T5 Ecu In My Glt
54 replies to this topic
#1 Jcbkid
Jcbkid
  • 90 posts
Posted 06 April 2012 - 03:37 PM
Hey guys I picked up a t5 Ecu from an 850 Turbo at the junk yard today
Having some problems:
I was told with it in I'd boost at or around 10psi I definitely feel alot more power and no lag but I'm still only boosting at 7psi vs my previous 5 psi I'm not getting any cels and it starts right up. It did start vibrating a little but that could have always happened since I have a bad top motor mount and leaking PS pump
#2 Jcbkid
Jcbkid
  • 90 posts
Posted 06 April 2012 - 03:49 PM
Update
It holds boost pressure at 4psi then down shifts where as before it would down shift right at 1psi and I'm getting better MPG? Weird
#3 Yellow95
Yellow95
    Grandpa G
  • 6,750 posts
Posted 06 April 2012 - 04:21 PM
If you are running it in a 97 GLT then enjoy. No issues at all. If you are running it in a 98 X70 GLT, take it out or dont use your air conditioner. Gary
#4 MattyXXL
MattyXXL
  • 2,467 posts
It's been a while since I ran a stock t5 ecu, someone correct me if I'm wrong but isn't stock t5 set to 7.5 or something like that? And the R was 10?
If that's how it is then your right on target.
1996 854 T-5 Modded, But who really Cares
1995 Yellow 854 T5-R Bone Stock!
http://www.floridavolvocommunity.com/
#5 Yellow95
Yellow95
    Grandpa G
  • 6,750 posts
Posted 06 April 2012 - 04:22 PM
Supposed to be 9lbs but his turbo could be tires, his wastegate could need adjusting. His CBV could be torn. Should I go on? :) Oh and his boost gauge could be off.
#6 Jcbkid
Jcbkid
  • 90 posts
Posted 06 April 2012 - 05:43 PM
mines off by 1psi. its now boosting normally again around 7-9! Why can i not use my ac? So far it runs mint!
#7 MattyXXL
MattyXXL
  • 2,467 posts
Posted 06 April 2012 - 05:50 PM
With you 100% on that... :tup: :tup:
mines off by 1psi.
Id get a new gauge..
#8 burnout8488
burnout8488
  • 728 posts
Posted 06 April 2012 - 06:29 PM
You need to tell us if you put it in an 850 or S70.
'99 S70 AWD + FWD Trans // 161K
2.4+15g/Rmani/Snabb Pipe/EST DP/ARD Green/4300k Bi-Xenon Retrofit/Nivomats/Rear Heated Seats
#9 Jcbkid
Jcbkid
  • 90 posts
Posted 06 April 2012 - 06:44 PM
Its in a v70xc
Found that my fuel pump takes a little longer to go up to pressure when key is on and when i shut the car off it hisses from air vents. So far though running wise its mint.
#10 MattyXXL
MattyXXL
  • 2,467 posts
Posted 06 April 2012 - 06:49 PM
what car did the ecu come from?
#11 Jcbkid
Jcbkid
  • 90 posts
Posted 06 April 2012 - 06:51 PM
ecu came from an 850 t-5 i checked the serial number on the ecu and it is a t-5
#12 RobT5.
RobT5.
    FRED SANFORD
  • 5,039 posts
Posted 06 April 2012 - 07:21 PM
Go ahead and remove that ecu for right now....
850 ecu in a 70 series is not a good idea...
Lets just say your ac compressor will no longer like you...
ask the PO of my car how I know...
tuned 850 ecu in the 70. :lol: <3 ya billard.
#13 Jardim
Posted 06 April 2012 - 07:24 PM
Keep the AC off you should be straight. My ac stuff the bed ages ago so this isnt a problem for me.
#14 MattyXXL
MattyXXL
  • 2,467 posts
Posted 06 April 2012 - 07:48 PM
Its in a v70xc
Could this be happening due to the 850 ecu being M4.3?
#15 Jardim
Posted 06 April 2012 - 08:08 PM
They say M.4.4 starts the car faster than M4.3 so maybe.......I wouldnt downgrade from 4.4 > 4.3 though, i thought it was the other way around...
#16 MattyXXL
MattyXXL
  • 2,467 posts
Posted 06 April 2012 - 08:11 PM
Same thoughts here...
#17 Yellow95
Yellow95
    Grandpa G
  • 6,750 posts
Posted 06 April 2012 - 08:30 PM
The ac pinout is dfferent and it will do dastardly things to your ac. Other then that it will run fine.
Gary
#18 Gideon35T
Gideon35T
    GET OFF MY GRID, damn kids.
  • 1,419 posts
Posted 06 April 2012 - 09:49 PM
There's a million things that can cause boost pressure issues. However, I bet that at least a portion of the issue is with the boost gauge. Most boost gauges are not calibrated. They are just a rough guess. Beyond that, the motor is 15 years old, stock intercooler piping couplers are rubber and don't last, CBV could be damaged, wastegate tired and/or needs adjusting, turbo could be tired, boost leaks of all different types, etc etc etc. If it's faster and you've done a good stage zero then just be happy. As for the ac, I seam to remember a thread where someone rewired things so the ac was fine. I wonder if Lucky could chime in on the ac wiring difference as I'm sure it's within the serial bus and may be able to be adjusted just via tuning.
2003 S60 2.4T: FMIC, 16T, OZ Wheels, B&G S2 Springs, etc. - 106k --- 1994 855 Turbo "Zombie Wagon": Roof rack, Push bar, 13 psi - 250k --- 1995 855 Turbo "Nessie": Replacement for the Zombie Wagon - 170k
gdizzle - ' I'm trying NOT to look like a total pretentious prick.  Those gloves scream, "HEY!  Look at me!  I'll suck your dick!"  No thanks. '
#19 Jcbkid
Jcbkid
  • 90 posts
Posted 06 April 2012 - 11:54 PM
Honestly I'm doing an AC delete anyway so I'm not worried I have done stage zero so I'm very happy!:)
#20 Keaton85
Keaton85
  • 7,502 posts
Posted 07 April 2012 - 12:06 AM
AC delete: do you plan on ever reselling this vehicle? if so then I would shy against that!
