White Top Injector Question
25 replies to this topic
#1 Jcbkid
Jcbkid
  • 90 posts
Posted 03 May 2012 - 08:22 PM
Picked up a set of injectors from the junk yard, just curious what i should watch out for if anything when putting them into my 98 v70xc
I Currently have an mbc and im pushing 10psi so i want a little more power obviously
Thanks guys
#2 ErikS
ErikS
    99.9%
  • 5,408 posts
Posted 03 May 2012 - 08:36 PM
Why? Are you going to a 15G/16T turbo?
1995 854 T5M Click for Mods
2005 S60 2.5 T
2013 MB GLK 350
#3 Yellow95
Yellow95
    Grandpa G
  • 6,745 posts
You wont need them at that boost level. Nice upgrade for future plans but unneeded right now.
Gary
#4 Jcbkid
Jcbkid
  • 90 posts
Posted 03 May 2012 - 08:56 PM
Well follow up question:
Ive been looking into the turbo from an 850 turbo (not glt) which correct me if im wrong has a 15g and white tops? so is this usable on my car?
#5 FINN
FINN
    Pretty Boy Racing
  • 7,316 posts
Posted 04 May 2012 - 01:11 AM
Gonna be oranges.
-Petri (Val)
'97 850R: Built motor - 99RN Head - 960TB - Ported/Polished Intake Mani - R Mani - K24 - FMIC - 3" turboback - M56 w/ R Clutch - Prosport gauges - Bilsteins - IPD Springs - Projectors - Gemini Carbon Fiber Lip - MP 19x8.5" - Fuzion ZRi 235/35/19 - X70 interior swap
Build thread: http://volvospeed.co...r-build-thread/
'96 850R: IPD - Koni - BSR - Samco - Yakima - Giovanna 18x8" - Falken Azeni 225/40/18
#6 Yellow95
Yellow95
    Grandpa G
  • 6,745 posts
Posted 04 May 2012 - 12:34 PM
Even with the 15G the white tops wont be needed. Your GLT injectors actually outflow (marginally) 850 turbo injectors. If you want to, throw the whites on. Just dont expect any performance gain. There wont be any.
Gary
#7 sconeman
sconeman
  • 4,387 posts
Posted 04 May 2012 - 01:31 PM
if you throw bigger injectors on your car without tuning for them you will just run rich and get bad gas mileage.
#8 Jcbkid
Jcbkid
  • 90 posts
Posted 04 May 2012 - 02:30 PM
Good to know! So can you guys give me a list of injectors from smallest to largest by color? I tried looking and couldnt find one. And is that turbo on the 850 a 15g? i know it had the t5 ecu
#9 lookforjoe
lookforjoe
  • 9,771 posts
Posted 04 May 2012 - 03:33 PM
You're kidding, right? Look in the pinned thread & use SEARCH. None of that matters anyway. Unless you are planning on a bigger (than 15g) turbo, there is no need or point, as has been stated.
#10 Jcbkid
Jcbkid
  • 90 posts
Posted 04 May 2012 - 04:48 PM
Whoa slow your row bro, no need to get all anal on me. Ok ill search thank you very much.
#11 Deimos
Deimos
    I beat anal fissures
  • 971 posts
Posted 04 May 2012 - 05:05 PM
Yes, it's a 15g, no you don't need new injectors, just a proper tune and MBC-delete. Why don't you "slow your roll bro" and do some research before getting random parts?
1999 S70 Base w/ Manual - IPD Springs and Sways, HD Endlinks, Bilstein TC Struts, HD Shocks, OBX Strut Brace, Lots of Poly, Custom Exhaust, Amaltheas, Pioneer Double DIN
#12 Jardim
Posted 04 May 2012 - 05:15 PM
OP: If you get a 15G out of a 850T to go in your 98 XC your going to need a new down pipe (or modified stock DP). 15G = Conical, im pretty sure 98 turbos are straight flanged so that would be a issue.'
and the T5 ECU from an 850 is Motronic 4.3 vs your XC being M4.4...if you can find a T5 Ecu from a S70 T5 that would be your best bet.
#13 -Matt01
-Matt01
  • 451 posts
Posted 04 May 2012 - 06:46 PM
bro, slow down your row bro, bro.
Same with the AWD... if you don't actually own one, or never have, or plan to do so, then shut your pie hole.
#14 Aequitas_Veritas
Aequitas_Veritas
    Blue Calipers&Balls
  • 8,130 posts
Posted 04 May 2012 - 06:52 PM
many 15g turbos came with a straight flange. And if he did get a conical version he could just swap over the hot side off his turbo now onto the 15g and not need a new downpipe. In fact he should do that anyways cause the conical flange sucks and should be avoided.
#15 Jardim
Posted 04 May 2012 - 07:14 PM
Never seen a 16T with a straight flange, must be on later year 850 models....but yes i forgot you can simply swap the hotside... the difference is in the compressor side and the wheel....making these TD04s "hybrids"....But id get an ehxaust anyway =P
15G* not 16T :lol:
#16 Aequitas_Veritas
Aequitas_Veritas
    Blue Calipers&Balls
  • 8,130 posts
Posted 04 May 2012 - 07:16 PM
yeah 96/97 850s had them. Mine had a straight flange stock.
#17 aggarcia
aggarcia
  • 275 posts
Posted 05 May 2012 - 10:11 AM
Manual trans 850R and later S70 T-5 to name a few had straight flange 16T. Pretty common turbo in fact.
97 850R - ARD Blue tune, S60R Ceramic Manifold, 18T, Snabb Fresh air pipe, OBX Downpipe, 3' SS mid pipe w/Random Technology Cat, TME Exhaust, AC Delco BCS, FCP Silicon Hoses,
Suspension - IPD 25 mm track sway bars, H&R Springs, Koni Sports struts/shocks, Maxxium Grip 18x8 Wheels, 302 brakes with Porterfield R4S pads
#18 Jcbkid
Jcbkid
  • 90 posts
Posted 08 May 2012 - 11:57 AM
This is what i will do as soon as i get paid, will also revert back to my tcv and run the 850 ecu untill i can find a t5 ecu, thanks for the help guys
#19 Jcbkid
Jcbkid
  • 90 posts
Posted 08 May 2012 - 08:23 PM
In the meantime i was looking into a N/A intake manifold and throttle body as i have heard they were slightly larger than the ones on mine currently, not expecting a huge gain if any but just looking into a few other options. (I already know i can use N/A cams just dont want to do that yet)
#20 madspeed50
madspeed50
  • 167 posts
Posted 08 May 2012 - 11:18 PM
15G* not 16T :lol:
Me gots 16T with straight flange, but it is a 98 S70
98 T5M, IPD ECU, OBX Turbo back, KW Variant II coilovers, 17x8 OZ Supperleggeras, Snabb pipe, Short shift kit, IPD Sway Bars, IPD Strut Brace, blah blah blah and more to come for sure aka - MADSPEED
