Andy's 1999 V70 R
Nice work Andy! Great attention to detail especially with the head swap.
After wrapping up my manual swap, I drove down to Stevo's place in CT and he worked some magic for me. He removed the CEL and 4k rev limiter associated with the manual swap, remapped the throttle to make the car easier to drive smoothly, and turned the boost up to about 15/16 PSI with corresponding changes to fuel/timing as well. Boost development is very stable and holds steady to redline at ~6500 RPM. Between the manual and revised tune, the car is a blast to drive.
AC2FBDD2-08CF-4A9B-9A30-E296F3D7B673_zps
Since then, I've basically been driving it, enjoying it, and taking some much needed time away from working on my car.
5ACB2A81-AD8C-4668-9A4D-C478589803FE_zps
Had a good time at SCD even if the weather wasn't ideal.
c75810fd318f2f3adea321b1acfc46bc_zps0mrw
11809969_871171912959559_1574914523_n_zp
However, I have recently been back at it and taking care of a few issues as they've popped up.
I had a transmission bracket bolt snap in half, so I drilled that out and replaced it.  Kind of a pain in the ass to repair, but it actually was not as bad as I expected.
DED43714-9AE6-4F04-855C-8744952E55E9_zps
53A5103B-EE0A-4A4B-A433-D46F33F252E6_zps
The forecast for the last couple nights showed weather dipping below freezing. Since I was running straight distilled water as coolant, this was a big problem. Since I needed to switch to Volvo 50/50 mix, I decided it was time to install my do88 all-aluminum radiator.  I decided to use a -98 style thermostat cover to resolve the overflow line issue (see earlier post about this)
f50da5796adfece27aed26591f558319_zpsd34g
Got that all buttoned up and went to replace my worn out, leaky, power steering rack with a remanufactured rack from rackdoctor.com and new OEM outer tie rods and a new OEM 05+ PS reservoir to eliminate a few different leaks.  The old rack was pretty nasty and I was so glad that I was replacing it:
1E41762E-972D-490A-8851-5BB516EEBC15_zps
This is where things got ugly.  After I got everything taken apart, I was presented with this horror show
d523fc31732e3dc9f1a183c7328ab8d7_zpsdmlr
Someone who had worked on this car in the past had cross-threaded the return line and the fitting was effectively destroyed when I removed it from the rack. So after exploring a few options, including a call to Hussein (thanks for picking up H!) I dejectedly decided to order a new OEM return line and re-assemble all my old components until I got the new line in.
This tuned out to be way, way more work than it should've been. Getting the steering column U-joint back on the rack in the car proved impossible, so I had to drop the rack/subframe, remove the u-joint from the car, and hammer it back on then re-install the subframe back in.
29615b6c04be0dd74b0353da7db3a3e7_zps5ojf
So that was a shitload of wasted time and effort, which was really frustrating. On the plus side, I was able to fix a loose turbo drain tube and re-route my shift cables from in front of the steering column to behind the column where they belong. This helped smooth out the shifting a bit.
  • Upvote 3
Seems like you've been dealt a lot of shitty cards with that car. I know how it feels lol. I did the same thing with the cables too! They are harder to mess around with than you would think. Anyway, nice work man. I wish I got things done as quick as you
Love the progress. Good work Andy. With the shifter cables the way they were, how did the shifting feel? I'm pretty sure mine are routed properly but am just curious.
It seems there's always somthing with these cars...
I'm thinking of a new rack for my 2000R. The steering feels sloppy as F. It's like there's a dead spot at 12:00 and it's not so bad when you're driving slowly, but once you get on the hwy it's a bit sketchy. You can move the wheel back and forth slightly and the car isn't affected. Makes it hard to get a feel for the road.
IDK if it's leaking but soemthing isn't right.
I love that you're sticking with it, despite everything that's been popping up, Andy. Nice work!
How was the removal of the steering rack? I may look into doing mine on the wagon after winter, as it's leaky and has a slight slop to the right.
Having recently completed a rack replacement on my VR, I'll go ahead and comment it's a pain in the ass.  Not a whole lot of room with the bevel gear and sway bar in the way. If I EVER have the need to do it again with an AWD, I'll drop the whole subframe and not just the rear.
Yep, doing it on an AWD car is a pain without a lift. I replaced the rack in my XC last winter with the car on jack stands and it sucked. Replacing it might be easier in a FWD car since there's not as much stuff in the way.
Sorry to read you had so much trouble Andy.
Thanks for the words of encouragement guys, I really do appreciate them.
Tommy, the shifter had a slight notchiness to it that is now gone.  Hard to describe more accurately than that.
Mark, my rack now has a bunch of on-center slop.  However, both of my inner tie rods are totally shot too so that may be part of the issue.  I do suspect that the stock rubber subframe bushings aren't doing any favors for steering response either though.
Honestly, the rack wasn't bad to remove.  I did remove the sway bar because I had planned on replacing it with another one I had cleaned up and putting in new poly bushings. Unfortunately, I ordered the wrong size bushings so that didn't happen either :glare:
The hardest part was removing the u-joint and the line fittings.  The u-joint was easy once I used an air hammer to drive it upwards.  The fittings were problematic because initially I didn't loosen the front subframe bolts and couldn't sag the subframe enough to turn the wrench.  After I loosened the front bolts, there was plenty of room to work.
Now, that being said, it was very easy to remove the subframe.  The picture of me working on the u-joint was taken about 10 minutes after I decided to remove the subframe.  Getting the rack/subframe back into the car was a bit of a fiasco due to late night frustration/exhaustion but whatever.
Just drink a beer. or 6. It will make everything better.
Truth. Plenty of beer has been consumed, and all is better.
Old rack came out easily
3A64D078-934D-4D68-8CF0-22D62B38D84B_zps
New one went in with no problems. Had to use bolts/nuts instead of the OEM studs on the rack because the rebuilt rack didn't have the brass bushings to hold the studs in place.
96DCC2CE-6E1D-4846-B1ED-7EE0B739A955_zps
Put a whole bunch of new OEM parts in too - PS return line, outer tie rods, steering column u-joint, and 05+ PS reservoir. The 99-04 reservoir swells up and leaks over time, the revised 05+ reservoir doesn't do this. The line locations are different between the 2 reservoirs - you can use the 05+ feed line that runs between the pump and reservoir, or you can trim the factory hose to fit. I trimmed my factory hose to fit. The return line works fine.
E0451E01-239E-4CF6-A320-F06D7F1A06DE_zps
Replacing all the steering components made a noticeable difference. On-center sensitivity is improved, there is less bump-steer, and steady state cornering is more stable.
A61FA7F4-1396-4D72-A2B1-B6C8143A599A_zps
  • Upvote 2
1 hour ago, apeacock said:
still itching to swap my wagon, everyone else is doing it!
Come to Troy, NY, where we can swap your wagon in a couple days.
It's like we've done this before....
You guys still have a door there for my parents xc wagon lol
Hey I drove to Massachusetts to swap my wagon and I'm from the Midwest. Just ask Tom and Brandon. Haha
Auto V70R wagons are lethargic. They really need a 6 speed.
Mine will never have one...
Hmmm $1500 for manual in my beat A$$ R or $1500 into suspension and brakes on the M3..
Edited by Dick Dastardly
word filter because I am a cheapMotherF**ker this year
  • Similar Content
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By lowbudgetracing
    • By andyb5
    • By cryptophilosopher
    • By apeacock
      1999 V70 R - Needed a VS build thread.
      Wagon is a Canadian, originally tested by a rental car company and thankfully for me was rejected. Purchased in 2012 I'm the third owner. Vehicle thad a full service history that would put other anal Volvo owners to shame.
      Mods list run down
      Suspension/Brakes:
      Ohlins Road holding kit Front - Rebuilt by PSI, Performance Shock Inc in California.
      Ohlins Road holding kit Rear
      TME Awd Springs -
      IPD Front 25mm Sway bar
      IPD Rear Bar
      IPD Strut tower brace
      Solid-ish Top engine mount
      Poly Firewall Mount.
      Ceika 330mm large 6pot Front set  -Street Grey Pads
      Porsche 330mm 4pot rear brakes  - Textar Porsche 996 Pads
      Engine/Exhaust:
      Stev0 Tune running 20-24
      BW EFR 7064 Turbo Smart CBV and Dual port wastegate
      Snabb Reverse intercooler piping kit
      Custom Inlet tube mated to 3.5" maf housing
      VR exhaust manifold - Milled Flat to fit T3 Turbo
      Custom DP from Aaron
      Magnaflow rear mufflers
      Do88 intercooler -
      Do88 Rad
      Wheels:
      Borbet LV5 with Bridgestone Potenzas.
      Many thanks to Bmac,Steve, Hussein, and anyone else for answering the endless questions.
      Day 01:
      Car came with its drive shaft pre-removed but included. 12 total wheels and tires, a brand new set of R mats in the volvo box, and a stack of service receipts totaling 26,000 CAD.
      Purchased at 121,000 miles currently 152k on everything.
      March 2014 - Acquired many nice parts through the winter. Met Bmac and got everything installed and then had Steve tune it the same evening. Long day but everything has held together like new since then.
      Snabb kit was a oh yeah! to install, lower pipe need to sit just right to make it all work.
      18" of space was nice but we almost needed more.
      Clamshell was not surprisingly rusted closed.
      ugly ugly welds but it went in perfectly. Did require cutting the old downpipe to clear the angle gear.
      Bens BIG turbo
      Manifold and turbo and exhaust removed.
      Nice new nuts and reused the washers.
      Huge difference in design.
      Sway bars are such a nice improvement on this car
      Reused a front bar from VS, rear can be had new without buying the set (just ask)
      Practice Safe Turboing
      May '14
      Tint and Clear Bra - No surprise it doesn't show up in pictures. The Tint Shop of Rochester NY did a great job. Happy to protect the newly painted front end. (barely visible below)
      'Winning' Only two volvos that weekend so I can't be too happy.
      Summer 2014
      Fitting some poly bushings to rattle my fillings out.
      Sticker from the EST customer bbq day
      Nice little paint job under the hood
      Nothing Special but it does the job
      March 2015
      Prep the Front shocks for service
      Found a guide form what what i can't believe is 10 years ago. Thankfully the pictures are still up http://v70r.com/forums/topic/1667-ohlins-strutspring-install/
      Had to get a offset box wrench but it was really the only tool for the job.
      Rear set still brand new in box. Really excited to get this all in and be on the road
      Not sure if VS works this way but Saving this space for suspension and brakes when they go on.
