Ard Tune: Launch Control
Posted 25 April 2012 - 04:43 PM
The bulk of this conversation will be around manual trans but I was working with Cliff M. (RIP) on the autos so perhaps we can start on that again.
So what is launch control?
The initial idea behind it is to pre-spool the turbo a bit to provide quicker on set of boost at the track or off a stop light to maximize the power buildup and get off the line faster.
How does it work?
Launch control is active any time the engine is between 3200-3600 rpm and sees less than 7% load (Basically clutch in and engine freerevving up to 3200-3600rpm.
What does it do?
When active launch control adds fuel, reduces the timing and Duty cycles the TCV to encourage the turbo to spool by igniting the additional fuel in the exhaust manifold which in turn causes the the turbine to increase in speed ultimately bringing the turbo up to the boost threshold faster and sooner. This is similar to anti lag but not as aggressive or as hard on the motor.
What models is it available for?
All manual models 1994-1998 for now. Automatics in the future, will be more like power brake activated launch control. ME7 will have this option as well but we'll start with M4.x first.
What's the cost?
For those with and ARD Tune the added launch control feature is $150
Can it be added via the ARDVARC?
Yes however we won't be initially offering it for remote ARDVARC loading right off the bat.
Is it 100% perfected?
No, were about 90% where we want to be but for each setup the launch control requires some slight adjustments so a bit of tweaking is still required.
The purpose of this thread is to get more input and ideas around launch control and see what folks do and don't want and if this is even worth pursuing.
All input welcome!
Thanks guys
Posted 25 April 2012 - 04:53 PM
Just so I properly understand, this doesn't also pre-load the drivetrain (since the clutch is disengaged) correct? Some pre-load would be what I would want, to minimize the abrupt drivetrain slack take-up & subsequent wear/potential breakage (lol).
1998 V70 XR M66 Quaife 14J PTE6262 BB Built '04 2.3l Block Wiseco Pistons 147mm H-Beams '03 Ported Head EnemY21Cams TurboTuner 710cc Inj, DW300, 3" DP back Dual Magnaflow 14834's Apr 2013 408WHP AWD (@7925rpm) 347WTq(@4400rpm)@18psi LGSpeed Header Custom Intake Manifold 30x12.5x3.5"Treadstone FMIC AP Racing Clutch KU SM Billet Flywheel Kaplhenke CoilOvers
Posted 25 April 2012 - 05:04 PM
Only way I can think of preloading, or taking out driveline slack is catching the brake peddle a little bit and allowing the car to move forward a very small amount.
Clutch won't last long though. :-/
Edited by 550, 25 April 2012 - 05:10 PM.
Posted 25 April 2012 - 05:33 PM
Granted it's still going to be easier on the drivetrain than side stepping the clutch. Launch control is for the fastest/smoothest off the line start so you can build boost and maintain traction.
Posted 25 April 2012 - 05:37 PM
Posted 25 April 2012 - 05:39 PM
im in of course lucky, once i do the 5 speed swap though lol
edit: how does this differ from a wot box and the no lift shifting and 2 step etc?
- Greg - '96 Red/Tan 855 R - M - 104k miles - '98 Blue/Charcoal V70 T5 - M - 170k miles -
Posted 25 April 2012 - 06:20 PM
Watching Justus take off the line with the 60 trim is hilarious. I know the initial shock of the boost hit may be a good thing with launch control, but I still see, even with a LSD upgrade of some sort, there being issues getting off the line.
Posted 25 April 2012 - 06:28 PM
Half of it is for fun and for play, not all folks will want or need it but it is cool to have it
Posted 25 April 2012 - 06:31 PM
Posted 25 April 2012 - 06:32 PM
Ian Carr - 09' C30 T5-Polestar Tuned - (Sold)99' Volvo S70 T5M
Posted 25 April 2012 - 06:51 PM
All depends on the setup, for larger turbo guys it's quite helpful to combat lag and even for stock cars you can get some quicker times if you modulate throttle well.
See that's the thing, there is lag, but it's almost necessary to even get off the line. Because when that boost hits... all hell breaks loose lol. And your traction doesn't exist.
Only reason I want to do launch control on the 242 with MS, is because it is a "showy" thing LOL. But hard need much when traction is already a joke.
Edited by 550, 25 April 2012 - 06:52 PM.
Posted 25 April 2012 - 07:40 PM
Flat foot shifting could certainly be doable as well, is that where this is heading???
Posted 25 April 2012 - 07:59 PM
1997 854 T5M - Megasquirt 2Extra with COP
#14
Posted 25 April 2012 - 08:01 PM
Please forgive my ignorance, but what if there was an exhaust leak? Could you put fire where you don't want it?
Also.... what does this do to EGT's? I'd assume it'd be wise to monitor to avoid cracking a turbine housing.
1998 V70 R AWD - M66 & 2.5T RN swapped
2007 Dodge Ram 1500 QC (Daily)
#15
Flat foot shifting could help me, but not by much. I can really only see it being a benifit for drag racing.
#16
Posted 25 April 2012 - 08:07 PM
No different than running full throttle. Your exhaust is still burning in the exhaust system. My spider with open header will be shooting flames out of the end of the header 2 feet from the head.Please forgive my ignorance, but what if there was an exhaust leak? Could you put fire where you don't want it?
EGTs shouldn't be anywhere near what you would get at full boost.
#17
Posted 25 April 2012 - 08:18 PM
#18
Posted 25 April 2012 - 08:23 PM
1998 S70 GLT-5 427 / 1998 S70 T5M 019
#19
Posted 25 April 2012 - 10:41 PM
98 T5M, IPD ECU, OBX Turbo back, KW Variant II coilovers, 17x8 OZ Supperleggeras, Snabb pipe, Short shift kit, IPD Sway Bars, IPD Strut Brace, blah blah blah and more to come for sure aka - MADSPEED
#20
Posted 25 April 2012 - 11:10 PM
