Finally got around to cutting the hood & installing the Elevate vents. Set them as far back & out as is possible without compromising the inner framework.
took about 12 dremel cutting discs. Tried a angle grinder, but it burns the paint too much...
had to cut the inner lateral support
passenger side I drilled the tab holes before cutting, easier that way
both sides - just ordered 5 sheets of 18x32" Dynamat Extreme - don't want to put my crusty hood insulation back...
grilles installed - think I will have to remove & paint the lip - not sure I like the silver inner edge that's visible
