Door Locks Keep Locking Themselves
#1
Posted 30 April 2012 - 02:37 AM
#2
Posted 01 May 2012 - 01:05 PM
#3
Posted 01 May 2012 - 01:41 PM
'95 850 GLT 228k M56H ARD 850R/T5-R STUFF
#4
Posted 01 May 2012 - 01:46 PM
#5
Posted 01 May 2012 - 04:53 PM
1996 854 T-5 Modded, But who really Cares
1995 Yellow 854 T5-R Bone Stock!
#6
Posted 01 May 2012 - 05:14 PM
My guess would be the central locking relay..
yup. sticky contact or something. clean it/replace it and see if it happens again. although on my 95 Turbo it did not have a lock/unlock button on the inside, i believe that is 96-97 850's. i would think that is the culprit.
CHECKMATE
#7
Posted 01 May 2012 - 07:29 PM
Toronto CAN A DA.
#8
Posted 01 May 2012 - 10:40 PM
a broken wire in the door harness, something like that seems plenty plausible.
Don't forget the lock switch in the trunk. That key locks and unlocks, too
And both the 850's and 70 series car have that 30 second "you didn't open any
doors, so I'm locking back up" auto relock feature. But I don't think that's what's
happening with the OP. I'm going with a broken wire somewhere contacting ground.
But, if it only happens when the key is on...It may be the module.
Or it could be a bad remote receiver module. Easy enough to unplug.
Just some ideas. Weird one.
Any aftermarket stuff installed in this car?
#9
Posted 01 May 2012 - 10:44 PM
where is this found?
yea the lock switch doesn't work during this period of locking itself. if i try to unlock the doors with the button it either doesn't respond or it would unlock quick then instantly lock again
If you unlock the doors, the car will lock itself again unless you open a door. This is a timer built into the relay. This may be a clue for you. Do your interior lights come on when you open the driver's door? If not, the relay may time out and lock. There could be an issue with the driver's door lock module. Otherwise, I would remove and inspect the door lock switches on the driver and passenger door. Loose wires, screws, dirty switches are all potential culprits.
850's don't have this feature! ummm i dont usually keep the interior lights in the "door open" position i just run with 0 lights all the time.
so really a simple wire can cause the whole car to lock itself and keep pulsating while the keys in the ignition? thats insane! i dont know if i wanna live with it or trace it aha....is it possible my aftermarket alarm that the bestbuy dudes put in 2 years ago could be screwing around right under the steering wheel?
I'm with Ronny - A funky lock switch, either on the dash or in a door latch,
so i have to open every door basically and check for anything? damn lots of work
umm i know my 850 doesnt have this feature guaranteed its never done it for me nore with the aftermarket alarm has it ever done it
it only happens when the key literally gets put into the ignition, and when its baking outside. if its neg deg weather or chilly it doesnt happen
aside from the alarm any sort of other wiring wouldnt come close to anything to do with the doors
#10
Posted 01 May 2012 - 11:50 PM
Pretty cool feature, especially now that i know you have to open the door. It only does this with the key fob fwiw, with the keys if you unlock it stays unlocked, or atleast i ran into the 30 seconds bizness after i finally got a key fob.
All that aside, when my 93's locks died eventually, i believe this is sorta the similar symptoms i had. Unfortunately, the death of mostly all the locks was alot quicker then what you had. If you search through here, if the locks are constantly trying to lock, they WILL eventually burn up. So, don't think ok this will be fine. If it gets worse and starts doing it more then just when the key is in the car, prepare to lose 90% of your auto locks. There is documentation of this happening to people around the forum, idk how old it is though.
The whole key in the ignition thing is a IDK , and the heat makes more sense to what they are saying about relays and wires. When its hot, the poor contact expands and generally loses continuity. Cold, vice versa. You see this everyday with the ABS modules.
I would follow what they said above for testing. I honestly am shooting a guess here, but, iirc the locking relay has a 'K+' terminal, which is the signal to lock all the doors? It's been a while so idr, but, i would look into the locking relay after everything is said and done.
1993 850 GLT - My Baby, Lanier
1996 850 R - My Love, Suwanee
VS for life
#11
Posted 02 May 2012 - 01:28 AM
Under the drivers side dash... relays 205/206where is this found?
***Edit*** Added pic from vadis
Edited by MattyXXL, 02 May 2012 - 01:44 AM.
#12
Posted 02 May 2012 - 08:39 AM
Prime suspect!
#13
Posted 02 May 2012 - 03:26 PM
#14
Posted 02 May 2012 - 04:27 PM
#15
Posted 03 May 2012 - 11:45 PM
next move is that relay above the pedal assembly
and possibly after that the aftermarket alarm well see how she goes
#16
Posted 05 May 2012 - 11:51 PM
#17
Posted 06 May 2012 - 11:42 AM
Toronto CAN A DA.
#18
Posted 06 May 2012 - 01:37 PM
