Edited by dublin14, 26 April 2012 - 03:38 AM.
Loud Cracking When Turning Left And Right.
Started by Fudge-Brownie, Apr 26 2012 03:37 AM
7 replies to this topic
Posted 26 April 2012 - 03:37 AM
The last few weeks when I turn the wheel stopped or just pulling into my driveway ect at very low speeds I get this cracking noise. Problem is I cant find where its coming from. On the hoist with the weight off the suspension it doesnt do it. The guys thought its my rack, Im not convinced? Steering knuckle? Suspension is brand new in every way also.
Posted 26 April 2012 - 02:13 PM
Nobody has clue either.
Posted 26 April 2012 - 02:25 PM
First thought that popped in my head was CV joint.
86 Kawasaki Gpz900R Ninja
Posted 27 April 2012 - 01:01 PM
subframe bushings make this noise at wheel lock when turning also.
Posted 27 April 2012 - 04:16 PM
my 93 makes the same sounds, and unfortunately there is so many things wrong with it I can't determine, but it's been going on for many years,just embarrassing when people hear it.
I do know when i greased the steering stops it helped ALOT with the creaks at near full lock, but if i had to guess i would say CV Joints as well. My sound comes from the driver side, as the passenger axle popping sound went away of course upon replacement.
1996 850 R - My Love, Suwanee
VS for life
VS for life
Posted 28 April 2012 - 07:20 PM
I had this problem. Found out I didn't fully torque 1 bolt for the lower control arm to the frame bushing. I got 3/4 of a turn on the right side rear bolt. Noise was gone.
'98 S70 NA Silver Stock 220K
Toronto CAN A DA.
Toronto CAN A DA.
Posted 29 April 2012 - 09:51 AM
Well it turns out the steering rack was loose where its bolted down to the subframe. Got out the air gun and all is well.
. As yes the cause was bolts that needed to be torqued!
That was supposed to be a +1I had this problem. Found out I didn't fully torque 1 bolt for the lower control arm to the frame bushing. I got 3/4 of a turn on the right side rear bolt. Noise was gone.
Posted 29 April 2012 - 12:26 PM
Glad to hear you solved it. Simple solutions are a gem.
Toronto CAN A DA.
Toronto CAN A DA.
