Andy's 1999 V70 R
50 minutes ago, andyb5 said:
.  Opened the hood to confirm my transmission mount had snapped the same bolt as last time :monkey: Unlike last time, I haven't done anything to provoke this one.  I fucking hate this car sometimes.  Guess I'm going to remake that bracket, because even though it'll take 2 minutes and $0.50 to repair, it's sure as hell really annoying to have this as a recurring issue.
E745DDD1-2A3B-47B4-B5C4-C339C0D1337C_zps
Wait - you mean the M7 bolt at the rear of the trans bracket into the casing split? What grade bolt did you use and what length? Did you helicoil/ timesert the threads in the inner case? I had trouble originally (2008) because the bolt I used didn't go all the way through the rear casing, and worked lose, allowing excess load to occur. Can you elaborate? If there is an issue with the bracket I made, I need to fix it
PM sent.  But yes, that bolt failed, it wasn't on the car when I examined it on the lift.  After the first one snapped off in the trans casing, I drilled out the old one, and put in an 8mm grade 10.9 bolt (~70mm length if memory serves) that went straight through the casing and used a nut on the backside.
Replied to your pm - I need to fix it for you. I apologize for the trouble.
  • Upvote 2
Sweet brakes man, where'd you get them? :wink:
I just reread your thread all over again (slow day at work) and it's making me rather excited to get back into the P80 world. Keep it up bro, I may be at Ben's some time in early March to take a look at a few things. I know you're a short drive away so I'll give you a ring when the time comes if you wanna swing by.
To follow up on the trans bracket issue, Hussein sent me a new trans bracket that had a piece of tube on the end instead of a socket like my first bracket had.  Old on top, new on the bottom.
883691E6-9107-4D9C-9D72-BD3BB3CF2C00_zps
So far, so good.  No issues and the bolt is still holding tight :smile:
A little while ago, I hit a car that was parked outside my apartment's driveway.  I dented up my passenger side rear door pretty good, and bought a replacement door from the 99 R Adam was parting out.  I also purchased the fuel pump assembly, OEM front passenger axle, and a few miscellaneous other parts.
7D340915-A1A6-468A-AB10-E43B5AFCDFA3_zps
Got the door installed yesterday.  I need to remove the pinstripe, but it's nice to have that issue taken care of.
100E1644-894F-45C4-BBA1-2CF5BE0B5097_zps
Today, I pulled the factory sunroof out.  It's been in poor shape since I bought this car, and I've had a replacement waiting to be installed for a while now.  The seal at the edge of the glass had separated from the glass, allowing water to enter and creating a ton of wind noise.  I've run a bead of silicone around the edge of the seal a few times to stop the leaking, but it was never 100% effective.  You can see the silicone as a dirty ring inside the edge of the sunroof.
132F0308-7B9B-4D98-8C9D-33ACDF2470ED_zps
176AB950-0BB3-4A3C-ABAB-CF864128315F_zps
The inside frame had become quite rusty as a result of years of water entering where it shouldn't be
49121C0F-F8D9-4F1A-86BF-7C141B1D9AB9_zps
46B3F225-3F65-4576-812B-A8D3DBF3CBE9_zps
After successfully removing my sunroof trim (without breaking it) I tore the rest of the interior out to get the headliner and sunroof cartridge out.
5EFD2053-82F6-49E8-8921-FAA456B2ACDA_zps
The sunroof is fairly heavy and awkward to maneuver, which makes this is a pretty crappy job to do by yourself (like I did).
DA5BEDC7-D253-4384-BED9-4E56895F47E8_zps
In terms of function, nothing is different than it was before, but the reduction in wind noise and knowing it won't leak has already made regular driving much more enjoyable.  With most of the interior out, I was able to eliminate a few squeaks/rattles, and adjusted the tailgate latch the hold the door tightly and stop it from rattling over bumps.  Small things, but they make a huge difference just in driving around town.
  • Upvote 6
Impressive to get it out by yourself. I did this job in my s70 and it was very much a two man operation. Maybe in a wagon you could lay down and hold it with your feet while removing the front bolts.
Nice work!
This reminds me, I have my sunroof panel that I refinished & resealed. I'll have to bring it to Carlisle. :)
no, you just gotta use your head man ... literally :)
I've been driving without a front swaybar for the last 9 or so months. The stock front bushings combined with the car being lowered repeatedly killed endlinks. I removed one endlink until I figured out some adjustable endlinks and had an opportunity to replace the stock bushings that had deteriorated over time (thanks oil leaks!)
I had originally planned on removing the factory bushings (that are vulcanized to the bar) repainting my stock bar, installing poly bushings and adjustable endlinks when I replaced my PS rack last fall. In the comedy of errors that is my life, I ordered the wrong size poly bushings and wasn't able to reinstall the bar. I've just driven the car without a sway bar since then. The body roll was annoying but not awful. The nice part was how close to neutral the chassis balance was; understeer was almost totally gone.
The other night I finally got it all installed and it's ridiculous how much less body roll, and the shift back towards understeer is less pronounced than I expected.  Sweeping ramps and twisty roads are significantly more fun to drive now
E8370915-20C0-42A0-8914-56B8FC7403C3_zps
Stock 21mm bar with Energy Suspension poly bushings.  The Teflon tape is a little trick I picked up from motoiq.com to  help reduce friction when installing poly suspension bushings
ECF30AA0-7C4D-48BE-81E3-C64B191B341A_zps
The endlinks are (hopefully) my solution to having a nice adjustable endlink that won't be a pain to maintain like QBM style ones are. Having experienced firsthand the issues that heim joints have on daily driven cars here in the northeast, I didn't want to use heim joints; even with rubber boots they're destined to fail.
FF0671BF-AF73-412B-B459-F208623F9031_zps
By maintaining the stock style rod-ends, I'm hoping that I'll keep a good service life. I simply chopped a few inches out of the endlink, and then threaded one half with a RH thread and one with a LH thread to match the turnbuckles I bought at Lowes. Add a couple jam nuts, and they're done. The cost came out to be about half of what a "QBM style" heim joint setup would cost. Admittedly, since this was kind of a "proof of concept" run, I used a set of cheap Karlyn endlinks so I'm not sure how they'll hold up, but in the case that I totally screwed up and destroyed them, I wouldn't feel bad about wasting nice parts :laugh:
275CEC28-7A25-4C88-A1D2-6922F553B7FB_zps
(The black paint is so my pea brain could quickly ID which end was LH thread)
  • Upvote 4
Fancy solution! Welcome back to having a front sway bar. And, the body roll was really noticeable by the way. Now you'l hit the tree forwards instead of backwards (according to Top Gear)
:laugh: Thanks man.  I'm still working on ways to hit the tree backwards again!
Got an alignment for the first time since buying the car :huh: but my front bumper was too low to get onto the lift.
2D3A53DC-DDC7-4042-B604-5F9AAE466287_zps
I've spent entirely too much time dealing with axles the past few months:
First, I went to install the OEM passenger axle I bought from Adam to replace the junk Advance Auto one I installed last November  (OEM top, Advance bottom)
334FBD53-0DD8-43C8-A63D-F2A4BE480804_zps
And found one of my lug bolts had snapped off in the hub.  To add insult to injury, it snapped off in the wheel bearing I had replaced last November.  I tried unsuccessfully to drill it out and use an extractor, but all I did was break the extractor in half :monkey: :mad:
So I took the hub off and installed my old one until I can get a shop to extract the busted lug bolt.
715BB1E0-31FB-4955-BFA5-9BE13E4BE178_zps
My drivers axle split the inner boot the night before the Ithaca Euro Meet
67B31900-83F4-4F64-920B-4E7462B8C51F_zps
The inner boot ripped nearly all the way around, and did a very effective job of slinging the grease allllllll over my formerly nice clean transmission.
DCBB137B-1EBC-46BD-9938-1CDC4758C60F_zps
As far as I can tell it was original to the car, and with ~206k on it, I guess I shouldn't have been surprised that the boot failed.  The timing sure sucked though :monkey:
So I installed a spare axle from Matt's C30, and made the drive on out to Ithaca.  Had a great time seeing everyone out there
39d7a69589af0237a8b16333589f7352_zpsd63d
Rebuilt my axle with OEM boots from Tasca
CC3AB70A-2298-4FC1-BDBE-25B3FCA83541_zps
Tore it down, cleaned everything up, and reassembled it all
A033ED00-A712-46BE-A14B-C28842AF6D3B_zps
77D0F858-0816-4FA0-9B90-06B78B917035_zps
7B3C07BA-AA9C-4C0C-A7D7-E33A96DDA4D3_zps
At some point in the middle of all of this, I moved to a new apartment.  The wagon towed this trailer with great ease - between the Brembo's and coilovers/nivomats, it was like the trailer wasn't even there.
48F46BB7-E920-4A76-85AB-BAD1CB3E7665_zps
I also bought a remanufactured driveshaft from a 00 R that has the larger (more durable?) carrier bearing so my wagon is now AWD again.  One slight modification is needed to run a 00 R driveshaft in a 99 R.  The 00 carrier bearing bolt hole spacing is narrower than the 99 carrier bearing, so one hole needs to be redrilled.
F6597449-6A60-42AB-B76C-FAEAA4214D63_zps
  • Upvote 2
Good to know on that because I have a '00 plate I want to replace my rusty 99 one with. Looks Easy and quick though.
  • Similar Content
    • By zman172
      Box #1
      Steering wheel
      Trunk hatch carpeted trim
      Center console
      Box #2
      A/C compressor
      Windshield wiper motor
      Accelerator pedal
      Fuel door lock solenoid
      Navigation Antenna
      Ignition immobilizer
      Ignition switch starter
      Turn signal stalk
      Sensor alarm
      Seat belt restraints (x2)
      Door sill plates (x2)
      Metal radio pocket
      Volvo plastic radio pocket
      Radio
      A/C control unit
      Side view mirror left
      Servotronic fuse relay
      Trunk latch
      Windshield wiper stalk
      Overhead light driver front
      Rear bumper trim (x2)
      Dashboard trim
      Instrument border
      Rear speaker covers
      Driver motor seat controls
      Passenger motor seat controls
      Gear shifter
      Steering wheel column cover
      Center console trim (x2)
      Front cupholders
      Master cylinder
      Box #3
      Side view mirror right
      Fuel pump regulator
      Overhead dome light rear
      Windshield rain sensor
      Tan headrest with long spikes
      Rear armrest with cupholders
      Power steering pump tank
      Right upper brake light
      Right lower brake light
      Armrest for front seats
      Driver window switch box
      Front passenger window switch
      Airbag sensor
      Rear speakers (x2)
      Box #4
      Side airbags (x2)
      Spare tire
      Rear fuse relay box
      Rear third brake light
      Emergency brake with leather
      Rear trunk speaker trim (x2)
      Right rear trunk carpet trim
      Box #5
      All 4 door panels
      Rear bottom single seat
      Single seat leather upper
      Double seat leather upper
      Right front carpet
      Left front carpet
      Drivers front seat
      Passenger front seat
      Rear trunk hatch trim
      Box 6
      Braking systems (x2)
      Glove box
      Emergency brake trim (x2)
      Center console back plate
      Passenger lower dash cover
      Floor door trim (x2)
      Front door handles
      License plate frame
      Seat railing covers
      Box 7
      Instrument cluster 163000
      Radio trim
      Shifter trim
      Rain sensor cover
      Dash radio storage box
      Fuse panel cover
      Gas tank cover
      Front air bag crash sensor
      Rear air bag crash sensors
      Air bag impact sensor
      Headlight switch
      Hazard light switch
      Dashboard airbag
      Ecu
      Box 8:
      Miscellaneous
      On pallet not in box:
      Door pillar vents (x2)
      Torque rod
      Trunk pillar covers (x2)
      Left side skirt cover
      Right side skirt cover
      Trunk trim no cut out
      Dashboard
    • By lowbudgetracing
    • By andyb5
    • By cryptophilosopher
    • By apeacock
      1999 V70 R - Needed a VS build thread.
      Wagon is a Canadian, originally tested by a rental car company and thankfully for me was rejected. Purchased in 2012 I'm the third owner. Vehicle thad a full service history that would put other anal Volvo owners to shame.
      Mods list run down
      Suspension/Brakes:
      Ohlins Road holding kit Front - Rebuilt by PSI, Performance Shock Inc in California.
      Ohlins Road holding kit Rear
      TME Awd Springs -
      IPD Front 25mm Sway bar
      IPD Rear Bar
      IPD Strut tower brace
      Solid-ish Top engine mount
      Poly Firewall Mount.
      Ceika 330mm large 6pot Front set  -Street Grey Pads
      Porsche 330mm 4pot rear brakes  - Textar Porsche 996 Pads
      Engine/Exhaust:
      Stev0 Tune running 20-24
      BW EFR 7064 Turbo Smart CBV and Dual port wastegate
      Snabb Reverse intercooler piping kit
      Custom Inlet tube mated to 3.5" maf housing
      VR exhaust manifold - Milled Flat to fit T3 Turbo
      Custom DP from Aaron
      Magnaflow rear mufflers
      Do88 intercooler -
      Do88 Rad
      Wheels:
      Borbet LV5 with Bridgestone Potenzas.
      Many thanks to Bmac,Steve, Hussein, and anyone else for answering the endless questions.
      Day 01:
      Car came with its drive shaft pre-removed but included. 12 total wheels and tires, a brand new set of R mats in the volvo box, and a stack of service receipts totaling 26,000 CAD.
      Purchased at 121,000 miles currently 152k on everything.
      March 2014 - Acquired many nice parts through the winter. Met Bmac and got everything installed and then had Steve tune it the same evening. Long day but everything has held together like new since then.
      Snabb kit was a oh yeah! to install, lower pipe need to sit just right to make it all work.
      18" of space was nice but we almost needed more.
      Clamshell was not surprisingly rusted closed.
      ugly ugly welds but it went in perfectly. Did require cutting the old downpipe to clear the angle gear.
      Bens BIG turbo
      Manifold and turbo and exhaust removed.
      Nice new nuts and reused the washers.
      Huge difference in design.
      Sway bars are such a nice improvement on this car
      Reused a front bar from VS, rear can be had new without buying the set (just ask)
      Practice Safe Turboing
      May '14
      Tint and Clear Bra - No surprise it doesn't show up in pictures. The Tint Shop of Rochester NY did a great job. Happy to protect the newly painted front end. (barely visible below)
      'Winning' Only two volvos that weekend so I can't be too happy.
      Summer 2014
      Fitting some poly bushings to rattle my fillings out.
      Sticker from the EST customer bbq day
      Nice little paint job under the hood
      Nothing Special but it does the job
      March 2015
      Prep the Front shocks for service
      Found a guide form what what i can't believe is 10 years ago. Thankfully the pictures are still up http://v70r.com/forums/topic/1667-ohlins-strutspring-install/
      Had to get a offset box wrench but it was really the only tool for the job.
      Rear set still brand new in box. Really excited to get this all in and be on the road
      Not sure if VS works this way but Saving this space for suspension and brakes when they go on.
