Edited by dublin14, 14 May 2012 - 12:09 AM.
Ac Compressor Issue
Posted 14 May 2012 - 12:08 AM
Posted 14 May 2012 - 05:39 AM
If there are no leaks and an adequate charge (static (off) pressure should be around 80-100psi) then look at the clutch gap. Test: Turn the A/C to "on" and run the car, then hit the clutch with a broomstick or equivalent tool that will not injure you. If the clutch engages, it needs to be shimmed. If not, the clutch isn't getting the "on" signal from the car. At that point, I'd look to the relay, faulty low pressure switch, or ECC module in the dash.
'99 S70 AWD + FWD Trans // 161K
2.4+15g/Rmani/Snabb Pipe/EST DP/ARD Green/4300k Bi-Xenon Retrofit/Nivomats/Rear Heated Seats
Posted 14 May 2012 - 10:34 AM
Posted 14 May 2012 - 11:29 PM
Posted 15 May 2012 - 12:36 AM
The only reason to suspect a leak is if there is not adequate pressure. But you must have adequate pressure, since you need it before you can test the compressor clutch. And you just posted that you checked the clutch gap. So ... ? Maybe this was not made clear enough: The way to tell whether or not the AC has a leak is by checking pressure, with a gauge. Not by attempting to test the clutch gap.
So, if the system does have pressure, then try the other things mentioned. Will take some searching but the low pressure switch can be jumpered, for example.
'96 NA 855 - 111 k - daily driver
'95 R 854 - 177 k
Posted 15 May 2012 - 01:51 AM
I think not, unless you didn't understand what burnout8488 was posting?
I didnt check the clutch on the compressor to see if I had a leak? That would make no sense at all. I checked the clutch to see if it would engage with a tap.. and it didnt. Now Im going to check for leaks with dye and see if I have a leak
Edited by dublin14, 15 May 2012 - 01:51 AM.
Posted 15 May 2012 - 02:42 AM
All I'm saying is you might want to first put a gauge on the valve and check pressure. If there is none, then dye test it. But if there is enough pressure, then don't waste your time with the dye. burnout's post explains it very clearly, it goes like this:
(1a) If there is pressure in the system and the clutch engages when tapped:
- removing clutch shims (or using zip ties) will solve it
(1b) If there is pressure in the system and the clutch does not engage when tapped:
- test the relay, the low pressure switch, or the ECC module in the dash.
(2) If there is no pressure in the system:
- Stop. Do not pass go. The clutch will not engage when there is insufficient pressure in the system. Ever. In that case, don't bother tapping it.
Since you didn't check pressure first, you don't know if the system is empty (2), or if the system is still charged but one of those other components is bad (1b). Is there pressure in the system or not? That's the first question.
You said AC quit working all at once, which is unusual for a leak. Usually craps out gradually, gets weaker. So some component failure is a reasonable explanation, too. Test the pressure and find out! On the pressure side, at least you know the evap should be OK since "the AC system was all replaced a few years back."
Hey did you evacuate the system before charging it? Moisture mixes with r134a to form acid, which will corrode the system internally. But I always thought that takes longer to happen.
'95 R 854 - 177 k
Posted 15 May 2012 - 12:00 PM
Edited by dublin14, 15 May 2012 - 12:01 PM.
Posted 16 May 2012 - 04:24 AM
I've rebuilt the A/C system on my S70 from the ground up, painting the lines, replacing every part, and it's actually quite a simple system once you've worked on it a bit. Make sure you evacuate the system before recharging it if you need to replace something and lose all of your refrigerant. Ask any questions here, I'd be glad to help you.
