Want To Rent Ny: Wastegate Adjustment Tool
wastegate adjustment tool
8 replies to this topic
#1 burnout8488
burnout8488
  • 714 posts
Posted 02 May 2012 - 01:26 PM
Going to be installing my turbo soon, I'd like to rent a wastegate adjustment tool. (Probably the IPD one?)
I'll pay a deposit (you determine) plus shipping, ship it back to you, then you refund me the deposit minus $10 for your time.
Need ASAP within two weeks max, thank you!
'99 S70 AWD + FWD Trans // 161K
2.4+15g/Rmani/Snabb Pipe/EST DP/ARD Green/4300k Bi-Xenon Retrofit/Nivomats/Rear Heated Seats
#2 db130
db130
  • 771 posts
Posted 02 May 2012 - 04:02 PM
do you have a fuel pressure gauge or can you borrow one from one of the chain auto parts stores? if so, you can make one quite cheaply
this is my Kent-Moore wastegate tester that I bought 2nd hand. all you need is the gauge, some rubber tubing, a vac tee, and a blood pressure bulb($6.25 w/ free shipping on ebay, see item # 230785022148)
2000 V70XC SE, 162k '00 R Duals/Angled 15G/15 psi ST T5 tune/Delco TCV/UK 302s/180°F Stant Superstat/Samco hoses/IPD HD CBV/Sconeman intake
1998 S70 T5, 233k '00R 302s DIY AEM BCS/IPD Stage 1 ECU/IPD 3" Turboback
Check out the Delco BCS/TCV
#3 850T5M
850T5M
  • 445 posts
Posted 02 May 2012 - 04:25 PM
I used a blood pressure cuff that I ordered off ebay...paid it 15$ shipped I believe.
Basically you just need the gauge and the bulb and a vacuum T-fitting. The gauge is in mmHG but you can convert from PSI to mmHG.
My ARD Tune + 16T says to be at 3.7PSI at the wastegate, so thats 191mmHG.
1994 Volvo 850 Turbo Manual
ARD Green Tune | FMIC | OBX Turbo Back | Angled 16T | TurboSmart BOV
#4 burnout8488
burnout8488
  • 714 posts
Posted 02 May 2012 - 04:28 PM
Didn't realize they were that cheap! Guess I'll go that route then and just buy one.
#5 850T5M
850T5M
  • 445 posts
Posted 03 May 2012 - 12:45 AM
http://www.ebay.com/...=item3cc4fb405b
This is what I got...worked fine
#6 sconeman
sconeman
  • 4,387 posts
Posted 03 May 2012 - 01:16 AM
I've got one you can "borrow" for shipping and a deposit. I can have it to you by Saturday if paid tonight. email me your info I'll paypal you an invoice. As soon as it's paid I'll ship you return it.... I'll refund deposit minus $10 as suggested.
kristian@snabb.us
please send shipping info and paypal email address plus phone number.
Kristian
#7 Yellow95
Yellow95
    Grandpa G
  • 6,746 posts
Posted 03 May 2012 - 01:57 PM
DO those things have a one way valve in them or do you just squeeze and hold?
#8 Jazzy_J
Jazzy_J
  • 309 posts
Posted 03 May 2012 - 07:36 PM
I would assume so but not sure. The video IPD has of how to use the pump shows them pumping away then letting go and it holds the pressure. I don't see how this could work without either a check valve or a closed system.
#9 shurgen
shurgen
  • 1,137 posts
Posted 03 May 2012 - 08:43 PM
There is air release valve between the bulb and hose, put pressure in with bulb and close the valve, then slowly release the air until your desired number on the gauge.
96 855R 160k miles
04 V70R Red/Atacama/6 MT, 78k miles, Rica Stage2, 3"DP, JRL mod, 3"CAI, Viva CBV, Elevate sways
