Eagle One Engine Etching
eagle one engine etching cleaning
25 replies to this topic
#1 C7mb
C7mb
  • 68 posts
Posted 15 May 2012 - 03:09 AM
Hey guys! Just wanted to post up a quick tutorial/my experiences using the Eagle One MAG cleaner to etch my engine.
Before:
After:
All you need is:
bottle of Eagle One MAG Wheel Cleaner
rubber gloves
Heavy duty trash bag
Rubber bands/tape
set of sockets or flat head screwdriver
torx bits (T25, and T30 for my 04 XC70)
WD40
hose
towels
leaf blower
wire brush (optional)
To start off, make sure that the engine is clean and cool. The bottle doest specify wheather the engine needs to be dry (I didnt dry it before I sprayed on the Eagle One), however I think it will work better if it IS dry.
Now remove all the plastic engine covers (fuel rail cover, plug cover, timing belt cover) and the intercooler pipe. THIS STUFF CONTAINS HYDROCHLORIC ACID AND WILL STRIP OFF PAINT ETC!!! Using a heavy duty trash bag, cover the exposed boost tubing couplers and intake filter if you have an aftermarket one (I also covered my fuse and ECU cover because they are painted). Finally place a towel (or plastic if you can do it well) over the ignition coils to prevent any standing water or Eagle One from eating through the plastic.
With the engine prepped, put on your gloves and grab the bottle of Eagle One. Starting with a test section, spray the Eagle One onto the aluminum making sure that there is a thick foam covering the section. Wait 30 seconds to a minute and FLUSH THOROUGHLY with water. If you see a difference then you can spray the rest of the aluminum. If not then try a second or third coat until you see a noticeable difference, scrub with a wire brush if necessary. With the test spot a success, begin to spray the rest of the aluminum parts by section. Also do not get this stuff on any polished, chromed, or buffed surface because it will either turn it purple or make it dull. After each etching stage, flush the area to make sure that there is no acid left anywhere on/in the engine for an extended period of time. Keep applying, and flushing each part until you reach the desired results.
Once the all the aluminum has been etched, flush the whole engine compartment one last time to make sure that all the acid has been neutralized/diluted. Next take a towel or leaf blower and dry all the aluminum. The aluminum must then be coated with WD40 to protect against future damage/corrosion. If you do not put WD40 or powder coat the aluminum it will corrode and turn white/nasty. Replace all the engine parts that were removed earlier and now you have an etched and clean engine without the hassle of media blasting!
More before and after pics:
Edited by C7mb, 15 May 2012 - 03:14 AM.
04 XC70 "RICERMööS" - LED Mods / Projector Retrofit /CAI / OBX Catback and Downpipe /Snabb Inntake /IPD Strut Mounts, Upper Engine Bushing and Transmission Mount / Drilled and Slotted Rotors / Custom Grill / Rail-less / Polished Intake Manifold
#2 98t5M
98t5M
  • 546 posts
Posted 15 May 2012 - 07:17 AM
Looks nice, please keep us updated about how your timing belt holds up after being sprayed with acid.
#3 (n)A-GAME
(n)A-GAME
    Chief Investigator
  • 7,645 posts
Posted 15 May 2012 - 01:23 PM
Funniest post I've seen all week.
2011 Volvo S60 T6 AWD Polestar | 2000 Volvo V70 R AWD
#4 C7mb
C7mb
  • 68 posts
Posted 15 May 2012 - 02:18 PM
Haha i didnt dump the Eagle One on my entire engine. I sprayed on just the aluminum parts and washed off any over spray that got onto other components. But i will definitely let you know if i shread my timing belt because of this. XD
#5 Yellow95
Yellow95
    Grandpa G
  • 6,750 posts
Posted 15 May 2012 - 02:22 PM
OP- You should know that if you post something helpful here they will stand in line to dump on you. Its the VS way.
#6 C7mb
C7mb
  • 68 posts
Posted 15 May 2012 - 02:33 PM
Haha yeah ive gotten that sense since joining. If youre not one of the "originals" or if you dont do insane mods, you get shat on. As long as you dont take anything personally/dont give a monkey what people think your golden! Thanks for the support!
#7 95-850 wagon
95-850 wagon
    Billy Mays here for CB.
  • 125 posts
Posted 15 May 2012 - 02:44 PM
its true.....i get shat on all the time :D
good info here
#8 MattyXXL
MattyXXL
  • 2,467 posts
Posted 15 May 2012 - 08:21 PM
You Love it.... so complaining... :P
1996 854 T-5 Modded, But who really Cares
1995 Yellow 854 T5-R Bone Stock!
http://www.floridavolvocommunity.com/
#9 Dan A
Dan A
    Old Man Crew Pledge Pres.
  • 1,994 posts
Posted 16 May 2012 - 02:41 AM
Not sure I'd try this with the parts on the engine but you can't deny that his engine bay looks superb.
99 V70R
98 V70 GLT
#10 BtownVolvo
BtownVolvo
    Level 69 Member
  • 8,709 posts
Posted 16 May 2012 - 05:30 AM
Haha yeah ive gotten that sense since joining. If youre not one of the "originals" or if you dont do insane mods, you get shat on. As long as you dont take anything personally/dont give a fuck what people think your golden! Thanks for the support!
And this is currently why you're netting a +5 rep (which is good). Most don't get our humor, and cry. So high five for you.
Reid | 1998 V70 T5
#11 Mattphi
  • 8,626 posts
Posted 16 May 2012 - 12:33 PM
#12 Mesoam
  • 19,745 posts
Posted 16 May 2012 - 01:04 PM
some simple green, steel wool, assorted sand paper and mothers mag alm polish would accomplish this much safer
covers look good, what did you spray them with? clearly painted
Edited by Mesoam, 16 May 2012 - 01:04 PM.
#13 VolvoForLife91
VolvoForLife91
    TICKLE SHITS
  • 4,808 posts
Posted 16 May 2012 - 05:53 PM
Haha yeah ive gotten that sense since joining. If youre not one of the "originals" or if you dont install underglow, you get shat on. As long as you dont take anything personally/dont give a fuck what people think your golden! Thanks for the support!
#14 C7mb
C7mb
  • 68 posts
Posted 17 May 2012 - 03:57 AM
good info here
haha Thanks!
Thanks! Yeah I made sure I was very careful. So far so good!
Hahaha truth is, I like LEDs and lighting in general. Every light in my car has been switched over to LEDs as well as lights added. Another reason I added the underglow and stickers was because I like making people laugh and thought it would be funny to rice an XC70. If only you saw the looks I get while driving!
I actually did that before using this. It lasted a while but then became white and corroded (never used WD40 until the Eagle One). I intend to polish all the aluminum to a mirror finish when I have the time.
The covers are painted with rustoleum Carbon Mist. It looks AWESOME but the clear coat I used is stuff (rustoleum) so it peeled a little in a few places.
Do you mean "if you do install underglow you get shat on"?
#15 tuner4life
tuner4life
  • 287 posts
Posted 23 May 2012 - 03:53 PM
Nice write up, this thread isnt about your car, its about a good way to clean up the aluminum under your hood. I will be trying this.
1d2a0e33-e26d-4036-b396-36c45b3ecd73_zps
'98 Volvo C70 Saffron HT Coupe - '97 Lexus SC300 rsp/blk/turbo - '92 Saab 9000 Turbo -'86 Saab 900 Turbo SPG clone - '97 Volvo 850 - '93 Toyota Camry
#16 C7mb
C7mb
  • 68 posts
Posted 24 May 2012 - 03:45 AM
Thanks! And thanks for puting the thread back on topic!!! USE ALOT OF WD40! My manifold is begining to turn a little dark....
#17 Deimos
Deimos
    I beat anal fissures
  • 988 posts
Posted 24 May 2012 - 07:48 PM
LED Headlights?
1999 S70 Base w/ Manual - "5 BANGER" - IPD Springs and Sways, HD Endlinks, Bilstein TC Struts, HD Shocks, OBX Strut Brace, Lots of Poly, Custom Exhaust, Amaltheas, Pioneer Double DIN
#18 C7mb
C7mb
  • 68 posts
Posted 24 May 2012 - 10:25 PM
LED Headlights?
I have LED switchbacks for the turn signals/DRLs and red angel eyes. I retrofitted projectors and painted the headlight housing.
#19 Deimos
Deimos
  • 988 posts
Posted 25 May 2012 - 01:46 AM
Ah, I was just wondering if you'd done an LED conversion for the actual headlights with parts from an Audi R8 or something like that. Also love how people are following and -1ing all my posts now, even the legitimate ones.
#20 Dan A
Dan A
  • 1,994 posts
Posted 25 May 2012 - 03:48 AM
pics?
99 V70R
98 V70 GLT
