Abs Tracs Lights Onhard Knock When Braking
abs brakes v70 awd
6 replies to this topic
#1 paulwall5
paulwall5
  • 9 posts
Posted 30 April 2012 - 04:18 PM
I just bought a 98 v70 awd had a bunch of codes when i bought it didnt pay nothin for it. since i got it i have done both half shafts, plugs and wires, air filter, oil change, struts, put on all funky, little stuff so far (waiting on rotors and pads) . ok problems now to be adressed abs and tracs lights on and when i stop most of the time but not all the time i get a loud clunk from under the car towards the rear.
So the question is could the noise be abs related or couldt it be drive shaft related? and how can i check the fluid level in the rear? Or could it be rear half shaft related do they even sale those.
#2 Matty Moo
Matty Moo
  • 1,922 posts
Posted 30 April 2012 - 10:29 PM
Sounds like it's either one of two things.
You didn't torque down the axles correctly, or something is going on with the abs system. It could be the module or you possibly screwed up some wiring since you stated you did things "funky".
#3 paulwall5
paulwall5
  • 9 posts
Posted 01 May 2012 - 01:21 AM
i havent had time to mess up any wires but i will check all abs and tracs sensors and wires and the sound is comeing from the rear havent done anything back there, trying to see were to start .Rear pad were diging in to the rotors just slaped some pads in to get it to the shop. Lights were on when i bought it two weeks ago . Got rear rotors and pads today but i aint put nothin on till i figure out wats going on. Front coils were all wavy thats funky dont know (scary) funky stuffs off. Got to see it to belive it, ima put it on here when i figure how to.Got a abs module on the way.
thanks for the help
any body know if i plug my car in to vadis can i see abs codes?
#4 T5BLACKattack
T5BLACKattack
  • 478 posts
Posted 01 May 2012 - 01:53 AM
If the shocks look "wavy" someone may have replaced them and they might not have seated. I have seen it a few times before where the jump around the spring seat when braking. Also, if the previous owner did brake pads and they did not sit right they could also be slidding around under the caliper causing a clunk. Abs module is not really going to cause a clunk.. nor is the module itself.
1998 S70 GLT-5 427 / 1998 S70 T5M 019
#5 paulwall5
paulwall5
  • 9 posts
Posted 01 May 2012 - 04:58 AM
I pulled both struts out before doing half shafts that noise was a hard pop when i turnd left. Im going to do the pads and rotors all around and bleed system anyways , look like a metal soup bowl. just remembered there was almost no fluid in brake reservoir.like i said paid nothing for it just a project car somthing to tinker with. looks like its going to sit another week.
#6 T5BLACKattack
T5BLACKattack
  • 478 posts
Posted 01 May 2012 - 02:00 PM
If you are hearing a bang on a hard left I would look at axles, especially seeing as you touched them recently.
#7 paulwall5
paulwall5
  • 9 posts
Posted 01 May 2012 - 04:02 PM
Axels were blown first thing replaced, checking bolts, wires everything around there. Any one know if i can buy new rear halft shafts. havent seen any out there or could it the prop shaft. Back in a bit im going under.
