Random Speedometer 98 S70 T5M
5 replies to this topic
#1 BoostedMoose517
BoostedMoose517
  • 176 posts
Posted 01 May 2012 - 03:49 AM
Alright, So i made a post earlier similiar to this. I searched and couldnt find anything like the issue i am having so here it goes....
Car is a 98 S70 T5M.... The car doesnt have a ABS light when ignition is on 2 and i cant get the TRAC light to come on on the dash either, I went over the abs system and all sensors are clean, Seated correctly, No wires broke, No blown fuses or relays. I am leaning towards this is also why my speedo isnt working. I dont think its the ignition switch as to i can give the switch hell for 5 mins and to no avail nothing happens to fix it. If i turn left i lose the speedo, Under accel i lose it. And randomly comes back.
1997 854 N/A(Sold) 1996 854 Turbo-Sold 1994 855 Turbo - Sold 1998 S70 T5M- Currently stock
#2 survolvo
survolvo
    Hollywood
  • 3,224 posts
Posted 01 May 2012 - 03:56 AM
Its your ABS Module.
I had the same speedo thing happening, replaced ABS mod and works great.
https://www.midwest-abs.com/
Also sounds like you need to replace some cluster bulbs.
1996 854 T5
M56h w/ R Clutch, NA Intake Mani, Snabb Phenolic Intake Spacer, NA Throttle Body w/ 960 Plate, Snabb Intake Pipe, Custom CAI, NA Cams, S60R Exhaust Mani, ARD Billet 16t , Whites, iPd TCV, ARD Lightwieght Crank Pulley, +99 Oil Pan/Cooler, Kingsborne 8mm Spark Plug Wires, 302mm Front Brakes, Volvo OEM Strut Tower Brace, Konis, IPD/TME springs, ARD Green Tune
#3 BoostedMoose517
BoostedMoose517
  • 176 posts
Posted 01 May 2012 - 03:58 AM
Alright, I will buy a unit off that site and let you know what happens, I was thinking its the ABS mod but wanted other input, Thanks Sur
#4 survolvo
survolvo
    Hollywood
  • 3,224 posts
Posted 01 May 2012 - 04:16 AM
If you end up replacing the cluster lights you should replace the Odometer gear while its apart.
1996 854 T5
#5 Matty Moo
Matty Moo
  • 1,941 posts
Posted 01 May 2012 - 04:43 AM
I found a bag full of cluster bulbs today tucked away in a box. Let me know if you want some.
#6 T5power
T5power
  • 4,939 posts
Posted 01 May 2012 - 02:41 PM
it's a 98. 98=digital.
unless you're doing it Two Turtles style!
CHECKMATE
