'95 850 - Shimmy Between 50 And 60Mph
850 vibrating shaking 50 mph 60 mph
6 replies to this topic
#1 VS Legend
VS Legend
    Has a Member Title
  • 6,918 posts
Posted 11 April 2012 - 04:45 PM
I remember this being something that used to come up from time to time. The 850 will shake / vibrate a bit from 50 - 60mph on smooth highway. Everything is fine below 50mph and above 60mph. I'm trying to remember what it was that caused this, but I can't find it because there are so many threads with similar descriptions of other problems. If my memory serves me correctly, it's usually the balance, tie rods, or control arms. If anyone can confirm or deny it would be much appreciated!
Thanks, guys!
2007 Volvo XC70 Daily Driver Steel Cargo Barrier, Cargo Cover, Parrot Bluetooth, USA Spec Adapter w/ Repurposed Mountek nGroove Mount, Pioneer A-Series 6.5" 350W 4-way Door Speakers
#2 MattyXXL
MattyXXL
  • 2,455 posts
Posted 11 April 2012 - 07:11 PM
sound like the tires need to be balanced ;)
1996 854 T-5 Modded, But who really Cares
1995 Yellow 854 T5-R Bone Stock!
http://www.floridavolvocommunity.com/
#3 VS Legend
VS Legend
    Has a Member Title
  • 6,918 posts
Posted 11 April 2012 - 09:42 PM
Problem is they were just balanced, but I'm sure dealer will recheck balance before going to other things.
#4 survolvo
survolvo
  • 2,912 posts
Posted 11 April 2012 - 10:00 PM
Ive had this problem plaguing me. I can't tell you how many times i have gone to the shop and they tell me everything is balanced. Not just one, but 3 different shops.
Have replaced everything but the rack, but thats next. Hopefully it will fix it. My fix is to go 70 everywhere. ;)
1996 854 T5
M56h w/ R Clutch, NA Intake Mani, Snabb Phenolic Intake Spacer, NA Throttle Body w/ 960 Plate, Snabb Intake Pipe, Custom CAI, NA Cams, S60R Exhaust Mani, 16t w/ Whites, iPd TCV, ARD Lightwieght Crank Pulley, +99 Oil Pan/Cooler, Kingsborne 8mm Spark Plug Wires, 302mm Front Brakes, Volvo Strut Tower Brace, Konis, IPD springs, few more things to come...
#5 MattyXXL
MattyXXL
  • 2,455 posts
Posted 12 April 2012 - 11:16 PM
What dealer are you going to? Englewood volvo?
thats where i bought my 850... I picked up the car told him the ride height seemed high, he said the shocks just need to settle.. Took it around the block and the ride was stiff and not at all like the one I test drove... Went right back and told them something wasnt right.. they pulled it into service and put it in the air... the spring spacers were still in it, they never took them out during the PDI..
From then on I took the 15 min drive to Ramsey volvo instead.
Know it was kind of a rant but, id get them checked at a good year or firestone.
It could be an axle out of balance also... maybe? possibly??
#6 Serge
Serge
    Level 6 Senior Member
  • 10,834 posts
Posted 12 April 2012 - 11:28 PM
Does this happen when you are accelerating or while coasting as well?
If all your suspension components check out, I'd also check: wheel hub and axles.
Serge - 95 850 T5
#7 Turbobucket
Turbobucket
  • 47 posts
Posted 20 April 2012 - 06:31 PM
I had this problem too. It was my tires. Rotate front to back and see if it goes away. My 850 seems to be real sensitive to worn tires and the vibration always comes back when it is time for new tires.
