95 850 Wagon - Project Dd
33 replies to this topic
#1 REUBS4
REUBS4
  • 43 posts
Posted 24 April 2012 - 12:35 AM
I needed a place to post pictures, progress, to ask questions, get advice and of course get flamed. Originally had hopes of doing a turbo swap, however, this car has an LH3.2. Had it been the Motronic 4.3.. I probably would have pushed onward despite all the issues others have had trying to make it happen... see http://volvospeed.co...ap#entry2003390
So, anyway, 95 N/A 850 wagon with LH3.2 and an M56 250k (ish) on the clock, blown head gasket or cracked head/block. The goal is to make a nice looking, reliable DD. This is a second car, and doesn't get as much of my time as I would like, so needless to say, my progress is slow. Not really sure what the overheating issue is with the original motor (will tear it down at some point to find out) so rather than fix it, I opted to pull a motor at the local JY. Ended up with a N/A motor from a 98 S70 with closer to 150k. Debated tearing it down and going "stage 0" but since it was only $100 for the motor, and compression seems to be ok, I figured why not give it a shot and see how it goes.
So far:
Original motor removed
Engine bay deep cleaned (what a mess)
Cleaned new motor up
M56 moved to new motor with new clutch and new rear main seal
Gasket matching on intake and exhaust ports
Painted valve cover and intake mani
New oem plugs
New timing belt
Various other accessory items moved over
To do:
Finish slapping on all the accessories I can before the motor goes in (this includes new thermostat and PCV breather system)
Paint engine bay
Put in new engine mounts and poly bushings
Get the engine in the car, hooked up and see how she runs
Prep and paint Volans
Prep and paint car
There are many other things on my "want to do" list, eventually they will happen.. but for now the goal is to get it running right and looking halfway ok.
I haven't taken as many pictures as I should have.. but here's what I have now. More pics and progress to come.
95 850 Wagon | 01 Audi S4
#2 gmsgltr
gmsgltr
  • 5,289 posts
Posted 24 April 2012 - 12:43 AM
tell me more about the s4! :)
- Greg - '96 Red/Tan 855 R - M - 102k miles -
#3 REUBS4
REUBS4
  • 43 posts
Posted 24 April 2012 - 01:18 AM
...and since I'm either too retarded, or do not have the option, to edit a topic that I created... here are the 3 pics +1 with dead links from the original post:
#4 REUBS4
REUBS4
  • 43 posts
Posted 24 April 2012 - 01:27 AM
The S4.... is an 01, 6spd, with a stage 1 GIAC tune, SSAutochrome catback, R1 Diverter valves, riding on H&R springs(wish I could get that low with springs on the 850) It needs some "stage 0" loving, which it will get once the 850 is on the road.
#5 gmsgltr
gmsgltr
  • 5,289 posts
Posted 24 April 2012 - 01:34 AM
sweet ^^^ would have one of these if i didnt have the 850r
love the b5 s4 specifically the avant
#6 REUBS4
REUBS4
  • 43 posts
Posted 24 April 2012 - 01:38 AM
Thanks, I think it's pretty sweet myself.. and it certainly gets up and goes. I would have purchased the avant if I could have found one when I was in the market. But this one had low miles.. one owner.. and it was a Vegas car (never saw winter) couldn't pass it up.
#7 laird
laird
  • 1,541 posts
Posted 25 April 2012 - 01:35 AM
Who is the old guy working on your car :)?
5/7th of my family aboard "Allure of the Seas"
1997 850 R, 1999 S70 NA, 1998 V70 NA, 1969 MGC, 2007 PILOT
#8 Tommy.
Tommy.
  • 5,729 posts
Posted 27 April 2012 - 12:18 AM
Nice project, I need to do some engine bay cleanup and painting like that this summer.
#9 REUBS4
REUBS4
  • 43 posts
Posted 27 April 2012 - 04:00 PM
thanks for all your help Pop
thanks. If I had the patience.. I'd do more, like tucking etc. $500 car, not gonna be too fancy.
#10 Daisy_854
Daisy_854
  • 68 posts
Posted 29 April 2012 - 02:06 AM
I love looking at pictures of a job that was also done to my car yesterday, with out the M65 of course but I just had my n/a motor yanked yesterday to begin my turbo swap.
Your paint looks great!
#11 laird
laird
  • 1,541 posts
Posted 29 April 2012 - 09:02 PM
As an aside, Reuben is sticking with the 95 header which is sigificantly different from the later models. It appears to have, more or less, equal length tubes. The tubes may be a bit longer than later models and that may affect upper end power somewhat. After fixing up the exhaust to make it louder, (= faster right?) this baby will fly! (right out of my driveway to his place I hope) He has spent quite some time on gasket matching the intake/exhaust ports as well as the intake manifold. I have no doubt that this will yield impressive yet imperceivable results but the work sure looks nice:)
If the JY engine works at all it will be a bonus and if not, the variable intake manifold looks interesting and an NA rebuild will begin.
#12 REUBS4
REUBS4
  • 43 posts
Posted 29 April 2012 - 09:22 PM
Thank you, I'm having fun with it
#13 Daisy_854
Daisy_854
  • 68 posts
Posted 30 April 2012 - 07:23 PM
Thats that matters the most.
#14 boxpin
boxpin
    Old Man Crew Psyllium pusher
  • 1,613 posts
Posted 30 April 2012 - 08:22 PM
Just described 50% of the VS community.
20G, ARD Black, 342whp/403bhp
#15 REUBS4
REUBS4
  • 43 posts
Posted 13 May 2012 - 12:16 AM
Old PCV system was packed full of crud. Replaced it with a new one.
Engine is all ready to go in.. still need to do some things in the bay before it can happen.
#16 survolvo
survolvo
  • 2,912 posts
Posted 13 May 2012 - 06:16 AM
Looks good! Just missing something coming off the exhaust manifold. ;)
1996 854 T5
M56h w/ R Clutch, NA Intake Mani, Snabb Phenolic Intake Spacer, NA Throttle Body w/ 960 Plate, Snabb Intake Pipe, Custom CAI, NA Cams, S60R Exhaust Mani, 16t w/ Whites, iPd TCV, ARD Lightwieght Crank Pulley, +99 Oil Pan/Cooler, Kingsborne 8mm Spark Plug Wires, 302mm Front Brakes, Volvo Strut Tower Brace, Konis, IPD springs, few more things to come...
#17 REUBS4
REUBS4
  • 43 posts
Posted 13 May 2012 - 05:51 PM
sad but true... that's what the S4 is for ;-)
#18 matt b
    Earth Day-Every Day
  • 15,737 posts
Posted 14 May 2012 - 05:29 PM
Looks good. Nice of you to let the local senior citizens work on it too, I'm sure they appreciate it.
Nice to see such a clean engine, looks good.
#19 REUBS4
REUBS4
  • 43 posts
Posted 14 May 2012 - 10:35 PM
oh he's not that old, haha! And thank you, wont be fast, but should look pretty decent when it's done.
#20 REUBS4
REUBS4
  • 43 posts
Posted 20 May 2012 - 01:23 AM
Got the bay stripped down, scuffed up, and painted.
Hopefully within the week, I'll be able to get the bay put back together, and with any luck, get the engine in.
