New S80 Owner As Well As Member.. Tips Please
Posted 07 April 2012 - 12:47 AM
1) Can someone with good knowledge on this car please tell me anything I should check, replace, test outside the norm\basics i.e. oil change, tune-up, radiator flush. Possible Trans flush/fluid-filter change.
2) My new S80 starts right up, but has a rough idle, seems to have a dead cylinder but will drive with decent power. I’m positive there’s more to the T6. So I researched the issue, call my best friend who is a master mechanic/diesel mechanic and tell him to hand over his snap on SOLUS scanner. So excited to use all the advanced features over a smaller less expensive scanner he told me he doesn’t know if it will scan a Volvo. I found out it was not upgraded with the European car software, but I was able to read the codes and live data and this is what I got for the codes.
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0102 Mass or Volume Air Flow Circuit Low Input
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0110 Intake Air Temperature Circuit Malfunction
Please correct me if I’m wrong, The P0108 seems to fit with the post I found where the MAP sensor is bad due to cheap design and the soldering could be cracked or damaged inside, so I should attempt to clean the connectors/the solder fix or find a replacement MAP sensor.??
P0-104-102-101 to me points to a dirty or malfunctioning MAF sensor, I’ve tested MAFs on fords, but I wouldn’t think it’s the same. My plan is to clean connectors, clean MAF elements and housing, test voltages input/output if good clear code and see where I am. Any tips??
P0110 I have not found an IAT sensor but I am thinking it is in reference to the sensor on the MAF... Any help is appreciated. I can’t wait to get my new toy on the road...I will post Pics of it now soon and my appearance progress pics...
Posted 07 April 2012 - 06:56 PM
help
Posted 07 April 2012 - 08:45 PM
Buy a Bosch (aftermarket) it's the same as the Volvo blue box MAF, and go from there
Posted 07 April 2012 - 08:54 PM
Posted 08 April 2012 - 02:25 PM
As JRL mentioned, buy a Bosch MAF only. The cheaper aftermarket brands are absolute crap.
Posted 10 April 2012 - 04:43 PM
Question:
Does anyone know the voltage test procedures for the MAF as well as the MAP? I will buy sensors if needed but I want to make sure that it’s the proper diagnosis before shelling out hundreds of dollars and still have the same issue.
If problems are corrected will code clear automatically after a number of test drive cycles?
Any tips or Guidance is greatly appreciated, I just want to get this car running and everything to OE specs.
Posted 13 April 2012 - 06:20 AM
Still need tips and advice as I gather everything I need to bring this one back to original running order.
Posted 13 April 2012 - 12:32 PM
There isn't many vacuum hoses on your car. I would consider replacing each one if I were you.
The IAT sensor is on the cold side intercooler piping in front of the intake manifold.
Posted 16 April 2012 - 08:53 PM
Posted 17 April 2012 - 04:51 AM
In the morning I will get plugs, oil (still need the ppls choice on the best oil to use) filter, Oring, drain plug washer. and install. If i get it right I will have this bug I always get with my favorite cars in my life time. (a long post that would be) Im just gettting excited about the possibilities and potential of this car.(drem BIG!!.. LOLZ)
Back to it.. The RPMs were between 1100 and 1300 I believe no surge, didnt have the scanner today and i was so excited on the progress. I didnt get the new message until after test drive with seafoam. Changing oil and plugs should give me some improvement but Im wndering now. Should I seafoam the vaccum system, Ive put 1/3rd can in crankcase and gas tank alerady and i noticed from the time I started it until after test drive, the Idle improved gradualy.
Ill go with my original plan and wait for the Jury on the seafoam..
Thanks again, can wait to help someone here for somehing I have knowledge on..
Im mobile now sorry for the typos
Posted 17 April 2012 - 05:29 PM
Posted 18 April 2012 - 12:21 AM
The oil pressure light coming on is probably due to bad oil pan o-rings (search this site) You'll want to get that resolved before you cause catastrophic damage.
When changing the plugs, use Genuine Volvo ONLY. Nothing else. Also, inspect the coil packs for cracks by pulling down the rubber boots. If you see them this can cause a poor running issue, but usually they don't go long before flagging a CEL.
As for the surge, look into cleaning the ETM (read thread pinned at the top of this forum) Hint: Do not spray carb/brake cleaner into the throttle assembly, it will damage it.
Spray it on a rag first. If you need to spray something in the ETM, WD-40 is safe to use.
#14
Posted 18 April 2012 - 02:27 PM
thanks again
#15
Posted 25 April 2012 - 05:31 AM
My questions are:
Did my cats take a dump i.e. rattling\smell\weak acceleration??
What vacuum line is best for smoke testing the system??
could the shake be mounts that are shaking the exuast as a part of the noise I hear??
please for give my typos as I broke my key board and its a struggle to type..
Thank fellas for any help...
#16
Posted 25 April 2012 - 03:32 PM
Any Help is greatly appreciated...
#17
Posted 25 April 2012 - 03:39 PM
My questions are:
Could have... take a rubber mallet and hit the convertors. If they rattle then you need to change them.
I don't know because I did a leak test as opposed to a smoke test. The materials cost me less than 10 bucks (assuming that you have access to an air compressor)What vacuum line is best for smoke testing the system??
Did you replace the vacuum lines yet?
Could be. Are you sure that its not the lifters that you are hearing?could the shake be mounts that are shaking the exuast as a part of the noise I hear??
Edit: Missed your last post. Sounds like you may need to invest in a new exhaust. I'd recommend a 2.5" cat-back solution. Don't eff with the down pipe unless you are sure that you have clogged convertors. And if the convertors need to be replaced, insist that they reinstall the O2 sensors in the same position as they are on the stock DP.
#18
Posted 25 April 2012 - 04:19 PM
Okay, the smoke test should work from a hose connected to the intake. I want to replace the vac lines today, but I’ll have to do some searching for and import parts store or maybe home depot. Advanced and AutoZone’s barley have a spark plug or oil filter for this car. Should I look for silicone hoses?? Also there are a few check valves, elbows and T's, can I clean or should I replace??
I will use a dead blow mallet on the cat to listen for a rattle; actually I did tap it lightly and did not hear anything. But I’m positive where the noise is and I’m sure it’s not the lifters. Only sound going on under the hood would be the injectors, which I had to get used to. That sound is not usually good on US cars.
What is the best 2.5 cat-back system for this car? I could I have a custom cat back built cheaper than a kit But I’d like to pick the best sounding/quality components. I would prefer to get a dual tail pipe outlet to go with a rear spoiler that I scoped out for later. I have a little spending money and ready to go shopping...
Thanks again...
#19
Posted 25 April 2012 - 06:43 PM
S8ET6, You are a big help and I appreciate it, you are in Chicago, I’m in Michigan and I swear if I get this thing on the road and stable, I coming to the windy city for a club meet\or show or something and I owe you the first 3 rounds of beer or whatever you favorite drink is....
Thanks again...
Thanks. You need to check out the MWC chat thread under the regional section... We meet up on a regular basis and you're more than welcome to attend the next one.
Ive had silicone lines for the past 5-6 years and they've held up well over time. Unfortunately, the company I purchased mine from no longer has a good reputation, so I can't refer you to them. However, if you search VS I'm sure that you can find another source for silicone hoses.
As for the exhaust, a custom solution would be your best/cheapest bet. I purchased a magnaflow muffler online for about $70 with shipping and had my local guy replace the old system with 3" piping from the cat back. I also deleted the resonator. I don't suffer from drone at any rpm with this setup
Edit: oh, and keep in mind that bad cats should throw a code. So if you don't have a CEL then I guess you can assume that they are not clogged.
#20
Posted 06 May 2012 - 02:23 PM
I want to perform a vacuum leak test on the whole system, what would be the best method smoke or presure test? I will also look to get a new tank of gas and a new filter as the gas in the tank is almost empty and is at least a year old. One question I have is what is the best way to rest the computer to have the computer re-adapt to the engine?? I read that I can disconnect the negative terminal and touch it to the positive for 30 seconds and that will clear it. Not sure if that works but by me just disconnecting the battery for 20 minutes did nothing. Is there anything else I should be looking at or testing.. getting close to a brick wall here.. I an greatful for any help..
