you can only reliably log three channels of data via OBDII. The limiting factor is ISO-9141, not the device.
That's what I have found also. If you attempt to log more than 3 parameters with the OT-2, things tend to slow down. Like Hussein said, that is NOT the OT-2's fault. It's because Volvo uses ISO-9141.
I use Innovate for all of my logging and it has been very reliable for me. I'm logging 9 parameters, but only 3 with the OT-2.
AFR... LC-1
Boost... AuxBox
RPM... AuxBox
IDC... AuxBox
EGT... AuxBox
IAT... AuxBox
Timing... OT-2
MAF... OT-2
Vehicle Speed... OT-2
I cut an OBDII harness and connector from a junk car, and wired it into the original harness. That way I can keep the OT-2 plugged in all the time, hidden behind the dash, and still have access to the originall OBDII connector.
If you look at the logs, you can see the channels that are logged with the OT-2. They don't flow as smoothly as the "real-time" data from the other sensors. Due to the ISO9141 being somewhat slow, the data looks a little "notchy", but still very usable....
1998 S70T5M, 2000 Built B5244T2 RN Engine, K24 turbo, 550cc injectors, Turbo-Tuner, Coolingmist Progressive WMI, Precision FMIC, 311whp 363wtrq
