Whirling Noise 1.5K To 2K Rpm - Cold Start
26 replies to this topic
#1 7 VII 7
7 VII 7
  • 22,956 posts
Posted 16 May 2012 - 03:51 PM
Over the last couple months I have heard a "whirling" noise after start my car up (been sitting for hours and engine is cold). It does not happen until I get to 1.5k to 2k RPMs. No hard shifting but it sounds weird, almost like wind. After the car gets going for 5 to 10 mins of driving (not fully warmed up) it goes away. I dont think it is the hub because it does not always happen when driving. I do have a busted driver's side inside axle.
Any ideas?
1 of 1 - '97 427 854R - 111k
#2 survolvo
survolvo
  • 2,932 posts
Posted 16 May 2012 - 03:55 PM
You only hear it while driving?
1996 854 T5
M56h w/ R Clutch, NA Intake Mani, Snabb Phenolic Intake Spacer, NA Throttle Body w/ 960 Plate, Snabb Intake Pipe, Custom CAI, NA Cams, S60R Exhaust Mani, ARD Billet 16t , Whites, iPd TCV, ARD Lightwieght Crank Pulley, +99 Oil Pan/Cooler, Kingsborne 8mm Spark Plug Wires, 302mm Front Brakes, Volvo OEM Strut Tower Brace, Konis, IPD/TME springs, ARD Green Tune
#3 Rsterns
Rsterns
  • 1,223 posts
Posted 16 May 2012 - 05:14 PM
Sounds like it could be your SAS pump. Only works for the first couple of minutes when the engine is cold. The pump can make strange noises.
'98 V70 T5 (Auto) At 280,000 fresh rebuild with port and polish ;Cryo treated everything, ARD Blue tune w/ IPD Intercooler and TME cat back exhaust,Koni FSD/ Eibach springs, IPD sways F/R, IPD HDEndlinks, IPD BBK Currently 407K miles... '99 V70 T5M (Was JRLs)
#4 7 VII 7
7 VII 7
  • 22,956 posts
Posted 16 May 2012 - 06:10 PM
no SAS pump
I will check when I leave work if it makes the noise while my car is in P and started up.
#5 Burn-E
  • 9,311 posts
Posted 16 May 2012 - 06:20 PM
Maybe it's time to oil the wheel and swap out a new hamster from under the hood. ;)
#6 rmorse
rmorse
    All my sperm swims to the right
  • 1,585 posts
Posted 16 May 2012 - 10:23 PM
This comes up soooo much, yet we still don't have a set answer. I have it too. :-(
But yea, best guesses are oil pan o-rings or oil thermostat.
#7 survolvo
survolvo
  • 2,932 posts
Posted 17 May 2012 - 01:50 AM
I remember someone saying something about the PS pump. Has anyone with these symptoms removed their Serp belt yet?
1996 854 T5
#8 rmorse
rmorse
  • 1,585 posts
Posted 17 May 2012 - 10:18 AM
I did, and it's still there.
#9 7 VII 7
7 VII 7
  • 22,956 posts
Posted 17 May 2012 - 11:56 AM
Ok, I started the car up this morning and started to rev it slowly to 1.5k and to 2k to 2.5 k... sound is there even when the car is in P. It is almost like a groaning/whirling noise. I was not doing anything else besides stepping on the accelerator.
#10 MrLorence
MrLorence
  • 1,831 posts
Posted 17 May 2012 - 12:01 PM
Ive had this happen on my old Plat. Wag and now its happening on my 97 R....I was thinking it was the belt tensioner for the serp, and I remember reading that on here in an older post....
1996 855 Platinum  - Died
1997 850  - Sold
#11 7 VII 7
7 VII 7
  • 22,956 posts
Posted 17 May 2012 - 12:30 PM
I mean that does make sense.
#12 T5BLACKattack
T5BLACKattack
  • 478 posts
Posted 17 May 2012 - 12:39 PM
Whirling noise, turbo not getting enough oil on startup? If its rpm related you should hear it slightly at low rpms, and as it increases you would hear it more. Its not present at idle at all? Could def. be the tensioner, when it warms up the fluid inside the bearing actually lubricates.
1998 S70 GLT-5 427 / 1998 S70 T5M 019
#13 7 VII 7
7 VII 7
  • 22,956 posts
Posted 17 May 2012 - 01:19 PM
It is RPM related. It is not present at idle at all.
#14 rmorse
rmorse
  • 1,585 posts
Posted 17 May 2012 - 01:30 PM
Not tensioner (I think), since I was scared when I first heard it and did a complete timing belt + water pump change.
#15 rmorse
rmorse
  • 1,585 posts
Posted 17 May 2012 - 02:10 PM
And here, background reading:
http://www.___.com/f...1110b7c45e4f1bc
http://volvospeed.co...ne-whine-98-t5/
http://volvoforums.c...hine-s70-58242/
http://v70r.com/foru...-on-cold-start/
tl;dr version - Try replacing the oil pan o-rings and then try oil thermostat.
Damn, I hate how VS doesn't like you posting MVS links.
Try this:
http://www.
___
.com/forums/
viewtopic.php?f=1&t=37422&sid=
b1dd155b67843df521110b7c45e4f1bc
Make that one link.
But add in Matthews Volvo Site
#16 7 VII 7
7 VII 7
  • 22,956 posts
Posted 17 May 2012 - 02:33 PM
Sep Tensioner... not Timing Belt Tensioner
#17 Mesoam
  • 19,743 posts
Posted 17 May 2012 - 02:44 PM
post a video of the noise
#18 gilber33
  • 15,151 posts
Posted 17 May 2012 - 02:52 PM
I got this too. Only does it when the car is cold and the first start of the day. After that it doesn't do it at all, even if the car sits for a few hours. I think it is coming from the PS pump somewhere. That's the EXACT area it's coming from. Happens in the same RPM range you're talking about, only happens for a few blocks of driving, car doesn't even have to be completely warm for it to go away.
#19 7 VII 7
7 VII 7
  • 22,956 posts
Posted 17 May 2012 - 02:57 PM
Exactly what I am going through. Thanks!
When I get situated in the new house I am going to go over my car with a fine toothed comb and get a good look at everything.
#20 rmorse
rmorse
  • 1,585 posts
Posted 17 May 2012 - 03:04 PM
But it can't be ps or serpentine tensioner if it still does it with no serp belt.
