Digital Gauges
digital gauge gauges 850 performance engine boost
18 replies to this topic
#1 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 15 May 2012 - 05:25 AM
Has anyone used digital gauges? I have an 850 turbo and I am looking at getting a digital computer for the car. I have the torque app on my phone which is nice but I would like something that I can keep on my car at all times. I was looking at the scangauge II and the edge insight cts. Also, there have been forums with people using arduino boards to make gauges too. Any recommendations or experiences?
#2 T5power
T5power
  • 4,929 posts
Posted 15 May 2012 - 05:35 AM
i have my scangauge mounted in the gauge cluster, tucked away. lights match perfectly!
i <3 clearing the CEL on the fly.
CHECKMATE
#3 NEU
NEU
    Old Man Crew Photographer
  • PipPipPipPip
  • 3,633 posts
Posted 15 May 2012 - 12:45 PM
I use VEI Hi resolution digital boost gauge in the red. It has a lot of different options like how much boost you want it to read, 12,24,36,48,60psi. peak mode with adjustable peak hold time. The boost resolution is selectable, 1.0psi, 0.5psi or 0.1psi. And brightness for daytime and parking lights. And the best part is that it's a one piece design like a analog boost gauge, some other digital gauges are the gauge and a sender, this is all in one and very compact. They have a lower res version too and both are available in interanl and external sensor.
The only issue I've had in 3 years of using it is when my battery is getting low the voltage is not enough to fire up the gauge (or the gauge + connection isn't the best). But that is kinda a reminder I need to clean the battery termals or throw the charger on it, so it's like 2 gauges in one. ^_^
If I ever get a 3 gauge cluster I'll probably get the 2 in 1 gauges for EGT and A/F and for oil psi and voltage.
Here is some video of it at work on my car.
www.youtube.com/watch?v=KTbRXmcoGXc
Laser Blue 2000 V70R
Speedtuning St2 @18psi/19T w/Forge CBV/IPD drop-in intercooler/R mani/CJ 3"DP/dual 3"Magnaflow/EST intake w/K&N/Samco & Snabb hoses/Delco TCV/Bosch Super Plus/IPD HD COP/UR lite pulley/CJ delrin subframe mounts/TME AWD springs/TME strutbrace/IPD sways w/adjustable endlinks/Koni Sport strut/18" OZ Ultraleggera
#4 ErikS
ErikS
    Not Pretentious
  • 5,419 posts
Posted 15 May 2012 - 03:12 PM
A/F digital, boost, and EGT mechanical.
1995 854 T5M Click for Mods
2005 S60 2.5 T
2013 MB GLK 350
#5 black98t5
black98t5
  • 79 posts
Posted 15 May 2012 - 09:38 PM
digital wideband
98 t5 auto :(, ipd exhaust, ipd cai, samco intercooler and radiator hoses, glowshift wb afr, boost, and oil temp gauges, 19t, r mani, ard blue, na tb + cams, fmic
#6 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 16 May 2012 - 03:51 AM
Has anybody used the Ultragauge?
#7 Homer
Homer
  • 96 posts
Posted 16 May 2012 - 06:25 PM
You could just swap a VEMS ecu in ;)
-Jacob
My project thread. Whiteblock content! http://forums.turbob...ad.php?t=219119
#8 MattyXXL
MattyXXL
  • 2,457 posts
Posted 16 May 2012 - 06:39 PM
digital wideband
How do you like the glowshift wideband?
1996 854 T-5 Modded, But who really Cares
1995 Yellow 854 T5-R Bone Stock!
http://www.floridavolvocommunity.com/
#9 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 16 May 2012 - 07:57 PM
Can you please explain?
#10 MattyXXL
MattyXXL
  • 2,457 posts
Posted 16 May 2012 - 08:30 PM
https://www.vems.us/
Engine management...
#11 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 16 May 2012 - 09:01 PM
Yes but what does that have to do with digital gauges...?
#12 ckavolvo
ckavolvo
  • 34 posts
Posted 16 May 2012 - 10:26 PM
I have the SPA dual gauge with boost and EGT in the vent
<a href=
And the scan gauge on the dash
<a href=
I really like the scan gauge
2006 V70R Black GT TME Exhaust, IPD Sway bars, HD end links, Strut Brace, Poly engine mounts,high output coils, D/P EST CAI, Silicone hose kits, SNABB intake, RICA stage II ElectronicsSPA digital Boost/EGT, ScanGauge II, Bel STiR ,Laser Interceptor HD front jammer, Mobileye collision avoidance system ,Sharper image ionizer, LED interior lighting,Garmin GPS hardwired custom POI's, Factory Sirius, ImiV, 2 USB, Verizon Mifi hotspot, PanaVise mount
#13 ckavolvo
ckavolvo
  • 34 posts
Posted 16 May 2012 - 10:32 PM
Photos
Is there anyway to edit a post ?
#14 MattyXXL
MattyXXL
  • 2,457 posts
Posted 16 May 2012 - 10:53 PM
only supporting members can edit
#15 Q-Ship
Q-Ship
  • 782 posts
Posted 17 May 2012 - 12:04 AM
auber instruments vacuum gauge - pefect stealth display.
'96 855 automatic. Color 214 <-now I will remember this. IPD stage 1 ecu, rip.
#16 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 17 May 2012 - 01:01 AM
My question: Is that the VEMS ECU or is that a gauge it comes with?
#17 oprahhwinfreyy
oprahhwinfreyy
  • 291 posts
Posted 05 June 2012 - 04:14 AM
I have a Scangauge. Cord goes through the back and under the steering column, routed along the side of the center console and up under my gearshift where my OBDII is relocated. If I have to get to it, I just pop the E-brake cover off.
1998 S70 GLT // NeckBrkz //
#18 VolvoForLife91
VolvoForLife91
    TICKLE SHITS
  • 4,808 posts
Posted 05 June 2012 - 05:14 AM
If that's your question, we can go ahead and end the thread now.
#19 maximumbuckeye
maximumbuckeye
  • 106 posts
Posted 05 June 2012 - 06:45 AM
What I'm really asking is, is that supported only with the VEMS ecu?
