1998 Volvo V70 T5M Green On Black W/210K - Usd 3,500.00
Posted 10 May 2012 - 02:46 AM
View the full article
Posted 10 May 2012 - 01:59 PM
Recently replaced:
IPD wires, plugs, cap, rotor
Rear brakes (pads, rotors)
Front pads
Rebuilt ABS unit
Timing belt +rollers
PCV system
Added:
Rear spoiler
Third row seat
Rear heated seats
Auto dimming mirror (wired in)
Ajustable wiper relay (#99)
XC grill
SAS delete
K&N air filter
In the process of replacing before sale:
Clutch: This will be done along with the RMS before selling
New brake cable on the drivers side and all new hardware
Normal failure points that are good:
No heater core leaks
AC works (no leaks)
All door lock actuaters work!!
Cup holders are 100%
FOB is not broken
EVAP has no leaks (no codes at all!)
Comes with two sets of rims and tires. One complete brand new never mounted Eagle GT summer tires (16s) and one set of good winter tires (15s). The 16s fit on the stock aluminum wheels and the 15s go on steels (unless you want three XC wheels and find a replacement 4th).
There is no CEL, SRS, ABS or any issues with it's running state. This is my personal vehicle that I have taken care of, it has no leaks aside from the rear main which will be replaced when I do the clutch. I wanted to post this up here ahead of time since I've seen some people looking to buy later on in the year.
Posted 10 May 2012 - 03:16 PM
Nick | 1998 S70 T5 SE | In the works: stuff
Parting: 2004 C70 Vert, 2002 C70 Coupe, 2000 C70 Coupe, 2000 V70R, 1998 V70R, 1999 V70R, 2000 S70 GLT SE
Posted 10 May 2012 - 03:38 PM
Posted 10 May 2012 - 03:43 PM
1996 854 T5
M56h w/ R Clutch, NA Intake Mani, Snabb Phenolic Intake Spacer, NA Throttle Body w/ 960 Plate, Snabb Intake Pipe, Custom CAI, NA Cams, S60R Exhaust Mani, 16t w/ Whites, iPd TCV, ARD Lightwieght Crank Pulley, +99 Oil Pan/Cooler, Kingsborne 8mm Spark Plug Wires, 302mm Front Brakes, Volvo Strut Tower Brace, Konis, IPD springs, few more things to come...
Posted 10 May 2012 - 04:16 PM
Not selling the 2001 for a while!
Posted 10 May 2012 - 06:24 PM
Former: 89 744 GLE 16V, 90 745 GLE 16V, 95 964, 94 854 Turbo, 01 S40 1.9T, 99 C70 HPT, 01 S60 T5, 07 VW GTI
Current: 98 V70 GLT - 155k, 02 Motor, 16T, ARD (DD), 97 854 GLT - 2xxk,(Backup)
Posted 10 May 2012 - 06:29 PM
'95 850 GLT 228k M56H ARD 850R/T5-R STUFF
Posted 11 May 2012 - 12:29 AM
Haha, green on black.. Translation: Tropic Green exterior with black leather interior.
Posted 16 May 2012 - 05:56 AM
Posted 16 May 2012 - 12:13 PM
I was just up in your neck of the woods last week
- The Lord is not my shepard for I am not a sheep- - If you repeat a lie often enough it becomes
