85 Ecu Question
#1 Jupiter
Jupiter
  • 3 posts
Posted 01 May 2012 - 09:42 PM
My 244 has a 0 280 000-511 in it
but I just found a 0 280 000-544 at the cophers, any reason for this to be a bad idea?
Some research indicates the 544 seems to use the same AMM the 007, and it's also the same Jetronic version LH 2.2
#2 Three Fat Tigers
Three Fat Tigers
    RWD Moderator
  • 1,752 posts
Posted 02 May 2012 - 12:52 AM
Should just be plug and play. Any LH 2.2 ECU should work, even one from an 700 series, as long as it's not for an V6 engine.
I'm using an LH2.4 ECU in my '92 240 that came from an '94 940 non turbo, made a big difference in throttle response and economy, next I hope to try an 012 amm to see if that does anything.
#3 Jupiter
Jupiter
  • 3 posts
Posted 02 May 2012 - 01:42 AM
Awesome, Thanks man!
