AC compressor, condenser delete, shorter belt
Freshly flow-tested/cleaned white injectors
New ignition components
Silicone vacuum lines
Aquamist
iPD Stage III Euro manual 850R tune, Turbosmart MBC @ 18psi
Mickey Thompson 24.5/8/15 ET Drag slicks
Slight weight reduction--no back seat, no spare tire, paneling removed over hatch floor
My question is, has anyone actually achieved high 12's at 110mph+ using a stock-frame turbo? A 19T-powered car, maybe?
If not, I think I will perhaps make this my goal this summer. I've been wanting to do a mild build (rods, pistons) for years now, but the 855R refuses to give me a good reason to swap a built motor in. *Knock on wood*
The reason I think high 12's are possible, is because I think that with a perfect launch, I can bring my 60ft time down another 0.25 seconds. What's a perfect launch, I hear you fellas ask? I'm thinking 2-step @ 10psi off the line? I've had my eyes set on the MSD 6AL w/ 2-step or N2MB's WOTbox for the longest time. I think the trap speed is high enough to warrant high 12's maybe?
1997 M59 855R ->Build Thread<- | 1994 854 T5M | 1994 854 GLE M 10v w/o sunroof | 1982 242 GLT M46
#2 JVC
  • 9,206 posts
Posted 28 March 2012 - 03:28 AM
Strip the interior out... that oughta get you pretty close.
#3 greekone
greekone
  • 3,413 posts
Posted 28 March 2012 - 03:40 AM
Trapping 109+ with an 18T, damn. Your car seems VERY healthy.
I never saw the slip, but was talking to Fishy some-what recently and he had mentioned running a 12.9 with a 16T in his 854 T5R auto.
'95 854 T-5R
'98 S70 T5
'09 BMW 335i 6MT
#4 Jardim
Posted 28 March 2012 - 03:41 AM
Stock T5 boost level + slicks will definetly get you going
#5 Oreo931
  • 24,497 posts
Posted 28 March 2012 - 03:49 AM
Wow, awesome numbers man! Very impressive on an 18T.
#6 TBM
TBM
  • 3,673 posts
Wasn't there someone on here (from Iowa) I believe who ran a 12.9 with an 18T and about 400 lbs of weight reduction?
EDIT: And that's a sick time and an even better trap speed. :tup:
Edited by TBM, 28 March 2012 - 03:50 AM.
1998 S70 T5M
- Comets - R Bumper - RICA Tune - OBX Turboback - FMIC - EST Intake - HKS SSQV - IPD HD TCV - Koni FSDs - IPD Springs - OMP Strut Bar - AEM UEGO -
Prosport BG & EGT - ABM Projectors - 6000k HID Lows & Fogs - LED Sidemarkers - Custom XC Grille - R Panels - 18T - R Manifold - Short Throw - 2 Baby Seats -
#7 greekone
greekone
  • 3,413 posts
Posted 28 March 2012 - 03:57 AM
Forgot the state, but remember who you're talking about. He had a black 854R with major weigh reduction (500-600 lbs.). Think he ran a 12.8, but I could be wrong.
'95 854 T-5R
'98 S70 T5
'09 BMW 335i 6MT
#8 ErikS
ErikS
    99.9%
  • 5,408 posts
Posted 28 March 2012 - 04:01 AM
Member name cr854, or something like that. Don't know if a slip was ever uploaded.
1995 854 T5M Click for Mods
2005 S60 2.5 T
2013 MB GLK 350
#9 MGD1
MGD1
  • 74 posts
Posted 28 March 2012 - 04:22 AM
Could probably shave another 120lbs(?) replacing your three wagon windows with speed glass...just a thought. Cheap weight reduction :)
#10 ARD - Lucky
ARD - Lucky
  • 1,089 posts
Posted 28 March 2012 - 04:41 AM
At my best with 18T straight flange, turbo back exhaust and intake with hottest tune I was willing to put on my own car I hit 13.15 seconds. You're pretty close to as good as it gets with a wagon which is 110 lbs heavier than my sedan :tup:
Robert 'Lucky' Arnold
#11 project_850
project_850
  • 701 posts
Posted 28 March 2012 - 04:58 AM
Thanks for the kind words guys. I think it's likely that I can break into the 12's. My plan is to go ahead with an MSD ignition box that allows for 2-step and WOT shifting, open downpipe, and my missing headlight mod which adds at least 15hp :lol:
I'll Go Pro it when the day comes this summer--hopefully my axles survive the launch :ph34r:
#12 MGD1
MGD1
  • 74 posts
Posted 28 March 2012 - 05:30 AM
There's your problem, you don't have any stickers yet!
Seriously though, your car is very sharp looking!
#13 Jardim
Posted 28 March 2012 - 05:31 AM
Lets hope we don't hear "monkey i think i broke something" :lol:
#14 Captain Bondo
Captain Bondo
  • 639 posts
Posted 28 March 2012 - 06:50 AM
Nice time man, and a lower mainland guy I see!
I think it's doable. With the MT's you should be able to get sub 2.0 60' times, a 1.8 and you're pretty much there....
Does the boost taper? Even if it does, if you can run more, with a splash of race gas even, that would also probably do it.
I am aiming for mid 12's this summer on 15gs (2 of them though). :D
#15 B Mac
B Mac
    Ginger Beater
  • 4,554 posts
Posted 28 March 2012 - 11:29 AM
If you can drop your 60ft you will be there. I got a 1.82 60ft last time at the track with MT slicks and no wot box/ launch control. 6,000 rpm bouncing the throttle and let 'er rip...your transmission and axles will hold, don't worry :tup: It felt like I got rear ended by a truck :lol:
The name's Ben: '95 850, m56 w/ gripper lsd, Sachs 707 pressure plate w/ organic disc, built '02 RN 2.3L, worked '04 R head, Enem Y21 cams, Precision 5857B, ARD tune, blah blah blah
#16 fischmama
fischmama
  • 4,948 posts
Posted 28 March 2012 - 11:56 AM
I destroyed a trans launching at 4k on hot street tires at 30psi. Diff exploded and found a way out. That was with a K24.
We also fried a quaife LSD with drag radials at 15psi. Best 60 was 1.9 I think. Even the drag radials would break loose sometimes. GT3076R
As much as I would love to see it, I don't think 12s are possible. Sorry I'm the glass is half empty guy when it comes to this.
Website: JJFab.net
#17 Dan A
Dan A
    Old Man Crew Pledge Pres.
  • 1,994 posts
Posted 28 March 2012 - 05:03 PM
R manifold
Custom intake
iPD 3" turboback
Aquamist
No LSD?
99 V70R
98 V70 GLT
#18 greekone
greekone
  • 3,413 posts
Posted 28 March 2012 - 05:16 PM
No LSD?
M59 has a viscous coupling.
'95 854 T-5R
'98 S70 T5
'09 BMW 335i 6MT
#19 Dan A
Dan A
  • 1,994 posts
Posted 28 March 2012 - 05:43 PM
Must be in his sig or something. Can't see sigs with the mobile skin. :(
99 V70R
98 V70 GLT
#20 greekone
greekone
  • 3,413 posts
Posted 28 March 2012 - 06:11 PM
No worries, factory manual 850R's came with the M59.
'95 854 T-5R
'98 S70 T5
'09 BMW 335i 6MT
