Uncle Boost
Drl Mod / Disable
I know this has been beat to death....While I had my S80 @ the dealer to have a new remote and key programmed, I asked them to turn off the DRL's.. I was standing there when the Tech brought all the modules up on the Screen.. I got a Freebee ETM update, as it showed mine is Failing...@ 73%.. Well, when he went to disable the DRL's, that option was NOT highlighted..as in "Not Clickable" on the screen.. He was hooked into Vida/ Dice etc... 2 techs couldn't figure out why that option to click on DRL was not functional.. Any Ideas? Such a PITA to have lights on all the time.. I know about the safety and all that... but it doesn't matter if you have lights on or not around here...people still drive like dumb@sses...I have a need to be Stealth sometimes with rental houses and Thieves lurking around properties..so I like to catch'em at Gun Point and call the meat wagon to haul them in...kinda hard to do lit up like a landing airplane 24-7.
I'm at the point of connecting an inline switch to the fuse... I don't need lights on all the fricken time..ha haha.. I have HID's in the headlights and the Fogs.. Did the Shunt mod so that nagging Bulb warning is nonexistent now..So any Ideas why the option to turn off the DRL's thru Vida wan't "Clickable" in the program?
-=UB=-
i know on my s70 there is a set screw below the headlight switch that turns them off, i turned it to the left and they are off, i hate drl's, 850's may be the same, not positive.
yeah My 855r had that screw..I turned it and Off Presto!.. no such a luxury on this s80
Why is this in Performance and not Cosmetics?
Well I know you have an s80 but. I have a question did all the models have drl or were there models that had the option to turn off. the reason I ask is on my 850 i changed my light switch to an earlier model which could turn the lights off all the way or I could leave them switched on and the lights would turn off with the ignition.
Mine did not have DRLs and was a 99. My dad has an 02 and it has DRLs.
Yours didn't have them at all, or you were able to disable them?
Here you go. The default setting is flexnoll. Switch it to flexstd and click program. No more DRL :tup: .....
i know on my v70 there is a Light sensor under the CC unit.
The little sensor underneath the "feet vent" selection button. if you cover this on my car, i used a tiny piece of electric tape, the DRL's shut off. maybe its the same on your car.
Holy Smoke!!!! Thats Exactly what i was looking for!!! I need to show the dealer this...I forgot but the screen they were on but this looks familiar...the "Daytime running light" box was a light gray, and inactive I think...either way, I'll show them this cause its on my receipt that they were supposed to do it and charged me the same..I looked this morning... I'll be back in touch with results.. Now is this Doable with a Vida/ Dice unit or does this require VD with Volvo interaction? A Download....? Thanks! Very informative here.. and Sorry for putting this in the wrong Category.. my bad.. U guys Rule man..
hahaha..man..I wish it was that easy.. even at night they come on.. I'm like Whats the point of having a switch is the Sh!t is Hardwired with No control other than switching between parking lights and headlights?.. I think this option sux.. People complain about shortening bulb life, and the rebutle that that isn't true is beside the point.. Ballast get hot and Burn up.. no one mentioned that.. Even though ballast (Non OEM) are cheaper now, I bought a case of 100 Xantec ballasts directly from China very cheap and made a ton of $$$ off of knuckleheads around here...but I use them in my 850r and my S80 and only had to replace 1 because it got hosed and shorted out.. I have had one heat up on me, but I swapped it and presto no more problems..(That was a weird one).. but..I'll try that tape thing..
No download purchase is needed, it is done directly through Vida.
I do have an original Dice and pay a yearly subscription, but I would assume it could be done with a clone Dice also?? :unsure:
if you don't mind me asking where is the screw? anyone have a picture of the screw on the s70's?
bottom right corner of the switch. Pretty sure that the position shown is for DRLs, and that you should turn it ~45 degrees left to disable them.
  • Similar Content
    • By Ghost Shadow
      So you want Dice to scan your 99 and newer volvo? You want to disable the DRL's? You want to reset the SRS light because you remove the climate control unit in you 01+ S60/V70? You want VIDA so you can know how to repair your vehicle like the pro's do but in your garage at 2:00am? You just a tool whore? You have nothing else better to do and just want to have it just in case you may need it some day?
      If any of those apply to you, read on but first....
      YOU WILL NOT GET NOR WILL YOU PUBLICLY POST SHARING OF COMMERCIAL SOFTWARE FROM THIS SITE!!!
      You will need to get the following
      Windows XP Pro or Windows 7 Pro 32 bit. No Ultimate, No Vista, No Home, No 64 bit
      Dice scan tool found here http://www.aliexpress.com/product-gs/437145144-DHL-FREE-SHIPPING-Wholesale-2012-hot-sale-Volvo-Vida-Dice-2011A-professional-diagnostic-tool-Best-price-wholesalers.html
      Microsoft Core XML Services (MSXML) 6.0 file name msxml6.msi http://www.microsoft...ls.aspx?id=3988
      Microsoft SQL Server 2005 Express Edition file name SQLEXPR.exe http://www.microsoft...s.aspx?id=21844
      PC Rquirements are 16GB of drive space, 2GB ram and some sort of fast processor. i bought this http://www.asus.com/...rformance/X54L/
      Internet Exporer 8.0 or newer
      First up ordered the Dice. It came in a few days.
      Installation Recipe for a sucessfull install
      Load up a virgin Win7 Pro 32bit, dowsnt have to be a clean install, just something that never had SQL and XMl stuff installed before
      ***NEW**** TURN OFF FIRE WALL AND USER Account Control Settings to OFF
      Install MSXML 6.0, what it does i dont have a clue
      Install SQL Server 2005 Express another, i have no idea WTF it does. When it installed, the setup check for required files and once it past registration the next window was feature selection. Click on the "X" for client components go down to "Entire feature will be installed on local hard drive". Click next and next and next till it installs leaving everything default. After install
      Open Microsoft SQL Sever 2005, Configuration Tools, then open SQL Server 2005 Surface Area Configuration
      There will be two choices on the bottom Click on Services and connections
      Another window opens up and on the left it says SQL server Browser. click on it and on the right you will see start up type highlighted on disabled. change it to automatic
      Install the Vida software. I used 2011A, so i have no clue what other versions do or how they install.
      there will be three choices when you get past the computing system requirements part. If you system meets requirements then it will get you to the three choices
      choose the top choice that installs everything. if it does not error out it will take a good 15-20 minutes to install depending on your system. Go get a beer, you are almost done
      If it ask you to reboot Vida and Vida checks out. reboot
      Once it reboots, here where you need to turn off the internet connection and things get sticky. You need to read the file that came with your Vida disk, usually a read me file
      Before you do what ever the readme files tells you to do, wait for the little vida icon in the task bar to go green. You might also get a eupdate icon too, dont worry about that one.
      Once it goes green then follow the read me file.
      You back from the read me file? Click on Vida-All-IN-One
      Internet explorer will open up with Vida login. Your login info usually is in the readme file on the Vida disk you got.
      Got my DRL's turned off on the 05 V70R last night as well as SUM recalibration...Those are going to be for another topic.
      Got sent a laptop to try and do this. Fussing with it for 2 days and finally figured out that since it was NOT my laptop i did not change notification settings. i left it default. changed firewall to off and user account settings to off. now it loaded fine. ARRG.
